Old 10-13-2023, 10:15 AM #46
lucidberries lucidberries is offline
lucidberries is on a distinguished road
Originally Posted by Bad Luck View Post
I just noticed your from BC. I have no clue how much you have to deal with rust, but I have seen problems with rust on axle/hub faces causing wheels/rotors/drums to not seat perfectly causing them to wobble. Might be something worth checking to see if where the axle shaft and drum touch is free of rust/debris buildup. There's also a very slim chance your axle shaft could have bent at the end causing a similar effect, but I would expect that to have made noise prior to drum replacement. Hopefully you can figure it out soon and make sure to let us know the results!
Not much rust at all on this rig luckily but I will add this point to the list.
I will keep yall updated here
lucidberries is offline   Reply With QuoteReply With Quote
Old 09-02-2024, 12:53 PM #47
It's been a while but dropping an update.
The grinding is still there, and I'd say a bit worse even. The issue is it only starts to grind (rotational) after I have been driving around for a while, so the mechanic thinks am crazy. It is 100% the rear brakes.
I drive so infrequently that's why I have not dealt with this more promptly
bit , drums , noise , rear , rotational
Trying to track down a rotational grinding noise Dirtrider216 4th Gen T4Rs 11 09-11-2019 08:59 AM
Grinding Noise Rear Wheel 4x4 3rd Gen? RunnerLimited 3rd gen T4Rs 0 10-24-2014 07:23 PM
Question on Rear Drum Grinding Noise kmiller93 3rd gen T4Rs 8 05-16-2013 04:28 PM
Metallic, rotational clicking, right front wheel, brakes? l Runabout36 4th Gen T4Rs 5 03-27-2013 11:05 AM
grinding noise coming from rear end sloopy 3rd gen T4Rs 15 11-07-2005 12:56 PM
