Old 10-17-2023, 04:49 PM #16
Originally Posted by 19963.4lsr5 View Post
They are the same. Interchangeable.
Agreed. They should all be the 'oval' plug type. Get the 80A version. If you are tight on $$$, you can likely just do brushes.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 10-17-2023, 04:55 PM #17
Silver Supra's Avatar
Silver Supra Silver Supra is offline
Silver Supra will become famous soon enough Silver Supra will become famous soon enough
Thanks guys - I will be going with the 80A version.
5-speed swap stuff available here!
https://www.toyota-4runner.org/for-s...isc-stuff.html
Silver Supra is offline   Reply With QuoteReply With Quote
Old 10-17-2023, 06:31 PM #18
I hate to say I tested both the 70 amp and 80 amp Alts and both will only push 40 to 41 amps in drive idling with the brake on at a stop at 600rpm with the automatic.
It’s easy Changing the brushes. But up to you.
Most reman companies only replace what was bad/failed. Is Denso the same……probably…….pay the extra 40 dollars for a lifetime Warranty on a high milage rig. They figure it will be in the junkyard before it fails again.
As an example. they receive a Alt with worn brushes……the correct thing to do is Chuck it in the lathe and turn down the commentator where the brushes ride. They don’t. Put cheep China soft brushes in and 1 year later you get the battery light again. Pull brushes and they are nubs. Like they had 200k miles on them and the Alt only had 20k miles on it.
Old 10-17-2023, 11:05 PM #19
pluton's Avatar
pluton pluton is offline
Real Name: Keith
pluton has a spectacular aura about pluton has a spectacular aura about pluton has a spectacular aura about
pluton's Avatar
Real Name: Keith
I ordered the 80A version from a 2000 4Runner and installed it into my '97 no problem. Why suffer with 70A when you can have 80A?
pluton is offline   Reply With QuoteReply With Quote
Old 10-18-2023, 07:31 PM #20
JoeT4R's Avatar
JoeT4R JoeT4R is offline
JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light
JoeT4R's Avatar
My buddy at the dealership is getting the 70 and 80 amp versions to compare side by side. I should know in a day or two if they are at least physically the same, connections, etc.
Very well. I will add that when you knock out this replacement, I would definitely recommend hanging onto your oem alt and keep it for a future project to have as a spare. I’d get a brush replacement kit from Toyota, I’m sure you can find all of the needed p/n’s here on this website for components needed replacing.
I only say this because it’s always a good idea to have a spare on hand and ready to go if at all possible. Plus it’s OEM. So that’s a huge benefit over an aftermarket piece of junk.
Old 10-18-2023, 09:20 PM #21
shadow247's Avatar
shadow247 shadow247 is offline
shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice
shadow247's Avatar
I have the local alternator guy rebuild my OEM one for 90 bucks. He replaced the bearings, brushes, plunger,, and cleaned it all up for me.
The 4Runner Show
shadow247 is offline   Reply With QuoteReply With Quote
Old 10-18-2023, 10:16 PM #22
Take it for what it’s worth…. Every reman is a OEM unit rebuilt to the cheapest specs.
I fixed my dead CarQuest Alt with brushes from Toyota.
I fixed my New Made in Asia starter with parts I had left over from fixing an OEM Starter.
And I’ll say that for the price of the New starter with the plunger greased/ replaced with a OEM contact kit is well worth it.
Old 10-19-2023, 12:05 PM #23
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
agree with this. I did a denso rebuilt on mine, with 249k and sounded like a bearing going, so got a rebuilt. Turns out the bearing whine was not the alternator. So kept the core, put brushes I had on hand, and its sitting on the shelf as a spare
Old 10-20-2023, 10:24 AM #24
JoeT4R's Avatar
JoeT4R's Avatar
That's a definite win. $90 sounds like an excellent deal especially if he's using all OEM components.
Smart way to go about it and I would do the same myself to be honest.
alternator , battery , home , started , thinking
94 3.0 died fastgtfairlane Classic T4Rs 16 08-16-2017 10:56 AM
Alternator died - Pep Boys Pro Start anyone? alms_lefko 4th Gen T4Rs 2 03-21-2015 10:27 PM
broke down, need help! alternator died on trip ghs215 4th Gen T4Rs 3 05-18-2013 02:40 PM
3rd gen almost died t4r4life 3rd gen T4Rs 45 05-06-2011 07:41 AM
'05 Ltd, GPS just died. briandunning Problems & Warranty Issues 10 10-22-2006 06:40 PM
