Old 10-18-2023, 07:16 PM #1
texadelphia texadelphia is offline
texadelphia will become famous soon enough
Clutch Pedal Adjustment
I had my clutch pedal out to replace the torsion spring bushing and realized that I might not have the clutch adjusted right. I was reading the FSM and 2 things are confusing.
First, it pictures a height adjustment bolt, but I have the cruise control switch where that would be. Should I just use the sensor like the bolt to set the height?
Second, it's unclear where exactly on the floor to measure from. I tried to hold the ruler as perpendicular to the pedal surface as possible but it says to measure from the "asphalt sheet" or the "floor panel". Is this what would be under the carpet? If so do I need to pull the carpet down to get a correct measurement. I just pushed the ruler as hard as I could into the carpet and added 3-4 mm to my measurement to account for carpet thickness
Finally, should the "free play" at the top of the pedal be super free or just pretty soft? It seems like the free play is really just the clearance between the pin that attaches the master cylinder plunger to the pedal arm. So basically you're just adjusting the plunger so that there's 1-5mm of travel before the hole in the pedal and the pin come in contact?
I think mine was way too low because the clutch engaged right off the floor and getting into gear, especially reverse was sometimes kind of notchy. But now that I have it adjusted the pedal just kind of feels slightly too high. But I want to make sure I'm getting enough travel out of the pedal so the clutch is fully disengaging. I'm assuming it's right and I'll just get used to the new position with time.
1997 SR5, 3.4L, Manual
texadelphia is offline   Reply With QuoteReply With Quote
Old 10-21-2023, 12:46 PM #2
1blink 1blink is offline
1blink is on a distinguished road
IMO, you seem to have the right idea. I did my clutch adjustment similar to you, didn't feel like pulling the carpet to get my measurement.
Sent from my SM-S901U using Tapatalk
215k+ 1997 SR5 manual, e-locker, + stuff
1blink is offline   Reply With QuoteReply With Quote
Old 10-21-2023, 01:15 PM #3
Sparky 97Runner's Avatar
Sparky 97Runner Sparky 97Runner is offline
Sparky 97Runner will become famous soon enough Sparky 97Runner will become famous soon enough
I think this is the most important thing so you don't wear out your throw out bearing. You don't want any pressure on the plunger. Sounds like your on the right track. I always found the FSM description confusing as well.
1997 Toyota 4Runner
Sparky 97Runner is offline   Reply With QuoteReply With Quote
carpet , clutch , floor , free , pedal
Manual Swap Clutch Pedal and Clutch Master Cylinder VernySanders 3rd gen T4Rs 5 06-27-2020 11:21 PM
Clutch Pedal Free Play (and piston rod adjustment) 89FourRunner Classic T4Rs 1 09-26-2017 10:05 AM
Clutch engagement point on pedal after new clutch and flywheel installed 89FourRunner Classic T4Rs 8 11-18-2016 04:03 PM
Clutch Pedal and Clutch Master Cyl sggaz 3rd gen T4Rs 5 10-29-2016 02:14 PM
Clutch Adjustment? PitbullRescuer 3rd gen T4Rs 6 07-10-2012 10:18 AM
