Old 10-08-2023, 02:56 AM #1
SpookyMulder's Avatar
SpookyMulder SpookyMulder is offline
SpookyMulder is on a distinguished road
Constant Clicking Sound After Brake Pad Replacement
Hey everyone, itís been a long time since posting here but the tracking of wheel well noises calls for your help!
So, my passenger side brake pads started squeaking when braking last week and I went ahead to replace them today with Wagner thermoquiet pads. Getting on the road to test everything out tonight I immediately notice an equally annoying constant clicking noise coming from the passenger side. The clicking doesnít stop when braking and it seems to match its RPM to my speed. Has anyone come across this after changing brake pads or in general? The Wagner brake pads were advertised as not needing the shims which I didnít reinstall if that could be related. But the issue isnít present on the driver side.
Any pointers or ideas would be greatly appreciated!
SpookyMulder is offline   Reply With QuoteReply With Quote
Old 10-08-2023, 08:07 AM #2
JoeT4R's Avatar
JoeT4R JoeT4R is offline
JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light
JoeT4R's Avatar
I'd recommend adding the shims in there just to see if it prevents the clicking sound. It seems to be like something is sticking or poking out of place or maybe even experiencing some slight movement back and forth. Add the shims back and take it for a test drive and update us then.
Old 10-08-2023, 12:00 PM #3
WayneM WayneM is offline
WayneM is on a distinguished road
Is the spring clip rubbing on the disk?
WayneM is offline   Reply With QuoteReply With Quote
Old 10-08-2023, 12:18 PM #4
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I doubt it the dust shield hitting the rotor as that be constant. Very good call on clip as they can tick if not snapped in place.
Old 10-09-2023, 01:54 AM #5
Thanks for the advice guys. Luckily I kept the shims and after reinstalling both with a bit of silicone brake grease the issue seems to be resolved. Iíll give it a test drive again tomorrow but fingers crossed I wonít have to worry about any strange sounds on my 1000 mile journey to Utah this week 🤣 So for anyone installing Wagner TQ brake pads Iíd recommend using the original shims as well!
Old 10-09-2023, 05:23 PM #6
So Many Roads's Avatar
So Many Roads So Many Roads is offline
So Many Roads is on a distinguished road
I notice my CV axles click at full droop when I spin the front wheels (when on jack stands.) Possibly a bad cv axle?
'99 SR5, 5 spd, Bilstein 4600, elocker mod, TBU
So Many Roads is offline   Reply With QuoteReply With Quote
Old 10-09-2023, 07:06 PM #7
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
You brought up what I was going to mention. CV axles click when they go bad. A dead give-away is making really tight turns, like making tight circles in a parking lot. If it's clicking bad on a left turn, it's the right CV axles that is bad. If it's clicking bad on a right turn, it's the left CV axle that is bad. The reason is, the outside wheel is turning faster and getting the most load on it weight-wise, because the weight of the vehicle is transferred to the outside of the turn.
brake , clicking , constant , pads , side
2002 strange sound then lights and constant beep. wrpsuite 3rd gen T4Rs 0 03-30-2014 01:20 PM
Clicking Sound Near Brake Fluid Reservoir? dbsoundman 3rd gen T4Rs 5 01-13-2013 10:04 PM
wheel bearing replaced-now constant scraping sound over 7mph up to 25 mph Headly 3rd gen T4Rs 3 06-11-2010 08:03 PM
Clicking Sound subzero Maintenance/Detailing 1 12-07-2006 02:37 PM
