Old 09-21-2023, 10:38 AM #1
98rennur4 98rennur4 is offline
Real Name: Brian
98rennur4 is on a distinguished road
Real Name: Brian
Wheel bearing noise?
I own a '98 Runner, 4WD, 3.4L, auto, 303K miles- I'm about to replace both CV axles, and I'm wondering if I should go ahead and replace the wheel bearings at the same time. The bearings are original I believe. I get a grinding noise when I corner moderately hard, in 2WD and 4WD. When I put it up on jacks, the front wheels do not have any side to side or top to bottom play. In the past 15 months I have replaced the steering rack, new tie rod ends, new control arms, new struts (Bilsteins), sway bar links, and UBJ and LBJ's. I hope the noise is in the CV axles, but I only like to replace things once.....
98rennur4 is offline   Reply With QuoteReply With Quote
Old 09-21-2023, 12:24 PM #2
Twisted Sid's Avatar
Twisted Sid Twisted Sid is offline
Twisted Sid has a spectacular aura about Twisted Sid has a spectacular aura about Twisted Sid has a spectacular aura about
I just did front bearings a little over a month ago and they acted the same way. 421k on the originals and they had no play when checking them but made noise in corners. Afterwards, noise is gone and it seems to not follow road groves like before. Wish I would have done them when they first started making noise.
'99 4Runner SR5: 5VZ, 2wd, AT, 400k+ club
'94 Pickup: 2wd, 22RE, 5spd, (3RZ swap in progress)
Front: Total Chaos Uniball Kit, Fox 2.5 8'' coilover
Rear: Deaver F67 Leaf Springs, Fox 2.0 14'' Reservoir Shocks, E-locker Axle 4.88 Gears 33x10.5 BFG ATs
Twisted Sid is offline   Reply With QuoteReply With Quote
Old 09-21-2023, 12:34 PM #3
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
If you decide to swap out your wheel bearings, the video @infamousRNR and I made will help you out.
Beware of letting shops do this job for you. It's pretty common they don't support the bearing properly when pressing in the hub and they screw up the bearing and dramatically shorten it's life.
axles , noise , replace , side , wheel
Noise After Wheel Bearing Replacement Devbot 3rd gen T4Rs 17 04-30-2023 03:43 PM
Wheel bearing noise? FortCollinsT4R 4th Gen T4Rs 3 03-27-2017 01:03 AM
Wheel bearing or tire noise? freeflight 4th Gen T4Rs 12 09-21-2015 03:19 PM
Wheel bearing noise or tire noise? AndyFromWI 3rd gen T4Rs 3 04-23-2014 12:55 PM
