Old 11-19-2024, 11:08 PM #46
Rahll's Avatar
Rahll Rahll is offline
Rahll will become famous soon enough
Rahll's Avatar
Buddy called for a rescue up in the snow. They were elk hunting and got hit by a bad snowstorm. Chim and I bombed out and made it up to get them off the mountain
Got to stretch the lockers legs a bit, but found having it on caused the whole rear to swing in the snow we were climbing
Overall handled some pretty deep snow pretty well and went smoothly
Rahll's 98 SR5 4wd Build-snow-rescue-jpg
Rahll is offline   Reply With QuoteReply With Quote
Old 01-21-2025, 02:25 PM #47
Rahll's Avatar
Rahll's Avatar
I followed PhoRunners videos on doing cheap bumpstops, and it works perfect. My rubbing in the front has pretty much disappeared, since it only rubbed bad while simultaneously turning and dropping off a ledge. The comments he makes about having the correct bolt is very important, as ACE and Wilco that carry the large bolt sets do not have the right socket head cap bolt to secure these. I ended up grinding down a hex bolt of the right thread pitch to fit a 12mm, which I was able to fit inside the front bumpstop. Normally the correct thread pitch is matched with a 14mm bolt, and the 14mm socket is too wide for the bumpstop. I got two sets of chevy bumpstops from the GMC model he lists in the video, and everything in the rear bolts up perfect. I haven't flexed out in the rear yet, but the size is really comparable to durobumps on paper, and I was having a lot of rubbing issues in the rear when fully flexed.
https://www.youtube.com/watch?v=JZNt...l%284Runner%29
4wd , build , functioned , sr5 , working
BEGINNING - Build on a Stock 4Runner! *UPDATED BUILD THREAD* bryanbgw 3rd gen T4Rs 27 11-22-2023 07:53 PM
>BUILD THREAD< The4kbeast's 3rd-Gen 2000 T4R SR5 (Highlander Edition) 4x4 Build The4kbeast 3rd gen T4Rs 285 07-25-2018 09:37 PM
1998 T4R Build Thread/Rear bumper build 4running11191 4running11191 3rd gen T4Rs 3 09-19-2014 07:07 PM
Snow White build 2006 v8 adventure overland apocalypse build Dubs Chops 4th Gen T4Rs 24 04-25-2014 09:25 AM
