Old 10-15-2023, 09:49 PM #1
Krommeweg's Avatar
Krommeweg Krommeweg is offline
Krommeweg is on a distinguished road
Krommeweg's Avatar
Time For New Suspension - what am I forgetting?
The time has come, whether I like it or not. Rear springs are sagged and shocks are barely starting to leak. Suspension is stock right now, with the factory lift springs. Like driving a soft mattress.
The Yota does miles on bad gravel roads and highway every day. Water crossings, washboard, loose gravel, deep snow, ice, and everything else you get in costal Alaska. Not to mention CaCl salt in the winter and something similar they spread on gravel in the summer to keep dust down. We periodically haul 500lbs in the back or tow as needed. It’s not unusual to be carrying 100 - 200lbs of diesel or food for the livestock on the ride home. Durability and control at speed on gravel are my top priorities.
If I can afford to add airbags in the rear, I will. Waiting to hear from Toytec about whether or not bags will fit with these springs.
Here’s what I’m thinking so far:
Bilstein 6112 kit assuming my top plates and isolater aren’t too corroded. Set at 1” lift
Bilstein 5160s in the rear
Toytec 9602HD for 3” lift
Or 9602RC with airbags
Stainless lines, ebrake extension bracket, weld-on Panhard drop bracket.
What do you think? Given that the welds are done properly, will the Panhard drop bracket be burly enough? Also planning to NOT install diff drop hardware on the front. Bump stops?
Does anyone use those Icon Coilover neoprene socks ? Goofy to be sure, but I’ll do what it takes to protect these shiny new parts.
Thank you for reading.
-- 1999 4Runner SR5, 3.4 5VZ-FE, A340E auto ~280,000 mi --
+ 265/75/16 Nokion hakkapeliittas > '01 Tundra brake swap (199m) > TRD 170 degree thermostat > Yukon axle shafts > Bilstein 6112s 600lb spring / 5100s and OME 890s > Airlift 1000 kit > Rear heater delete > Back seat delete
Krommeweg is offline   Reply With QuoteReply With Quote
Old 10-15-2023, 10:12 PM #2
the_welfare_wagon's Avatar
the_welfare_wagon the_welfare_wagon is offline
Real Name: Rich
the_welfare_wagon will become famous soon enough the_welfare_wagon will become famous soon enough
Real Name: Rich
The only help I can be is with the toytec springs, I got the HD and I will say that they are very nice. Mine has settled to 39.5" ground to flare so I think 3 inches of lift?? I have a hitch rack and putting 260lbs on that sagged the springs exactly one inch. Putting that weight in the back of the car sagged it only 1/4 inch but the weight was only on one side not in the middle. I have a back platform which is 70lbs and the hitch rack which is 50 and it doesn’t ride harsh at all unloaded.
Id also personally recommend the FJZ80 LC shocks if your gonna have weight. They are super cheap so you’d definitely save some money
The HD are 19.5” and 18.5” tall. Below is a pic of what I currently have in terms of lift from the HD springs and how they look compared to OME 890s. Keep in mind my tire is 33.5” tall so you’ll have more of a gap if yours are smaller
96 Limited: 380k+ 255/85s Geolander MTs, Ironman Nitro 2" lift, Toytec 9602HD W/FJZ80 Shocks
the_welfare_wagon is offline   Reply With QuoteReply With Quote
Old 10-15-2023, 10:25 PM #3
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Just to add a thought - changing the lift height will also change how the vehicle drives and feels. You may or may not like it since it is subjective. I've driven lifted 4Runners and personally didn't like it so I left mine at stock height but once again, that's me and this is you and your 4Runner. If you have a friend that owns a similar lifted 4Runner maybe ask if you can drive it and see what lift they went with. People love showing off their 4Runners.
