Old 10-15-2023, 07:19 PM #1
hawkcharmer's Avatar
hawkcharmer hawkcharmer is offline
hawkcharmer is on a distinguished road
994R Stiff Steering until warm. Please help.
Hello,
I have a 99 4R that has stiff steering until warm or until I drive it and turn the wheel a few times.. It starts to happen when the temp is 50 degrees or colder.
I have replaced the steering rack and lines. Pump reservoir is clean as a whistle and has new o-ring, no leaks. All steering components are new and everything is oem. The stiff steering was prominent even with the old rack during fall/winter.
The fluid in pump reservoir is spinning/circulating slowly while engine is running, no bubbles. Im not sure how much it's supposed to spin. Any idea? Slow spin or hurricane?
New synth fluid, no squeals from belt. maybe a little at full lock once in a while.
Does anyone know what the problem is? Can it actually be the pump? The belt is working and fluid is circulating..
Any feedback is greatly appreciated.
Thank you
1999 4Runner SR5, 3.4L 5VZ-FE V6 | Tundra/890 coils | 5100 Bilsteins all around l 199mm Tundra brake upgrade | 265/75/16 Falken Wildpeak AT3 tires | ARB Bull Bar
hawkcharmer is offline   Reply With QuoteReply With Quote
Old 10-15-2023, 07:27 PM #2
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
It sounds like you've addressed everything possible other than the pump itself. It might be that the pump can't effectively move the fluid during colder conditions when the fluid is thicker.
Are using ATF for the fluid?
Old 10-15-2023, 07:35 PM #3
MaineRunna's Avatar
MaineRunna MaineRunna is offline
MaineRunna will become famous soon enough MaineRunna will become famous soon enough
MaineRunna's Avatar
It may be a bad pump, although they typically work or they don't. They fact that it squeals at full lock tells me the belt may be a little loose or worn out. Toyotas need their belts TIGHT. The PS belts on a lot of older Toyotas also don't squeal when they aren't tight enough for some unknown reason.
98 SR5 4X4 5spd, desert dune metallic, Toytech Eibach 3" lift, 1" body lift, RAD Rubber Designs splash guards, 4XInnovations bumpers, Doug Thorely Headers, Magna-flow converter, JBA muffler & tail pipe, RCI skid plate, SPC UCA's & rear LCA's, front sway bar links on rear, gen II rear links on front, Tundra brakes, '02 headlights, tail lights & sidemarkers, BFG 255/85R16 Mud Terrain T/A's 241,000 miles.
MaineRunna is offline   Reply With QuoteReply With Quote
Old 10-15-2023, 08:01 PM #4
Yes, using ATF Valvoline Fuel Synth
Old 10-15-2023, 08:02 PM #5
Hmmm... That belt has been on there for over 12 years. I'll look into this tomorrow.
Old 10-16-2023, 04:43 AM #6
JoeT4R's Avatar
JoeT4R JoeT4R is offline
JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light
JoeT4R's Avatar
Please provide an update when possible. Interested in hearing how this worked out for you
Old 10-16-2023, 06:16 AM #7
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
@hawkcharmer , mine doing same thing @ 30* and below. New rack 5k mi. system flush pump screen clean
Belt grooves cleaned scuffed with sandpaper new belt tension gauge adjusted regular ATF Pump @ 229k mi.
It the pump, check out FSM section SR-35 clearance's in the 10,000th inch range for Vanes and Shaft
cold thicker fluid slipping by. Doing it at 50* your closer to pump end of life than me I'm a 3rd coaster
I've got miles to go yet.
If belt is not loose.
belt , fluid , pump , steering , stiff
Replaced intermediate steering shaft, steering stiff again after 2 months twa318 4th Gen T4Rs 6 11-18-2022 10:44 PM
Stiff Steering t4rFL 3rd gen T4Rs 23 01-07-2019 11:18 PM
Stiff steering drallan 3rd gen T4Rs 9 07-10-2015 01:29 PM
Replace u-joint on steering linkage to fix stiff steering? sibanez 4th Gen T4Rs 2 09-30-2014 08:28 AM
Stiff Steering BigK75 4th Gen T4Rs 0 11-19-2009 11:33 AM
