10-17-2023, 01:05 PM
Tundra Brake Upgrade - replacing front pads
I had performed the Tundra Brake Upgrade back in 2016, shortly after I had initially purchased my T4R. I had used the following kit from Amazon that's not available anymore:
Amazon.com
The calipers and rotors are still good but pads are starting to wear thin but since they were part of a kit, I'll need some assistance finding compatible pads that would work with the calipers I already have.
Is there a way to tell which pads I need from just looking at the pictures or do I need to contact Callahan to get the right pads?
Any help is much appreciated!
00 T4R LTD V6 4WD 275K e-locker
11 RAV4 LTD V6 4WD 100K
10-17-2023, 01:13 PM
Real Name: Rich
Real Name: Rich
Amazon.com
Are those pads in the image actually what came with that kit? They don’t look like any 13WL pads I’ve ever seen. That being said the only pads I can see that match those even remotely are a pair of centric brand on Rockauto but they are listed for the 13WE calipers. There should be holes in the pads that allow the pins to slide through at the top but maybe I’m wrong?
96 Limited: 380k+ 255/85s Geolander MTs, Ironman Nitro 2" lift, Toytec 9602HD W/FJZ80 Shocks
10-17-2023, 02:10 PM
From what I remember, they looked exactly like what's shown on the pictures. I'll replace the whole thing if I must, but just doing the pads is preferable. I'll see if I have the box that the pads came in in the garage somewhere. I remember putting my old pads in there way back when.
10-17-2023, 02:16 PM
Real Name: Rich
Real Name: Rich
Your calipers in the photo look totally fine to me. Im just very confused on the pads. If you go on rockauto any pads designated with the "WL" marking will work for you. Plenty of cheap options as well as some better brands to choose from. Maybe someone with more knowledge than myself has an explanation as to why those pads look so weird
10-17-2023, 02:31 PM
Here is a better picture (not mine) of the pads and rotors that came with this Callahan CCK11988 kit:
CCK11988
10-17-2023, 04:36 PM
Real Name: Patrick
Real Name: Patrick
CCK11988
Any pads for 13WL calipers will work. To make it easier look for brake pads for 2006 Toyota Tundra. They only came with 13WL calipers.
10-17-2023, 04:54 PM
Real Name: Rich
Real Name: Rich
CCK11988
Ah yes those are the correct pads. They must have just been showing a generic image
10-17-2023, 06:45 PM
Real Name: Jerod
Real Name: Jerod
I bought my pads and rotors from Toyota. Calipers off Rockauto.com. The TBU rotors from Toyota were cheaper than aftermarket, worth a look.
10-20-2023, 01:09 PM
That makes it easy, thanks!
10-21-2023, 08:50 PM
10-22-2023, 01:57 AM
Real Name: Jerod
Real Name: Jerod
Glad you found a set that worked great. Just for future jobs, the old pads still had plenty of life as the pad had plenty of material and the center groove was still intact. I realize you might have also been just looking to replace the kit pads anyway.
10-22-2023, 09:24 PM
Yeah the pads in the Amazon picture were a generic set. Looked like Tacoma 4X2 pads. Any Tundra WL pad will work but I recommend ultra premium ones like Adaptive One from NAPA. I personally use Toyota OEM on mine. No noise, no dust, longest life, most surface area.
98 SR5 4X4 5spd, desert dune metallic, Toytech Eibach 3" lift, 1" body lift, RAD Rubber Designs splash guards, 4XInnovations bumpers, Doug Thorely Headers, Magna-flow converter, JBA muffler & tail pipe, RCI skid plate, SPC UCA's & rear LCA's, front sway bar links on rear, gen II rear links on front, Tundra brakes, '02 headlights, tail lights & sidemarkers, BFG 255/85R16 Mud Terrain T/A's 241,000 miles.
10-23-2023, 10:25 AM
Real Name: Patrick
Real Name: Patrick
This project is now complete. I stopped at Advance Auto Parts and picked up a pair of ceramic brakes for 2006 Toyota Tundra and they fit just fine.
Like gamefreakgc said, those pads had a lot of life left. Industry standard at the shops I've worked at is 3mm or less on the lowest front pad needs replacement. Amazon sells brake pad thickness gauges if you don't have one already.
