Originally Posted by AuSeeker
Did you ever try as suggested spraying some starting fluid in the intake/throttle body to see if it will try to start?
If it does then your issue is no fuel being delivered, so maybe bad fuel pump.
I completely forgot to mention that. Yes my friend sprayed starter fluid directly into the TBI while I turned the key, and no go. Can someone show me (under driver's side rear seat) which plug is which (pump and sending unit)? And I am having trouble figuring out how to disconnect the one closer to the passenger side, what is the trick if I have to drop the tank? Gonna make sure it is getting a signal before going through all of that. I checked the fuse, it was fine, replaced it anyways.
