Old 11-02-2023, 09:05 PM #31
_Ace_'s Avatar
_Ace_ _Ace_ is offline
_Ace_ will become famous soon enough
_Ace_'s Avatar
Ordered a replacement Toyota fog lights rocker switch #00550-35976 from Toyota online, $9.62 shipped to my nearby dealer
The switch that I have now is missing the lens and while not connected to a set of driving lights I plan on doing that in the future.
1998 SR5 - 5 speed w/ 4.30 E-locker
My 1998 SR5 Build Thread
_Ace_ is offline   Reply With QuoteReply With Quote
Old 11-03-2023, 09:49 AM #32
_Ace_'s Avatar
_Ace_'s Avatar
Installed an Airaid intake tube also. Eliminates the baffles and cleans up the engine compartment.
I've had good luck with one on my Suburban 5.3L with it's proven dyno results to a stock engine.
Before & after -
Ace's 1998 4Runner Build Thread-img_8898-jpg  Ace's 1998 4Runner Build Thread-img_8903-jpg
Old 11-03-2023, 09:57 AM #33
_Ace_'s Avatar
_Ace_'s Avatar
Catalytic converter theft in my area is pretty bad so I installed a Talons Garage transmission /Catalytic Converter Skidplate to protect my T4R-
Toyota 4Runner | Transmission & Cat Shield | 1996-2002
– Talons Garage
I bought the steel version and installation was easy.
It protects the forward area of the cat so that they can't cut off that end. I may install a DIY extension with steel mesh to stop a thief from mistakenly cutting the other end.
Another option is buying their transfer case skidplate.
A few pics -
Ace's 1998 4Runner Build Thread-img_8895-jpg  Ace's 1998 4Runner Build Thread-img_8896-jpg
Old 11-03-2023, 10:02 AM #34
JoeT4R's Avatar
JoeT4R JoeT4R is offline
JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light
JoeT4R's Avatar
Before & after -
Looks beautiful!! Your build is coming along super sweet
Old 11-03-2023, 10:12 AM #35
_Ace_'s Avatar
_Ace_'s Avatar
Forgot to mention -
Before I installed the Airaid intake tube I removed and cleaned the Idle Air Control and the throttle body. The IAC was a bit sticky but it cleaned up well with some carb cleaner.
I ordered an IAC gasket ahead of time from Toyota parts online and picked it up at my local dealer. I knew my 26 year old gasket would be stiff so I planned on replacing it. It did break when removed.
My idle is still sticky so I'll be trying this throttle bail washer mod today (my throttle body sticks like the YouTuber's did) -
Old 11-03-2023, 01:24 PM #36
_Ace_'s Avatar
_Ace_'s Avatar
I went to my local Ace hardware with the nut that holds the throttle body bail onto the shaft and found that the nut fit on a M8 -150 fine thread bolt. I used that bolt to find some washers and bought one steel and 3 thinner nylon washers.
I figured that I could cut a nylon washer with a razor knife and put it over the shaft without taking the bail off.
The washers & the nut-
Ace's 1998 4Runner Build Thread-img_8923-jpg
Old 11-03-2023, 01:27 PM #37
_Ace_'s Avatar
_Ace_'s Avatar
I split one washer, greased it and put it onto the throttle body shaft the reinstalled the bail , nut , lock washer & cables.
Ace's 1998 4Runner Build Thread-img_8925-jpg
Old 11-03-2023, 01:28 PM #38
_Ace_'s Avatar
_Ace_'s Avatar
as you can see in the pic the shaft was a little larger than the inside diameter of the nylon washer.
There was still some play in the throttle body so I installed a second nylon washer and the play was gone, idle sticking resolved.
Old 11-04-2023, 03:45 PM #39
_Ace_'s Avatar
_Ace_'s Avatar
Removed, cleaned and painted the rear spoiler, it's brackets and the rear wiper assy with SEM Trim Black paint this afternoon -
Ace's 1998 4Runner Build Thread-img_8928-jpg
Old 11-08-2023, 11:32 AM #40
_Ace_'s Avatar
_Ace_'s Avatar
Since my 1998 has no imobilizer/chip key I bought this Viper 3505V 2 way alarm at Amazon-
https://www.amazon.com/gp/product/B0...e?ie=UTF8&th=1
Had Best Buy install it.
Range is excellent and it works great. Since my T4R is a 5 speed manual I chose not to have remote start enabled.
This model has the feature that will disable the ignition when the alarm is going off to stop a thief from starting & driving away after attacking the ignition switch. That requires a separate starter interrupt relay to be installed.
Old 11-08-2023, 01:01 PM #41
_Ace_'s Avatar
_Ace_'s Avatar
Yesterday I noticed the fan clutch was loud for too long so I ordered a replacement.
Tim covers diagnosis of a bad clutch & replacement here -
Old 11-08-2023, 01:15 PM #42
Look up ways of doing a secondary kill switch that interrupts power to the fuel pump. Hidden and separate from the alarm. Won't stop cat thieves or a tow truck... but then you should be pretty safe.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 11-08-2023, 08:24 PM #43
_Ace_'s Avatar
_Ace_'s Avatar
Removed and replaced the fan clutch, used this one -
https://www.amazon.com/dp/B0819TWFQT...roduct_details
Also replaced the rear liftgate struts with these -
https://www.amazon.com/dp/B00W8QBA30...roduct_details
Old 11-09-2023, 12:35 PM #44
JoeT4R's Avatar
JoeT4R's Avatar
Amazon.com
Amazon.com
Happy to see this kind of maintenance getting done. I personally have Strongarm struts on the rear hatch of my 4Runner as well as on the hood of my Honda Accord. Great results. Thanks to @for promoting these in the past, that’s why I went with them.
For the fan clutch I’m surprised you didn’t go with the saison unit. It’s under $100 and is OEM, but I hope you have good results with this one nevertheless.
Old 11-09-2023, 12:54 PM #45
_Ace_'s Avatar
_Ace_'s Avatar
It had good reviews so I thought I'd give it a try.
So far it's operating well.
4runner , e-locker , leather , oem , shape
Alikazam - 1998 4runner 4cyl "Betty" - Build Thread Alikazam 3rd gen T4Rs 16 08-18-2017 05:56 AM
inneyeseakay's 1998 2WD Build Thread inneyeseakay 3rd gen T4Rs 12 05-01-2017 08:15 PM
CodyX36's 1998 4Runner Build-Up Thread CodyX36 3rd gen T4Rs 68 04-23-2016 02:21 PM
1998 T4R Build Thread/Rear bumper build 4running11191 4running11191 3rd gen T4Rs 3 09-19-2014 07:07 PM
1998 4WD SR5 Build Thread Calvin52 3rd gen T4Rs 5 12-10-2013 11:42 PM
