Old 09-08-2023, 11:01 AM #16
Originally Posted by Romeo1 View Post
You should roll in a new thermostat to rule out issues. If I recall correctly, I think there's even a different thermostat that I suggested to be used for the supercharger application. The orientation matters. It's about 5 minute job.
Also, how does the condenser look? If it's beat up, that will impede airflow to the radiator.
If his Rad has 280k on it it’s time for a new Rad and a new fan clutch.
Old 09-08-2023, 12:33 PM #17
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
New rad every 10 years to avoid pink milkshake
Old 09-08-2023, 01:40 PM #18
phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future
Originally Posted by SocalRunner15 View Post
What gives? Is this normal on a supercharged rig? Or are temps way too high?
Temps should be rock solid around 190*F +/-3*F or so. Sounds like a thermostat installed upside down.
To be safe, get an OEM thermostat and install it with the jiggle valve at the 6 o'clock position (upside down from nearly every other engine - which is why so many mechanics get it wrong).
As others have said, fan clutch and radiator condition can also be a problem.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 09-08-2023, 01:42 PM #19
nissanh nissanh is offline
The ping happened in my 4afe 92 Corolla/prizm on load (30 MPH) for quite a some time and eventually it blew the head gasket between cylinders 3 and 4. Ping makes excessive pressures inside the combustion chamber and the weak spot will take the toll. I tried 91 octane but situation is the same. I might check the cat and thermostat. I am currently doing the HG in my car.
1990 3L Diesel Hilux LN 106; 1973 Ford Cortina XL
1992 4AFE Toyota Sprinter AE 91 (aka Geo Prizm)
1997 5vzfe 4Runner 4x4 (aka Hilux Surf)
2000 2uzfe 100 Series Land Cruiser
2021 Tacoma TRD Off-Road 4x4 6-speed
Old 09-08-2023, 03:46 PM #20
In my experience pinging will wreck a spark plug, crack the top ring-lan, or melt a hole in the piston before blowing a head gasket. Old antifreeze will rot a head gasket just like the wrong type will kill the water pump seal.
But, I guess anything is possible.
Old 09-08-2023, 08:56 PM #21
gamefreakgc's Avatar
Real Name: Jerod
gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of
Real Name: Jerod
So....i'm running down clues....Been looking at timing...coolant temps...
I just did a 500 mile trip from the bay area back to socal....one thing which concerned me was my coolant tempts. ECT on my obd was showing from 213 all the way to 221 Fahrenheit. The only time temps dipped to low 200s was when i turned off overdrive going up some big hills
This is almost all highway driving going 70-75-80 on the I-5 (mostly flat incline). Temps were from 92 all the way down to 70.
Radiator and fluid are new.....water pump was changed 25k ago by previous owner. No idea on the thermostat.
And could this be causing the intermittent ping under boost?
Yes that's too high. At 230 the needle moves towards the red area of the gauge. I think you found the anomaly causing the pinging as an engine running that hot won't like boost one bit.
326WHP 347TQ
Old 09-09-2023, 02:35 AM #22
SocalRunner15 SocalRunner15 is online now
SocalRunner15 is on a distinguished road
Just ordered 2 thermostats....the oem 180 one and a 170 one designed for the corolla. Going to compare/contrast and if they're both identical (forums say they should be)...then i'm going to install.
Have a strong feeling this (plus slightly dirty injectors) have been the cause..
4runner adventures continues
SocalRunner15 is online now   Reply With QuoteReply With Quote
Old 09-09-2023, 10:05 PM #23
Real Name: Jerod
Real Name: Jerod
You are in SoCal so this is probably a non-issue. I run the 170* thermostat as it hits up to 110 each year up here in Sacramento but it does affect the heater function in the winter. It drops the heater temps in the cab by 20 degrees. Probably not an issue but worth noting. I only notice it when I travel up in the Sierras in the winter snow and the coolant temperature doesn't get past 165 degrees on my scanner.
326WHP 347TQ
Old 09-11-2023, 02:48 AM #24
Ah this is great to know since i do spend some time in the sierras each year. That said....90% of my trips are in socal type weather....so the 170 should be gtg...
Old 09-12-2023, 04:52 AM #25
What are the typical temps that you see with you 170 stat?
Old 09-13-2023, 12:32 PM #26
I got the head gasket done with all OEM parts in the 4afe Corolla/prizm, and had the pistons (while in the cylinder bore) soaking in diesel for 2 weeks to remove carbon buildup around the piston rings. I did not do any cylinder head job, such as resurfacing the valve seats etc: After the HG job, I do not hear the ping any more on same driving conditions: 10 BTDC before and after the repair. Looks like weak compression would lead to ping as well. The car have good pulling power as well.
Old 09-16-2023, 09:07 PM #27
So went in and changed out the thermostat. The jiggle valve was in the wrong position causing the engine to run around 25 degrees hotter than normal (215-220 on a cool night at highway speeds).
Some people advised putting in a 170 thermostat (oem from a corolla) and i did that....the truck now runs at 175-180 temps (vs 185-190 for the oem 180 stat). I also ran some fuel injector cleaner through the system.
Right now, the ping is all gone....i'm going to keep testing and see if it comes back for any reason. Have a strong feeling it was caused by dirty injectors and 25 degree hotter engine temps...
Thanks again to everyone for all the help!
filter , fuel , gas , intermittent , throttle
Rebuilt motor, New Heads, Supercharger, and Ping 4runnerfiend 3rd gen T4Rs 24 09-23-2021 07:38 PM
Supercharger and 7th injector high-gear/low-rpm ping tyler_durden 3rd gen T4Rs 2 06-04-2018 01:46 PM
TRD Supercharger causing engine ping? nacho Classifieds - buy & sell (no commercial ads please) 0 04-29-2011 07:59 PM
2.65" Supercharger "anti ping pulley" for sale nacho Classifieds - buy & sell (no commercial ads please) 1 02-22-2011 12:15 AM
Ping: rowdymoose SubSonic Engines / Suspension / Wheels / Tires / Audio / Accessories 0 06-01-2009 03:29 PM
