Old 09-20-2023, 08:48 PM #16
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Originally Posted by mtbtim View Post
I absolutely agree with what you said. The problem with the analog coolant gauge is it's a poor indicator of the engine temp you're running at. The needle doesn't react until your engine is really hot. At what temp the needle actually starts to rise, I don't know, but I've gotten to 215 and the needle was still in the same location it would be if you were at the normal operating temp of high 180's to low 190's. In my opinion, a 30+ degree change with no needle movement is problematic. This is why I like using a secondary means to monitor engine temp. At first I used the phone app Torque Pro but I've since moved to using a Scan Gauge in each of my 3rd Gens.
I don't glance at my scan gauge constantly while driving, so if I burst a coolant hose, I still might not catch it in time before major engine damaged occurred. I mostly closely monitor it when I'm driving in adverse conditions. The ambient temp is high, 90's and above and I'm driving loaded down with gear and/or driving up sustained grades. This is the time I'm also closely monitoring my auto trans temp. Knowledge is power in these circumstances and I've more than once on trips pulled over to the side of the road and idled my engine until my engine and trans temp have gone down. When I'm creeping up on a 210 engine temp or a 220-230 trans temp, that's when I start to consider pulling off the road and giving my rig a break. I'd rather it take longer to get to my destination than burning up my engine or trans and then never getting to my destination. That day I was driving in Nevada and the ambient temp was around 210-215, I saw carnage all over the highway. There were passenger cars and trucks pulled off with what clearly looked like to me they overheated their vehicle.
I always highly suggest that people use an alternative means to monitor important things like Engine Temp, Auto Trans Temp and Charging Volts.
I didn't know the ambient temp in Nevada got to 210 to 215. I thought that area got around 110 to 115.... ;-)
I have had my 3rd gen up to 3/4 on standard dash gauge. I can understand the gauge may not be super accurate. But, I suspect the red zone on that gauge is the danger zone damage zone as per engineers would make it that way. :-)
I believe the variant without the gauge moment is on purpose. Owners would be complaining of the temp gauge would fluctuate wildly in normal operation. So my theory, is they have zone of no movement under the normal range operation.
I can understand, folks wanting to monitor things closely. I can agree with that if they want to. :-) I just check my fluid levels. Do maintenance and hope for best. Served me well since the 80s trucks. :-)
I do wish they would have options of full gauges. Like a built in android tablet that can just have a mode...
Old 09-21-2023, 12:44 PM #17
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
I corrected the temperature mistake in my earlier post.
I think you're giving the Toyota Engineers too much credit in this regard, but maybe your logic is correct in regards to how the temp gauge was intended to work.
I just think you don't want to wait until you're literally at the cliff's edge before noticing your engine is getting dangerously hot. It's better to closely monitor your temps in adverse conditions so you can catch the problem earlier and be able to do something about it. In my opinion, once the stock temp gauge needle starts to rise, it's already too late. You got your engine way hotter than you should have allowed it to get and maybe it ends up costing you a whole lot of money and headaches as a result.
As I've said many times, knowledge is power and ignorance isn't bliss in this situation. Catch the problem quicker by monitoring your engine temp and trans temp with an aftermarket means and you'll be better off.
Old 09-21-2023, 10:56 PM #18
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Valid points Tim... :-) This reminds me when my Sister took her Honda accord way past H. Not realizing and driving along.. Believe it or not, the engine ran for years afterwards... It did take the some termper out of the rings but amazingly that engine never warped a head crack or nothing. Just sipped a little oil.. I couldn't believe it. It met its demise when she took out a deer. It was all aluminum though. So the block and head expanded an contracted at the same rate. Thus I figured that's what saved it. :-)
I expect your radiator change corrected your issues with heat dissipation. :-)
Old 09-23-2023, 01:54 PM #19
Endlessblockades's Avatar
Real Name: Blair
Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold
Real Name: Blair
I wouldn't trust the dash temp gauge, personally. Mine was happily pegged in the middle as I took my rig on a sustained desert 'mountain' climb (Little Berdoo Canyon). I was shocked to see coolant temps go to 249 degrees on the Ultra gauge I had installed a few days before. The dash gauge wasn't moving any higher and I later heard that 250 degrees sets off a Temp light which seems rather extreme. There is some debate about which temp sensor the OBDII taps, but I stopped to cool down for 30 mins. Kept it in 4Lo the rest of the day but was still seeing 220s. Replaced the likely original 200k radiator with an OEM (wasn't aware of these options), new TStat at 6pm (it was at 12) a Tru-cool inline trans cooler and I now see 188 on the highway and 200 at max offroad stress. I view my dash temp gauge with the same suspicion I have for my fuel gauge - not to be fully trusted.
Y2K LTD/E 262K
Old 09-23-2023, 07:37 PM #20
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
The OBDII taps into the temp sensor at the front of the intake manifold since it's the one that communicates with the ECU. The temp sensor at the back of the intake manifold is the one that communicates with the engine coolant gauge on the dash cluster.
Yep, no way I would rely solely on the analog coolant temp gauge. This is especially important for anyone that drives in adverse conditions like you were doing in the desert. I think you got lucky. I would have pulled off to let the engine cool down WAYYYY sooner than that. I think you dodged a bullet not doing any engine damage. 250 is HOT for these engines.
