Old 10-11-2023, 12:38 PM #1
WrenchTech's Avatar
WrenchTech WrenchTech is offline
Real Name: Matt S.
WrenchTech is on a distinguished road
WrenchTech's Avatar
Real Name: Matt S.
Back Window Rolls Down on its Own at Random Times
My back window, the one in the tailgate, has a mind of it’s own lately. The problem is that it rolls down on its own a random times. I rolled it up twice yesterday and found it rolled down an hour later both times. This condition seems to be affected by the sun. When it is cold and cloudy it happens much less.
When I bought the 4runner the window didn’t work work at all. The owner told me the window regulator box needed to be replaced. I picked one up at a pull-your-part wrecking yard for $25. When I took the interior cover panel off of the tailgate I found that the box was unplugged. I replaced that box with the one I purchased, buttoned things up, and was pleased to have a working window.
That was when the window started its random operation. It then made sense to me that the former owner had left the box unplugged because he was probably experiencing the same problem.
The problem gets worse when the sun is shining on the tailgate warming it. It will also do it when I open or close the tailgate. This make me think that the problem is due to a fault in the wiring.
So the question is do I have two control boxes with the same problem, or is the problem due to something else, like a short in the wiring?
1999 SR5 3.4 auto, Horizon Blue Metalic 8N1, blue cloth, steel Daytona wheels, 265/75/16 AT tires, rear heat, A/C, sunroof, electric locking rear dif.
WrenchTech is offline   Reply With QuoteReply With Quote
Old 10-11-2023, 01:02 PM #2
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
You probably have partially severed wires going from the body to the hatch. You need to investigate. This video will help you out.
Old 10-11-2023, 01:02 PM #3
Sarki Sarki is offline
Sarki has a spectacular aura about Sarki has a spectacular aura about
More than likely the wiring harness for your tailgate has some cracked/broken wiring, not uncommon after many years of opening & closing the tailgate.
Fortunately there’s a video made by Timmy the Toolman that addresses this exact issue.
Rear Hatch Wiring Repair (3rd Gen 4runner) - YouTube
2002 SR5 Sport 4WD
Sarki is offline   Reply With QuoteReply With Quote
Old 10-11-2023, 01:04 PM #4
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
I guess I just beat you with my post. Thanks for mentioning my video.
Old 10-11-2023, 02:15 PM #5
Tim your videos have helped and encouraged me countless times and I appreciate all the time and effort you put into this site to help the community.
2002 SR5 Sport 4WD
Old 10-12-2023, 12:39 PM #6
WrenchTech's Avatar
Real Name: Matt S.
WrenchTech's Avatar
Real Name: Matt S.
Thanks to everyone for pointing me in the right direction on this issue. I am amazed again at the richness of Timmy the Toolman YouTube video resource.
Old 10-12-2023, 01:29 PM #7
Jakeepoo3's Avatar
Jakeepoo3 Jakeepoo3 is offline
Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about
Jakeepoo3's Avatar
Sounds like a circuitry issue. Can you recreate the problem by your own will? If so put a test light or multimeter on the connector to that controller box. That's if you don't see the problem in the harness boot. Someone the other day had a similar problem with battery voltage pulsating at that connector.
Jakeepoo3 is offline   Reply With QuoteReply With Quote
Old 10-12-2023, 03:00 PM #8
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
I had a similar problem with my first 4Runner. I would come out to the rear window being rolled down with no rhyme or reason. I thoroughly inspected the wiring harness between the body and rear hatch but never found any problems. What fixed it for me was gluing the rear hatch button part of my key fob to where it couldn't depress at all. Maybe it was a coincidence, but it never happened again for the 15 months after I did that until I sold that 4Runner.
Old 10-12-2023, 09:05 PM #9
sportscarfan's Avatar
sportscarfan sportscarfan is offline
sportscarfan will become famous soon enough
Whenever this topic comes up I repost my experience - (not broken wiring, not control box)
https://www.toyota-4runner.org/1471503-post5.html
'97 SR5 V6 4x4 | 5-speed | e-locker | 33's
sportscarfan is offline   Reply With QuoteReply With Quote
Old 10-12-2023, 09:26 PM #10
96RedRunner's Avatar
Real Name: Mark
96RedRunner is a splendid one to behold 96RedRunner is a splendid one to behold 96RedRunner is a splendid one to behold 96RedRunner is a splendid one to behold 96RedRunner is a splendid one to behold 96RedRunner is a splendid one to behold
Real Name: Mark
@WrenchTech I had wires broken and not the insulation, diagnosing not always cut n dried easy to see.