Airbags by far are the best option for hauling and towing. I agree with the above poster - there are a lot of OEM Toyota parts that could be used to save some bucks to put towards airbags. Even 99 talls are a great option but I realize 1" lift may not be what you are after. A thought on the lines - if you live where salt is a real problem are there any brake line extensions that are rubber coated like the OEM lines? I have stainless steel lines on mine but I don't ever see salt on the road.
I think the one thing we can agree on is ANYTHING is better than the tired old suspension you've got right now!
326WHP 347TQ
Old 10-15-2023, 10:59 PM #4
Real Name: Rich
Real Name: Rich
Totally agree with the part about lifting changing the dynamic of the vehicle. If OP was to go with these springs you will definitely need the panhard correction but OP has already mentioned wanting it.
Also speaking on the panhard... dont skimp and get the cheap eBay panhard drops. Go with the Eimkeith even though it's slightly more expensive. SRQ has a discount code to bring the price down as well but there is definitely a difference in metal quality between them, just an additional .02
Old 10-16-2023, 07:14 AM #5
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
Bushings all of them. Do not use Moog.
I went Tundra 6112's LC 5160's with LC springs for the weight capacity.
Old 10-16-2023, 11:06 AM #6
alexperrucci's Avatar
alexperrucci alexperrucci is offline
alexperrucci will become famous soon enough
I 2nd the bushings comment. I've heard the coilover socks do a great job keeping them new looking and operating.
IG: @lowtege
alexperrucci is offline   Reply With QuoteReply With Quote
Old 10-16-2023, 11:43 AM #7
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
I did a 2.5 inch lift on one, it was ok..did the pan hard brackets and a diff drop.
my current is a factory highlander....so it has the talls on it...so 1 inch over "stock". Yes on air bags, they are a big help.
also...I think if your going over 2 inches you might need to change your rear sway bar links....and if you have a locker you may have to relocate the rear sway bar...I know sonoran steel sells those, ( sway brackets) cant rememebr at what height those are recomended
Old 10-16-2023, 01:26 PM #8
Real Name: Mark
Real Name: Mark
Sonoran Steel 1.2 3"F - 4"R kit came with diff drop & S/B raise pieces locker or not.
2008 word was 3-4" lift when you needed both, I use them on current 01 Runner 2.75"- 3" lift.
CV boots last longer locker parts hard or costly to come by. Both easy to make if on a budget.
Have all EimKeith stuff except bumper, Durabumps for bumpstops both good stuff.
Old 10-16-2023, 02:42 PM #9
Bushings, as others have said, along with new OEM (OEM ONLY!!!!) front lower ball joints.
Bump stops and any number of other things can be done piecemeal.
Also consider that Bilstein shocks have digressive valving - which is good for some things and worse for others. Spend some time reading before you commit. (I have 5100's all around, so they aren't a bad choice!)
Budget is also an issue.
Rather than socks and other stuff on the parts, how about an oil coating like fluid film to fight the salt?
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 10-16-2023, 05:58 PM #10
LostInNewtonCo LostInNewtonCo is offline
LostInNewtonCo is on a distinguished road
I’m not sure what all you’re forgetting, but I would look into what bushings come with the struts that you buy. Sometimes the 5100s are sent with bushings that have 1/2 inch inner diameter holes that don’t fit the bolts on the 3rd gen LCA. Just a thought. I’m fighting that now and can’t find the right replacement lower eye bushings for my front struts unless I buy the crappy rubber ones that last barely 10,000 miles before they are squished and ruined again. Looking for some good Polyurethane ones if anybody has a link.
LostInNewtonCo is offline   Reply With QuoteReply With Quote
Old 10-16-2023, 11:36 PM #11
Romeo1's Avatar
Romeo1 Romeo1 is offline
Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice
Romeo1's Avatar
A rear 3" lift spring will have all kinds of rake with the 6112 set at 1" height. Unless you're running a ton of gear, it'll be very raked. I still have lots of rake with a few hundred pounds of gear and 4-5 people.
I have a a fair amount rake with gear in it still running at the 2" setting and 2890 ome springs. I'll be going to 2.3" up front when it roll my new lower arms and jba uppers some time winter.
