10-12-2023, 03:13 PM
#31
Originally Posted by Option01
Oh dang, sounds like OD off is pretty much good for everything when traveling a consistent incline. Any idea if ECT does any good or harm in that situation? Since I re-geared to 4.88, I've been thinking of leaving it on all the time since it feels a little better when accelerating from a stopped position (it feels like it jumps into 2nd gear a little too quickly and ECT seems to help a bit with that).
BTW, thank you again for all you super-informative answers! Without helpful people like you and the other posters on this forum, I'd probably be dealing with a busted transmission in the near future.
From a transmission longevity standpoint, it won't make much difference either way. Many on here drive in "power" mode all the time.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
10-12-2023, 05:03 PM
#34
@ phattyduck
or anyone else, Is there a definitive consensus on what exactly the ECT does? It obviously raises shift rpm's, but does it change the torque converter lock up strategy? Does it change anything else like say fueling tables or anything if the sort?
I want to say in the several hours I've spent searching that topic, I think there's only one thread that actually goes into it specifically. I should have probably booked marked it....
99’ Black “Highlander” sport, oak, 5VZ auto, 4.30 axle, e-lock, 265/75 Grabber X3,, Bilstein 6112 (2”) front 5160 rear shocks, OME 2906 springs, Durobumps, 4x Inovations front middle rear skid plates, 4XI square TRD tube sliders, lil skips tank skid, lotus dev RCA skids, overland custom sway bar links, Amp’d hidden winch, warn Vr Evo 10s
10-12-2023, 06:28 PM
#35
Originally Posted by IconicFJ_
Oh man, I really like your kit but it looks like it might not fit on my 4runner as my bumper overlaps the rail that the lower section of your bracket attaches to. Or am I maybe looking at it the wrong way?
1999 SR5 V6/Auto 4WD
4.88 Gears, Front/Rear E-Lockers
1" Body Lift, 2" Suspension Lift, 285/75 R16 Tires
10-12-2023, 08:53 PM
#36
Real Name: Mark
Real Name: Mark
Was looking at pic you really should clearance the cutout around freon line or bend line.
Condenser flex's with body bumper rigid with frame it will rub a hole in the line.
10-12-2023, 09:18 PM
#37
Real Name: Mark
Real Name: Mark
Originally Posted by mtbtim
I was actually thinking of cutting holes in my front skid plate and the bumper itself to increase air flow, but I'm leaving that as a last resort until I see how well the Koyorad aluminum radiator performs in adverse conditions.
Best way to go about it if you want to find out cause and effect of mods.
OE skid covers 1" of fins and bottom cap right at 3" of radiator noticed temp difference with it off.
OE skid better than nothing and it's enough for wheeling I do.
10-13-2023, 07:46 AM
#38
Thanks! Yes you are correct, my bracket won't work with that bumper. Is it a Coastal Offroad?
10-13-2023, 02:09 PM
#39
Originally Posted by Romeo1
@ phattyduck
Shift points, mainly. It *might* have a slight effect on lockup, but its minor. Absolutely no change in fueling or timing tables for the engine.
10-13-2023, 02:13 PM
#40
Where there's a will, there's a way. Grinder to the bumper, mount the cooler on the back side, spacers as needed, etc. There's plenty of room left in there for a trans cooler.
I custom mounted my cooler - it sits behind everything, right next to the AC condenser so the fan pulls as much air through it as possible. Modified the upper and lower condenser mounts, etc. I also used a thermostat on the cooling system to minimize overcooling in the winter. There's now a winch control box in there, and it all still fits...
10-13-2023, 02:42 PM
#41
That cooler looks like it was from my cummins……
10-13-2023, 04:40 PM
#42
Real Name: Mark
Real Name: Mark
No truer words my dad started saying that when I was around 10 yrs old, along the way I added no risk it no biscuit.
10-15-2023, 08:20 PM
#43
Yes it is. They make 2 versions for the 3rd gen 4runner and I got the one that is extra low-profile. Their other bumper might have more clearance.
10-15-2023, 08:24 PM
#44
Oh wow, I really like how your cooler is shorter but goes all the way across. Can you tell me what kind of cooler that is?
Also, I assume you do not have a Coastal Offroad bumper? It seems like it will be a very tight fit to get both a cooler and a winch to fit in mine.
10-16-2023, 01:43 PM
#45
Real Name: Robert');DROP TABLE Students;
It'll go but it's a fight. I've got a lot of snakeskin and cut up fuel hose in there to prevent chafing.
2001 SR5 - Like OEM, only worse (gears, e-locker, armor)
