10-12-2023, 04:03 PM
3rd Gen Transmission Cooler Kits
Hey guys, I'm coming over here from the FJ Cruiser Forums. I have recently purchased a '96 4runner and am increasing my product lines to include 3rd gen 4runners as well. My goal of my entire business is to reduce lead times and give the DIY'ers the ability to complete mods at a low price. Currently all my products are in stock and ship the following day. This includes the weld it yourself bumper kits. I'm trying to get the word out to the 4runner guys about these transmission cooler bracket kits and also my future 4runner front bumper weld it yourself kits.
My most popular product by far are the automatic transmission cooler kits. These make installs a breeze and reduce the ATF temps to allow your transmission to last longer. I would recommend this for any 4runner but especially for those who have oversized tires, drive aggressively, tow, or want to bypass the small factory cooler in the radiator that is prone to failing and causing damage. Automatic transmission fluid lifespan is primarily effected by temperature, any time it goes over 210 degrees you are reducing the life of the transmission.
1996-2002 4runner Transmission Cooler Bracket Kit
– Iconic Fabrication
10-12-2023, 04:21 PM
Real Name: Tim
Real Name: Tim
Maybe we could partner up and make a video install of your product to help promote it. No promises, but I think my buddy Sean and I could make it happen.
10-12-2023, 04:52 PM
You should think of making brackets for the BM 70264 and TrueCool 4589 trans coolers as well.
10-12-2023, 05:08 PM
Real Name: Patrick
Real Name: Patrick
I agree with the above. I used a TruCool 4589 on my first 4Runner as a standalone to bypass the radiator cooler.
10-12-2023, 11:05 PM
Why doesn't the hayden 699 model have a bracket?
10-14-2023, 11:53 AM
Real Name: 3 Bears
Real Name: 3 Bears
lloks nice, whish it was around when I installed mine, much cleaner
10-15-2023, 06:47 PM
Real Name: Blair
Real Name: Blair
Wish I had used brackets but I was in a hurry and used the zip-tie system that came with my Tru-cool. No problems 2+ years later.
10-16-2023, 08:13 AM
Of all the coolers I’ve installed using the zip method if never had one fail or rub through the condenser.
10-16-2023, 09:38 AM
can the bracket be also used on the RH side?
10-16-2023, 09:56 AM
I highly doubt it. I'll take a look later and if it does I'll let you know. If you wanted to drill some holes it could definitely fit.
My brackets only fit the Hayden 678, 698 and Derale 13613 coolers. The Hayden 699 has a much larger footprint than the coolers I sell.
11-03-2023, 09:09 AM
Bump, ready to ship!
11-13-2023, 06:24 PM
Still available!
02-22-2024, 11:16 AM
These 3rd gen kits are my best seller!
03-01-2024, 10:02 PM
wish these were offered for the bm 70268 cooler!
00' 4Runner Limited- Auto trans, E-locker, grey-wire mod, custom rock sliders, B&M 70268, TRD exhaust tip, 285/75/16 Duratracs
R.I.P 99' 4runna- auto trans, 4wd, tacoma whip mod,B&M 70768 tranny cooler, 265/75/16 Cooper Discoverer at3
03-01-2024, 10:12 PM
@ Joshv4runner
If you measure the bolt hole dimensions I'll tell you if my bracket can be made to work or not.