Old 09-23-2023, 09:18 PM #21
Real Name: Blair
Real Name: Blair
Yeah I was concentrating on navigating some obstacles and wasn't paying enough attention. I shut her down as soon as I noticed. When I restarted I ran the heater on full for the rest of the climb (short) and she was fine on the way down. She never boiled and acted just fine, but I was shocked. Especially because I had trusted the dash gauge several times flying up to Tahoe from the BA and a doing couple 10-milers into the Rubicon trail from the Tahoe side and Barker Pass. That was before I learned that 4Lo ran cooler in general that 4hi, too. Noob activities and I probably did get lucky.....
Y2K LTD/E 262K
Old 08-18-2024, 03:41 PM #22
det107 det107 is offline
det107 is on a distinguished road
Wink
Originally Posted by phattyduck View Post
There's no engine temperature light.
Old school "Thar She Blows" is another way to tell if engine is overheating.
det107 is offline   Reply With QuoteReply With Quote
Old 01-12-2025, 02:47 PM #23
Real Name: Blair
Real Name: Blair
Originally Posted by 2TH4IST View Post
Been running this rad for a few years now. It's super nice. Also foam tape the fan shroud to make the system as efficient as possible.
Sorry to resurrect this thread but I put in a Koyorad (and an Iconic bracket for my trans cooler) I have substantial gaps in the shroud - mainly top and bottom. I am thinking of trying to find a junkyard shroud and altering the attachment holes to get a better fit, but what type of foam tape did you use? Is it heat-tolerant? Thanks!
Y2K LTD/E 262K
Old 01-12-2025, 03:56 PM #24
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Now its been a few more years.. Would you say that the all aluminum Koyorad is far superior to a OEM densos? I would suspect that a pure aluminum radiator would be a lot better then a plastictop and bottom denso.
The best radiator would be a 100% copper made one. But I don't think anyone makes copper radiators today for 3rd gen 4 runners as I havent seen one advertized anywhere. Those would be the ultimate cooling radiator. Too bad someone cant 3d print a fan shroud for your Kororad radiators. That fix perfectly :-)
Being none of mine or heavily modified nor does it get hotter then 90s mostly in my environment. I just probably stick with the densos replacements unless they got so bad that they work at all.. IF that occurs I goto a Koyrad or another aluminum radiator ... :-)
Old 01-12-2025, 05:15 PM #25
2TH4IST's Avatar
2TH4IST 2TH4IST is offline
2TH4IST is just really nice 2TH4IST is just really nice 2TH4IST is just really nice 2TH4IST is just really nice 2TH4IST is just really nice
2TH4IST's Avatar
@Endlessblockades I used your run of the mill foam weatherstripping from home depot. I think it was 3/4" thick for the top and bottom of the shroud and 3/8 or 1/4 for the left and right sides (it's been so long I don't remember the sizes, i just eyeballed the sizes and went out and bought what i needed). I did attach the foam to the shroud not the radiator. I also left a 1/4 inch gap at the end of bottom foam on one side so it will allow water to drain out, from rain and water crossings. Zero issues with the heat from the rad regarding affecting the foam.
@brillo_76 100% better then the "oem" denso's. Nothing to worry about on the koyo vs oem. I use oem loosely with these denso's. The denso the koyo replaced the top plastic tank was out of spec for the rad cap. The 2nd sealing surface was about 1mm to low and would not let my cooling system build pressure. Found this out after going through 4 radiator caps. Only downside to the koyo is that it doesn't have the internal trans cooler. So there will be an extra cost.
Either way I don't regret the koyo at all. I know it's reliable, the fit is always amazing (I have a few koyo's in my cars). Also I do believe (I could be wrong) the koyo is a triple pass radiator (down up down or up down up), which is amazing at the price point the koyo is at. It would be even better if someone made a triple pass cross flow copper radiator, but I'd guess it would be in the 1k to 2k price range lol.
There's danger lurking around every corner, that's why I propose we make all of our buildings round.
I don't remember the time I was human that's why I don't understand anybody.
2TH4IST is offline   Reply With QuoteReply With Quote
Old 01-13-2025, 12:17 PM #26
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Good to know.. :-) Thanks for the information as the aftermarket densos seem to be getting quite sketchy in quality. Especially the ones made in China...:-(
air , due , flow , koyorad , radiator
Aluminum Radiator? thebrandon 3rd gen T4Rs 25 12-24-2022 02:22 AM
Does Koyorad radiator (VH010665N) interfere with 4xInnovations front skid plate? RidingDirty 3rd gen T4Rs 1 12-08-2022 11:48 AM
Griffin Radiator - Combo Aluminum Radiator + eFan Conversion with Shroud JONBOY345 4th Gen T4Rs 3 08-25-2020 09:12 PM
Anyone using this aluminum radiator? mickeyt 3rd gen T4Rs 14 12-11-2018 04:06 PM
Koyorad A2581 Radiator for V8 cyber_ecco 4th Gen T4Rs 0 11-18-2017 01:45 AM
