Old 10-24-2023, 04:47 PM #1
Wasatch Rebel Wasatch Rebel is offline
Wasatch Rebel is on a distinguished road
Installed new after market front bumper. Need load resistors installed.
So I just had a new bumper installed and now I need to install some load resistors for the rapid blink issue caused by switching to LED lights. The questions I have are where to install them and which wires to connect them to. Also if you have done this job, where did you mount the resistors themselves?
Wasatch Rebel is offline   Reply With QuoteReply With Quote
Old 10-24-2023, 05:22 PM #2
spartacus's Avatar
spartacus's Avatar
How To: Fixing Hyper Flash Turn Signal (Replace Flasher Relay)
Old 10-24-2023, 05:28 PM #3
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
or you can get the flasher that is rated for LED's. Thats what I did, I replaced all my flashers , brake bulbs, back up bulbs and parking bulbs to LED. got it at NAPA..maybe someone will chime in wth part number
however...dont replace your third brake light ( up high) with an LED as that will trigger your ABS light to come on. and as far as the ABS light coming on, it will come on if your stock bulb burns out....the ABS needs that resistance and why its wired in wiht that light is beyond me.
Old 10-24-2023, 05:58 PM #4
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
I used an adjustable relay purchased at Autozone plugs into blinker relay socket.
OOPs same one spartacus posted.
Old 10-24-2023, 08:40 PM #5
hklt4R's Avatar
hklt4R hklt4R is offline
hklt4R is on a distinguished road
hklt4R's Avatar
I got some Morimoto load resistors from theretrofitsource and just installed them on the body right behind and underneath the headlights. You just wire them in parallel with the turn signal wiring and you should be good to go. Will only work for the front tho. If you install led turn signal bulbs in the back it will still hyperflash.
2000 Limited
- E-Locker, 33 Yokohama MTs, 3 suspension & 1 body lift, Durobumps, SPC UCAs & RLCAs, 4X Innovations Front Bumper, Full Skids, Smittybilt 9.5k, Retros
hklt4R is offline   Reply With QuoteReply With Quote
Old 10-25-2023, 12:23 AM #6
pluton's Avatar
pluton pluton is offline
Real Name: Keith
pluton has a spectacular aura about pluton has a spectacular aura about pluton has a spectacular aura about
pluton's Avatar
Real Name: Keith
It's really easy to replace the flasher with an LED friendly one. Seems that most chain parts stores have them. With the LED rated flasher, you can change any/all of your signal bulbs to LED w/o further flasher-related trouble.
pluton is offline   Reply With QuoteReply With Quote
Old 10-25-2023, 01:11 AM #7
Endlessblockades's Avatar
Real Name: Blair
Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold
Real Name: Blair
Another vote for a $10-15 flasher relay. See Tim's video
258K - Y2K/E - Clock still works
bumper , install , installed , load , resistors
so I installed the CBI Covert Front Bumper and WTF? Gouranga 5th gen T4Rs 88 06-15-2022 04:16 PM
BayAreaMetalFabrication front bumper *installed* Barcelona4R 5th gen T4Rs 1 08-14-2021 11:23 PM
4xinnoations front plate bumper installed Carcrafter22 3rd gen T4Rs 1 01-11-2012 06:07 PM
BADLAND front bumper installed Elton H 3rd gen T4Rs 16 04-01-2010 01:25 AM
Shrockworks 4th gen front bumper installed mikestang Gallery 12 10-13-2006 06:06 PM