@Bad Luck had pocket lint build up in fob buttons cause stuff.
Old 08-28-2024, 04:02 PM #11
Brakleen Sniffer Brakleen Sniffer is offline
Real Name: Dave
Brakleen Sniffer is on a distinguished road
Real Name: Dave
I really fixed it!
My 2000 4Runner started randomly rolling the rear window down by itself. My version of this problem also disabled window up/down from the tailgate key switch, and also disabled the rear wiper, so I couldn't just disconnect the window motor. Not that I was willing to do that anyway.
tl;dr A new rear window switch assembly fixed the problem. p/n 84830-35041. This is the electrical switch piggybacked onto the tailgate key lock cylinder.
First, know that the Toyota service manual has many errors. Test voltages listed for the rear ECU are wrong, there are wires in the tailgate that are not shown in the manual, and the descriptions of how things are supposed to work are very poorly written (or translated?). So those things made it hard to know WTH to look at.
- I checked the wires in the tailgate flexy boot - not the problem.
- I tried a new used rear ECU. No.
- I pulled the ECU PC board and tested it on the bench. Applied 14V and ground and all other pins floating. Works: up and down relays click when pins 9 and 10 are grounded.
- Reinstalled the ECU in the vehicle with all tailgate motor and sensor connectors open. Works, so the problem must be one of them, and the problem is not bad data coming down the MPX serial data wire from the body ECU.
- Reconnect connectors one at a time, and failure occurred when I clicked the key lock switch connector into place.
- Turns out that there was an 80 ohm "short circuit" in the switch between the "window down" wire and ground. Evidently this confused the ECU. To check this, pull the ECU connector and on the wiring bundle measure pin 9 to ground and 10 to ground. Don't do it with the connector installed because there's power applied to the ECU full-time, which may confuse the ohmmeter.
Like all completed troubleshooting, this sounds easier than it was. There's the physical difficulty of reaching some of the electrical connectors, the misleading service manual, too many things to check, and my short attention span which caused me to jump around instead of pursuing each clue.
I hope this helps someone. It was therapeutic to write.
Brakleen Sniffer is offline   Reply With QuoteReply With Quote
Old 09-01-2024, 09:59 AM #12
Malcolm99's Avatar
Malcolm99 Malcolm99 is offline
Malcolm99 has a spectacular aura about Malcolm99 has a spectacular aura about
Malcolm99's Avatar
Like Brakleen, the key switch has full time power, if it is compromised, any excessive moisture will roll the window down on its own.
Malcolm99 is offline   Reply With QuoteReply With Quote
Old 09-01-2024, 04:20 PM #13
That's a good theory. That explains why the once or twice it has happened to me it was also (luckily lightly) raining.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 09-02-2024, 05:20 PM #14
Real Name: Dave
Real Name: Dave
No doubt moisture could cause this. The switch has an O-ring that’s supposed to keep the contacts clean, but eventually everything leaks.
The green disk is keyed to the back of the lock cylinder and rotates to connect the up and down wires to ground.
FWIW, in my switch the short circuit was in the sealed part of the switch. It was there even after disassembly and cleaning.
Back Window Rolls Down on its Own at Random Times-img_3812-jpg  Back Window Rolls Down on its Own at Random Times-img_3815-jpg
box , problem , tailgate , times , window
Rear window only rolls down Cletus4runner1997 3rd gen T4Rs 4 04-01-2022 01:52 PM
Rear Window Rolls Down On It's Own... trevo_man 3rd gen T4Rs 3 10-23-2016 12:06 PM
rear window rolls up and then stops and rolls back down about 1/4 way from top kjhalley New Members 1 04-22-2015 02:11 PM
Window rolls up then back down spoiler900 3rd gen T4Rs 3 11-25-2011 10:02 PM
Alarm sounds of at random times. txzaphod Engines / Suspension / Wheels / Tires / Audio / Accessories 1 01-16-2006 03:07 PM
