Old 09-02-2023, 12:15 AM #1
4runnerfever67 4runnerfever67 is offline
4runnerfever67 is on a distinguished road
Steering rack play, too much? Also upper control arm question
I'm learning here. I have this video I filmed showing my steering rack bushings. Another person is turning the wheel back and forth lightly. Also the truck is on gravel. Is this too much play or is it ok?
3rd gen 4runner steering rack play - YouTube
My other question:
I have OME 883 coils in the front of my 2000 limited and I think it gave about 2.5 inches of lift. Rn I'm still running stock upper control arms, but I'm planning to go through and change my suspension bushings. Should I just change the uca bushings or just buy complete aftermarkets and install them? I've heard some say that 2" is not required but 3" does require new uca's. So what if I'm right in the middle?
I'm planning to use 265/75/16 tires if it doesnt look too bad.
2000 4runner limited
4runnerfever67 is offline   Reply With QuoteReply With Quote
Old 09-02-2023, 01:47 AM #2
Jakeepoo3's Avatar
Jakeepoo3 Jakeepoo3 is offline
Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about
Jakeepoo3's Avatar
My other question:
Too much play. There should be no play. Yes you need upper control arms to correct caster with your lift.
Jakeepoo3 is offline   Reply With QuoteReply With Quote
Old 09-02-2023, 04:05 PM #3
Sarki Sarki is offline
Sarki has a spectacular aura about Sarki has a spectacular aura about
No way should your steering rack have that much movement. Take a look at the video by Timmy the Toolman and order up a poly bushing kit from Whiteline or which ever supplier you favor.
I just did this replacement last week while installing new lower control arm assemblies. It’s fairly straightforward and you will notice a significant improvement.
2002 SR5 Sport 4WD
Sarki is offline   Reply With QuoteReply With Quote
bushings , change , planning , rack , steering
Excessive play on drivers side steering - replace steering rack guide cheeser 3rd gen T4Rs 17 05-05-2022 08:15 PM
Aftermarket Upper Control Arms For Steering Stability (Sloppy feel fix?) TRDORmike 5th gen T4Rs 3 05-30-2018 09:43 PM
How play in the steering rack bushings is normal? fdbyrne 4th Gen T4Rs 6 06-09-2015 10:20 AM
Steering rack play mountainbiker42 3rd gen T4Rs 3 06-20-2014 11:28 PM
anyone else have some wicked play in their steering rack?? cordrayj1 3rd gen T4Rs 17 06-14-2013 01:16 AM
