Originally Posted by alumarine
I removed the intake manifold on my 2000 5VZ-FE 3.4
I want to check the compression before putting things back together.
Can I just disable the fuel pump and crank it with a key?
thanks
btw thanks to Tim the Toolman, his video helped a lot.
That should be ok. Pull the ECU fuse also.
You don’t have to block open the throttle plate if it’s not there.
