Old 10-11-2023, 12:38 PM #1
WrenchTech's Avatar
WrenchTech WrenchTech is offline
Real Name: Matt S.
WrenchTech is on a distinguished road
WrenchTech's Avatar
Real Name: Matt S.
Back Window Rolls Down on its Own at Random Times
My back window, the one in the tailgate, has a mind of itís own lately. The problem is that it rolls down on its own a random times. I rolled it up twice yesterday and found it rolled down an hour later both times. This condition seems to be affected by the sun. When it is cold and cloudy it happens much less.
When I bought the 4runner the window didnít work work at all. The owner told me the window regulator box needed to be replaced. I picked one up at a pull-your-part wrecking yard for $25. When I took the interior cover panel off of the tailgate I found that the box was unplugged. I replaced that box with the one I purchased, buttoned things up, and was pleased to have a working window.
That was when the window started its random operation. It then made sense to me that the former owner had left the box unplugged because he was probably experiencing the same problem.
The problem gets worse when the sun is shining on the tailgate warming it. It will also do it when I open or close the tailgate. This make me think that the problem is due to a fault in the wiring.
So the question is do I have two control boxes with the same problem, or is the problem due to something else, like a short in the wiring?
1999 SR5 3.4 auto, Horizon Blue Metalic 8N1, blue cloth, steel Daytona wheels, 265/75/16 AT tires, rear heat, A/C, sunroof, electric locking rear dif.
WrenchTech is offline   Reply With QuoteReply With Quote
Old 10-11-2023, 01:02 PM #2
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
You probably have partially severed wires going from the body to the hatch. You need to investigate. This video will help you out.
Old 10-11-2023, 01:02 PM #3
Sarki Sarki is offline
Sarki has a spectacular aura about Sarki has a spectacular aura about
More than likely the wiring harness for your tailgate has some cracked/broken wiring, not uncommon after many years of opening & closing the tailgate.
Fortunately there’s a video made by Timmy the Toolman that addresses this exact issue.
Rear Hatch Wiring Repair (3rd Gen 4runner) - YouTube
2002 SR5 Sport 4WD
Sarki is offline   Reply With QuoteReply With Quote
Old 10-11-2023, 01:04 PM #4
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Fortunately thereís a video made by Timmy the Toolman that addresses this exact issue.
I guess I just beat you with my post. Thanks for mentioning my video.
Old 10-11-2023, 02:15 PM #5
Tim your videos have helped and encouraged me countless times and I appreciate all the time and effort you put into this site to help the community.
2002 SR5 Sport 4WD
Old 10-12-2023, 12:39 PM #6
WrenchTech's Avatar
Real Name: Matt S.
WrenchTech's Avatar
Real Name: Matt S.
Thanks to everyone for pointing me in the right direction on this issue. I am amazed again at the richness of Timmy the Toolman YouTube video resource.
Old 10-12-2023, 01:29 PM #7
Jakeepoo3's Avatar
Jakeepoo3 Jakeepoo3 is offline
Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about
Jakeepoo3's Avatar
Sounds like a circuitry issue. Can you recreate the problem by your own will? If so put a test light or multimeter on the connector to that controller box. That's if you don't see the problem in the harness boot. Someone the other day had a similar problem with battery voltage pulsating at that connector.
Jakeepoo3 is offline   Reply With QuoteReply With Quote
Old 10-12-2023, 03:00 PM #8
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
I had a similar problem with my first 4Runner. I would come out to the rear window being rolled down with no rhyme or reason. I thoroughly inspected the wiring harness between the body and rear hatch but never found any problems. What fixed it for me was gluing the rear hatch button part of my key fob to where it couldn't depress at all. Maybe it was a coincidence, but it never happened again for the 15 months after I did that until I sold that 4Runner.
Old 10-12-2023, 09:05 PM #9
sportscarfan's Avatar
sportscarfan sportscarfan is offline
sportscarfan will become famous soon enough
Whenever this topic comes up I repost my experience - (not broken wiring, not control box)
https://www.toyota-4runner.org/1471503-post5.html
'97 SR5 V6 4x4 | 5-speed | e-locker | 33's
sportscarfan is offline   Reply With QuoteReply With Quote
Old 10-12-2023, 09:26 PM #10
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
@WrenchTech I had wires broken and not the insulation, diagnosing not always cut n dried easy to see.
@Bad Luck had pocket lint build up in fob buttons cause stuff.
box , problem , tailgate , times , window
Rear window only rolls down Cletus4runner1997 3rd gen T4Rs 4 04-01-2022 01:52 PM
Rear Window Rolls Down On It's Own... trevo_man 3rd gen T4Rs 3 10-23-2016 12:06 PM
rear window rolls up and then stops and rolls back down about 1/4 way from top kjhalley New Members 1 04-22-2015 02:11 PM
Window rolls up then back down spoiler900 3rd gen T4Rs 3 11-25-2011 10:02 PM
Alarm sounds of at random times. txzaphod Engines / Suspension / Wheels / Tires / Audio / Accessories 1 01-16-2006 03:07 PM
