Old 09-24-2023, 04:26 PM #1
Brandt Brandt is offline
Real Name: Brandt
Brandt is on a distinguished road
Real Name: Brandt
What does this wire go to?
Hey y'all,
I'm toward the end of the months' long saga of replacing my 5vz. Installation of the new engine is next weekend, and I've discovered that a connector was pulled off of a wire. Connector is circled in the lower right corner of the image. Could someone please help me identify where this goes so I can order a replacement?
https://imgur.com/a/aHuCMfa
Oddly, I can't get the image to show up in the post, so a link will have to do
Brandt is offline   Reply With QuoteReply With Quote
Old 09-24-2023, 09:20 PM #2
Real Name: Brandt
Real Name: Brandt
Thanks Brillo!
So, to clarify, is this the oil temp sensor connector?
Old 09-24-2023, 09:43 PM #3
Real Name: Brandt
Real Name: Brandt
Hm. I'm not able to get any hits for 5vz "ecu temperature sensor". Everything I find points to the coolant temp sensor. Would they use the same type of connector? If so, my real issue is solved.
Old 09-25-2023, 12:03 AM #4
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light
TheDurk's Avatar
There are two coolant sensors. One goes to the ECU. The other goes to the temp gauge. Plus one on the transmission (slush box only).
The ECU one is this puppy here:
1991-2010 Toyota Engine Coolant Temperature Sensor 89422-35010 | Toyota Parts
[Incorrect info deleted. See newer post downthread.]
Please, ALWAYS give your year, engine, and 4WD/RWD and auto/5SP when requesting wiring help. Without that, anything I give you could be wrong. A close-up of the end of the subject plug would also have been real helpful.
My Backyard Frame Swap
Old 09-25-2023, 01:11 AM #5
Real Name: Brandt
Real Name: Brandt
Thanks for the clarification, TheDurk.
The ECT/ECU Temperature Sensor naming difference was throwing me off. But it does sound like we are talking about the same thing.
You're right, I neglected to provide those details. 99 5VZ 4wd 5sp. I'll remember for next time.
Unfortunately, it's the end of the plug that was ripped off and I'm trying to repair. I can't find the original, (lost amidst other components, I suspect) so I'm hoping that the photo of a stock harness would provide enough context.
Thanks again to both of you.
Old 09-25-2023, 09:45 AM #6
Real Name: Brandt
Real Name: Brandt
You're good, mate. I just didn't realize they were the same sensor.
Cheers!
Old 09-25-2023, 02:57 PM #7
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Now I feel the need to chime in. The ECU coolant temp sensor comes off the passenger side of the harness. What the OP has circled is the driver side of the harness. Based off my examination, that plug that is circled goes to the front differential actuator.
Old 09-25-2023, 03:07 PM #8
That looks right. Very easy to miss when pulling a motor since it is so far down there.
edit to clarify: That is for the ADD position switch, not the the ADD VSVs that are up on the inner fender.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 09-25-2023, 05:16 PM #9
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Yep, that plug is very easy to miss.
When I looked at the comments to the OPs question, I was like HUH? The ECT (Engine Coolant Temp) sensor plug comes off the harness on the passenger side and the plug the Op circled is clearly on the driver side all by itself. On the passenger side, the Knock Sensor plug and the ECT plugs are right next to each other.
Old 09-25-2023, 11:17 PM #10
Real Name: Brandt
Real Name: Brandt
I see references to "T" tab and Split tab variants of this connector. Does anyone know whether there is a universal connector available for this repair?
Old 09-26-2023, 01:06 PM #11
There's a small sub harness between the position switch on the ADD actuator (on the tube coming off the front diff towards the passenger side). You just need to repair that sub harness. Do it while the motor is out, otherwise access is very difficult.
I had damage in that same area on the parts truck that I got all my 4WD swap parts from (damaged by previous owner who took the engine - I wanted the rest of the truck for the 4WD parts...).
Old 09-27-2023, 12:32 AM #12
Real Name: Brandt
Real Name: Brandt
Unfortunately, I don't have any closer photos, or from a different angle. The challenge I'm faced with is that the connector was pulled from the wire and I'm unable to find where it ended up. So I have no direct comparison to find a matching replacement part. If I had that part, I'd probably just relieve the pins and pull them out, then re-terminate the cables and reuse the connector.
I did find this ebay auction. 4Runner ADD Differential Disconnect Vacuum Switch Valve CONNECTOR PLUG Pigtails | eBay
I wonder whether the t tab variant could be considered universal.
Any feedback on this?
Old 09-27-2023, 01:47 AM #13
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Start watching this video at play time 26:25 to see how to access that wiring haness on the top of the differential that got damaged. You just have to disconnect the breather hose from the driver side fender well, disconnect the two vacuum lines at the switching valves on the driver side fender, disconnect the electrical connector at the ADD actuator and then take out the two bolts.
Old 09-27-2023, 02:01 AM #14
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Originally Posted by brillo_76 View Post
Yup I was wrong. It's the front fender that Charlie clarified. I thought the ecu coolant came off the passenger side of the injector harness not drivers.
That definitely needs corrected on the on this thread.
Huh? What do you mean it's the front fender that Charlie clarified? Maybe you missed my comment. I identified for the OP that the damaged connector goes to the ADD actuator on the front differential. Charlie confirmed what I said. What Charlie said is it's NOT one of the connectors for the vacuum switching valves on the driver side fender well.
The ECU coolant temp sensor DOES come off the passenger side of the engine wiring harness, not the driver side.
Dude, what have you been smoking? Let me know because I'd like some so I could do some hallucinating as well.
Old 09-27-2023, 08:59 AM #15
Real Name: Brandt
Real Name: Brandt
I think caused confusion with the photo link. The photo isn't of my specific harness, it's just an example photo for illustrative purposes. My wires aren't cut after the connector joint as in the photo. The connectors were disconnected during removal prep, and the part of the connector that was on the harness side is what was pulled off the wire. So one half of the connector is still on the car, and the other is missing.
identify , oddly , order , replacement , wire
Adapting a 3-wire gear driven VSS to a 2-wire electronic VSS harness? derekwilliams345 3rd gen T4Rs 10 01-11-2021 02:11 PM
Help, need to tab speed wire and ign wire behind dash Lawrence_Liang 5th gen T4Rs 5 01-19-2018 07:54 PM
Cigarette lighter wire tap - wire location? Nashvegas34 3rd gen T4Rs 7 03-03-2012 10:52 PM
How to wire speakers? Directly from amp or back to HU through stock speaker wire Woody17 Engines / Suspension / Wheels / Tires / Audio / Accessories 14 04-18-2009 07:36 PM