Your gonna love the shocks. Get durobumps at some point.
You'll have to address the sway bars at some point. There's a couple of ways to do that.
PCK is amazing. I should have done that way way sooner.
Lastly, air down! I air down to 15-18 psi when wheeling. It's a game changer, and the single greatest thing you can do for ride comfort, traction, and tire durability.
For max control on gravel at high speed, four wheel drive on, end of story. With thw swaybars dialed, a pan hard correction kit, and four-wheel-drive on you'll get to do high-speed gravel safely and with ease.
I was doing 55-65 on gravel today without a care in the world. So much much with the oversteer these 4Runners have around the corners. Need to fix my rear brakes though. My E brake turns are pretty sad since I ruined my rear pads.
99’ Black “Highlander” sport, oak, 5VZ auto, 4.30 axle, e-lock, 265/75 Grabber X3,, Bilstein 6112 (2”) front 5160 rear shocks, OME 2906 springs, Durobumps, 4x Inovations front middle rear skid plates, 4XI square TRD tube sliders, lil skips tank skid, lotus dev RCA skids, overland custom sway bar links, Amp’d hidden winch, warn Vr Evo 10s
Romeo1 is offline   Reply With QuoteReply With Quote
Old 10-16-2023, 11:42 PM #12
Romeo1's Avatar
Romeo1's Avatar
What are you going to run for tires?
Old 10-17-2023, 12:04 AM #13
Krommeweg's Avatar
Krommeweg's Avatar
I just happen to have all my OEM suspension bushings ready to go, and I did all four front ball joints, links and bar bushings 18 months ago, OEM. Should I do them again, or stick to the every 50,000 miles rule? Money is no object when it comes to avoiding blowing a ball joint on the highway in the winter.
Fluid film! That's a great idea. I use that stuff on the tractor and snowblower... and everything else. Thank you for the reminder.
Old 10-17-2023, 12:14 AM #14
Krommeweg's Avatar
Krommeweg's Avatar
I'm not afraid of the rake... but if I could find a variable rate heavy duty 2" lift spring in the rear, I would be happy. I could not care less about how goofy I look, and the tiny change in ground clearance from a higher front lift isn't worth the wear and tear on driveline parts, in my opinion.
Have decided I definitely need airbags, and the Air Lift kit looks pretty decent. Maybe a proper on-board compressor would be worth it, to air up and down.
Do I just need to buy Old Man Emu springs? They have a rainbow of sizes and applications, I just got the feeling from the price and what I've heard that they were a cheaper and less robust part.
Talk to me about sway bars? I was hoping the Panhard correction bracket would take care of the rear end, and if I kept the front lift at 1" my OEM bar and new end links would be alright.
Using 265/75/16s at the moment. Cool it on the e-brake turns man! Turns out most potential partners actually aren't impressed by that. I checked.
Obviously there is an alignment in my future.
Old 10-17-2023, 09:42 AM #15
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Have you looked into OME 906 springs with a small spacer? They're a higher coil spring rate but most people only net 1-2 inches unloaded with them without a spacer. You could easily run airbags in those springs as well for when you need the extra help.
I wouldn't worry about replacing the ball joints and sway bar bushings since you've already replaced them with OEM recently.
drop , gravel , lift , rear , springs
What am I forgetting? (Toytec 3 inch kit) FXFRunner General Discussions 0 09-08-2020 11:50 PM
What am I forgetting for my lift? Barcelona4R 5th gen T4Rs 13 08-26-2019 07:11 PM
Can't get brake rotors off. What am I forgetting? Robb235 3rd gen T4Rs 19 05-06-2017 11:52 AM
Anything I'm forgetting? mcarey86 5th gen T4Rs 1 09-22-2015 04:23 PM
Am I forgetting something (coils & struts)? SQ.MD 3rd gen T4Rs 5 03-03-2011 01:06 AM
