Old 10-16-2023, 03:38 PM #1
Silver Supra's Avatar
Silver Supra Silver Supra is offline
Silver Supra will become famous soon enough Silver Supra will become famous soon enough
Alternator died?
I was driving home and realized that my radio started to turn itself off then back on again. Then my tach went to zero and the ABS and battery warning light came on. the truck kept running and I made it home - barely.
The battery is only a couple of years old so I'm thinking my 279k mile alternator gave up the ghost.
Any way to check it before I remove it? What is everyone using to replace it - is there an upgrade? I think the OEM one is discontinued.
Thanks!!
5-speed swap stuff available here!
https://www.toyota-4runner.org/for-s...isc-stuff.html
Silver Supra is offline   Reply With QuoteReply With Quote
Old 10-16-2023, 03:44 PM #2
phattyduck phattyduck is online now
Charge the battery, and check the voltage while the truck is running. It should be >13.5 with some load on it (turn on the headlights or something) and >14V on a cold start.
A Denso reman (reman'd by Denso, not some other brand using a Denso core) is your safest plug-n-play bet. There are upgraded options that are a bit more work.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
phattyduck is online now   Reply With QuoteReply With Quote
Old 10-16-2023, 03:45 PM #3
Twisted Sid's Avatar
Twisted Sid Twisted Sid is offline
Twisted Sid has a spectacular aura about Twisted Sid has a spectacular aura about Twisted Sid has a spectacular aura about
Start it and put a multimeter on the main stud and a ground. It should be putting out 14(+/-) volts.
Charge your battery first back up to 12v though.
'99 4Runner SR5: 5VZ, 2wd, AT, 400k+ club
'94 Pickup: 2wd, 22RE, 5spd, (3RZ swap in progress)
Front: Total Chaos Uniball Kit, Fox 2.5 8'' coilover
Rear: Deaver F67 Leaf Springs, Fox 2.0 14'' Reservoir Shocks, E-locker Axle 4.88 Gears 33x10.5 BFG ATs
Twisted Sid is offline   Reply With QuoteReply With Quote
Old 10-16-2023, 05:07 PM #4
19963.4lsr5 19963.4lsr5 is online now
First off, do you own a volt meter and know how to use it.
If your battery will start the engine without charging it your battery post voltage should be above 13.5vdc.
Do you have a hammer? If you do give the Alt a good shot and start the engine. If the battery light goes out it’s your brushes. They are cheep and easy to replace.
19963.4lsr5 is online now   Reply With QuoteReply With Quote
Old 10-16-2023, 06:57 PM #5
Sparky 97Runner's Avatar
Sparky 97Runner Sparky 97Runner is offline
Sparky 97Runner will become famous soon enough Sparky 97Runner will become famous soon enough
This is what my brushes looked like compared to new brushes at roughly the same mileage as yours. I would seriously consider new brushes or Denso reman even if your alternator tests good.
Alternator died?-brushes2-jpg
1997 Toyota 4Runner
Sparky 97Runner is offline   Reply With QuoteReply With Quote
Old 10-16-2023, 09:46 PM #6
mtbtim's Avatar
mtbtim mtbtim is online now
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
On this subject, I've got a video showing how to do it.
mtbtim is online now   Reply With QuoteReply With Quote
Old 10-16-2023, 11:52 PM #7
Romeo1's Avatar
Romeo1 Romeo1 is offline
Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice
Romeo1's Avatar
Alternator died?
All of this.
For voltage testing apply max draw with lights, blowers radio your name it while running. Give it a little rpm. 1200 or higher If your alternator can't at least push 13.5 V it's time for a fix.
Load testing is the only real answer for the battery. You can get those specific gravity testers that are pretty handy and cheap though and test individual cells.
I'm not sure if these run a fusible link or not, but make sure there's continuity from the alternator output to the battery. Make sure the grounds are good too.
If you want to take a crack at fixing yourself, definitely use Tim's video. I have a local alternator shop that I use for everything car, tractor and truck. I've had good success with a NAPA premium stuff too. Never have put one on a Toyota though.
That is a real bummer if OEM is gone.
99’ Black “Highlander” sport, oak, 5VZ auto, 4.30 axle, e-lock, 265/75 Grabber X3,, Bilstein 6112 (2”) front 5160 rear shocks, OME 2906 springs, Durobumps, 4x Inovations front middle rear skid plates, 4XI square TRD tube sliders, lil skips tank skid, lotus dev RCA skids, overland custom sway bar links, Amp’d hidden winch, warn Vr Evo 10s
Romeo1 is offline   Reply With QuoteReply With Quote
Old 10-17-2023, 06:37 AM #8
JoeT4R's Avatar
JoeT4R JoeT4R is offline
JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light
JoeT4R's Avatar
Definitely agree with @mtbtim and @Romeo1 on this. If you decide you just want to throw an alternator at it, the Denso reman p/n is 210-0434. I personally have this alternator in my rig as we speak and it's done great over the past two and a half years. Absolute no issues out of it and it performs just as expected (Knock on wood!)
Old 10-17-2023, 10:01 AM #9
Thanks all for the feedback. Can anyone confirm the 80 amp (210-0434) is a direct fit for my '98 since it's spec'd for a 99-01.
Old 10-17-2023, 10:02 AM #10
I did this and I was seeing 11.9V... then 11.8V.... then 11.7V and it continued to drop. This was with NO accessories on whatsoever. I even turned the radio off!
Old 10-17-2023, 10:13 AM #11
JoeT4R's Avatar
JoeT4R's Avatar
I misspoke and checked my information based on your year rig. There’s two available for yours (assuming it’s a 5VZ) and those p/n’s are 210-0180 (70 amp alt) and 210-0447 (60 amp alt)
I apologize for the above error. Although I’m curious to know if you could still use the 0434 without issue. Maybe someone else here might know.
Also for future reference, the website I use for checking Denso parts is called “denso find my part”
Old 10-17-2023, 12:10 PM #12
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
im not so sure about the amps listed above, I know my 2000 uses a 80 amp denso, and the 2001 I had also took a 80 amp
and yes it is easy to just do brushes
but if you want to just swap out real fast , get a Denso reman...from Rock Auto or someplace....but you want a Denso, rebuilt by Denso
Old 10-17-2023, 12:56 PM #13
Smack the Alt with a hammer. It may get you by until you get an Alt or replace the brushed.
It works, trust me.
Old 10-17-2023, 04:05 PM #14
My buddy at the dealership is getting the 70 and 80 amp versions to compare side by side. I should know in a day or two if they are at least physically the same, connections, etc.
Old 10-17-2023, 04:14 PM #15
They are the same. Interchangeable.
alternator , battery , home , started , thinking
94 3.0 died fastgtfairlane Classic T4Rs 16 08-16-2017 10:56 AM
Alternator died - Pep Boys Pro Start anyone? alms_lefko 4th Gen T4Rs 2 03-21-2015 10:27 PM
broke down, need help! alternator died on trip ghs215 4th Gen T4Rs 3 05-18-2013 02:40 PM
3rd gen almost died t4r4life 3rd gen T4Rs 45 05-06-2011 07:41 AM
'05 Ltd, GPS just died. briandunning Problems & Warranty Issues 10 10-22-2006 06:40 PM
