Old 10-18-2023, 11:38 AM #1
infamousRNR's Avatar
infamousRNR infamousRNR is offline
infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light
NO SPEEDO - CEL + ABS/VSC Lights (2001-2002 4runners)
before I begin, this thread is a good resource for anyone with this problem. I have ordered a used ABS ECU before I started to troubleshoot because of this thread and because I have a P0500 CEL code...
Speedometer/Odometer Not Working + Related Warning Lights (P0500)
Symptoms: No speedometer, ABS and VSC Lights are ON, E-brake light is on, and CEL light is on
Now, question for the audience: Where can I find ABS trouble codes that can be read through a series of blinks on the dash cluster?
Is this info in the FSM?
After jumping the Ts and E1 terminals on the engine bay diagnostic port, I get a reading of the ABS code via the ABS light series of blinks...
my blinks on the ABS light are:
3 blinks
*pause
3 blinks
*pause
3 blinks
*pause
4 blinks
*pause
4 blinks
*pause
4 blinks
*pause
then sequence repeats....
counting these blinks we get 21 blinks total.
That code apparently is the Right Front Wheel ABS Actuator solenoid circuit...
could be an open or short... which is interesting because that's the same front wheel hub that I suspect has a bad wheel bearing..
and so the fact that the ABS light is flashing tells me that the ABS ECU isn't completely shot, although there could be a failed component inside still
my research shows that when an ABS light is always on (no flashing), means ABS ECU malfunction which would warrant an ABS ECU replacement..
Does anyone have any ideas on this issue?
1998 Desert Dune Toyota 4runner Limited 4x4 w/ factory e-locker
2000 BLACK Toyota 4runner Limited 4x4 w/ factory e-locker Build Thread
2002 Thundercloud Metalic Toyota 4runner Limited 4x4
Build Thread
infamousRNR is offline   Reply With QuoteReply With Quote
Old 10-19-2023, 10:53 AM #2
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
Bought my 01 Feb 17 with this problem ABS light was solid codes directed me to RF speed sensor also.
Used linked thread and FSM to get started, speed sensor tested good using a VOM.
Installed used Module problem gone so it ended there.
Toyota Tech's I know that dealt with this said along the lines if you have
3 4 of 5 conditions regarding lights they'd change module.
Old 10-20-2023, 10:56 PM #3
thanks for chiming in, I did indeed buy a new module like I mention in this thread, I will install tomorrow and report back.
any thoughts here @phattyduck @IBallEngineer @skcolb ?..
Build Thread
Old 10-21-2023, 12:21 PM #4
Real Name: Mark
Real Name: Mark
At the time I wasn't sure I wasn't just throwing money at the problem or not based on info and troubleshooting I'd done. Good Luck.
Old 02-27-2024, 01:34 PM #5
Walkersails Walkersails is offline
Walkersails is on a distinguished road
Not an uncommon problem
This is a common problem with these ABS TRC VSC modules. I repair automotive electronics for a living and repair these modules frequently. I have ads on eBay for "Repair Service" or exchange for these specific modules. You could search by part number or search for me under Walkersails. Or you could contact me directly through this forum for a discount. Thanks!
Walkersails is offline   Reply With QuoteReply With Quote
Old 02-27-2024, 02:41 PM #6
Real Name: Mark
Real Name: Mark
What you give me for my bad one?
96RedRunner limited 4x4 5VZ auto not stock 374k miles totaled 2018.
2001 limited 4x4 5VZ auto work in progress.
2011 Audi S5 Prestige 4.2 V8 6 spd MT.
abs , blinks , ecu , light , wheel
Parting TWO 2001-2002 4Runners Marysville, WA DeathCougar For Sale: T4R Items 214 04-16-2024 04:19 PM
WTB: 2001-2002 4Runner Tail Lights & Harnesses 1986Runner Want to Buy/Trade 5 05-16-2016 06:41 PM
Looking for 2001 or 2002 Grille and rear pair tail lights OEM houjames98765 3rd gen T4Rs 4 06-07-2015 08:05 PM
2001-2002 Tail lights - Phoenix, AZ $105 shipped absalom For Sale: T4R Items 0 02-13-2015 03:16 AM
