Old 11-20-2023, 11:42 PM #1
Soulman Soulman is offline
Soulman is on a distinguished road
LED Brake Lights- acting weird
So I installed LED back up lights and LED Brake lights from Super Bright LEDs.com. They are all bright and look great. The reverse lights seem to work normally, but the brake lights start to blink when the turn signal is on, and occasionally even the opposite side blinks. Anyone have experience like this? Do I need to go back to traditional bulbs? Swapped out the interior bulbs and they all work fine. Also, I bought the "Switchback" bulb for the brake light- no idea what that is but maybe that's the issue?
-1999 4Runner Limited w/RR locker, OME/5100s, 285 Toyo Trail R/Ts
-2021 Tacoma TRD Offroad w/OME/Bilsteins, 285 BFGs
Soulman is offline   Reply With QuoteReply With Quote
Old 11-20-2023, 11:59 PM #2
hoppyjr hoppyjr is offline
hoppyjr has a spectacular aura about hoppyjr has a spectacular aura about
I tried Super Bright LEDs long ago and had similar issues. Basically cheap junk like the eBay/amazon made in China stuff.
Switchback bulbs are typically designed for use in front turn signals, giving a white parking light and switching to an amber turn signal. They arenít intended for brake or tail lights.
Iíll say this, you definitely get what you pay for. I have used VLEDís products exclusively since about 2012 and the couple times Iíve had issues, they resolve them immediately. There is also a 30% sale at the moment.
hoppyjr is offline   Reply With QuoteReply With Quote
Old 11-21-2023, 12:29 AM #3
Ed_C's Avatar
Ed_C Ed_C is online now
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
Sounds like the switchbacks are causing your "backfeed" issues. Return them and get red Sylvania ZEVO (not their basic model line) or Philips Vision (not their current North American Ultinon line which are nowhere near as good as the originals sold in the Japanese market). The ZEVOs are available locally at Advance Auto and Autozone while the Philips can be found at Pep Boys, cheaper online though.
While I am a proponent for VLEDS stuff they're a little on the pricey side, especially their Tritons. The ZEVOs and Visions are my go-to for "plug-in" brake light bulbs.
PS I do use SuperBrightLEDS for interior and some 921 bulbs. They're the few companies that offer warm white in BA9s and festoon (map and dome light).
Ed_C is online now   Reply With QuoteReply With Quote
Old 11-21-2023, 12:38 AM #4
Thanks guys. Are the Zevos LED? Or just a better traditional bulb? Iíll check into all these options
Old 11-21-2023, 01:11 AM #5
Ed_C's Avatar
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
Yes, same with the Philips
Old 11-21-2023, 04:24 PM #6
The running/brake lights should not 'talk' to each other - the circuits are totally separate... except for the ground connection. Make sure the ground is clean and tight behind each rear interior trim below the tail lights.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 11-21-2023, 10:28 PM #7
JoeT4R's Avatar
JoeT4R JoeT4R is offline
JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light
JoeT4R's Avatar
I will happily +1 this, as I have Sylvania ZEVO LEDís in almost everything that can accept them. They are in my opinion the best you can get in terms of quality, brightness, longevity, no issues, etc.
Iíve used SuperBright, Iíve used vLEDS, not impressed. Just my .02
Old 11-21-2023, 11:10 PM #8
So is there any reason that I should not be able to use LEDs in all the rear lights? I've read some old threads about adding resistors, is that old tech now?
Also, anyone have recommendations for LED headlight bulbs?
Old 11-21-2023, 11:18 PM #9
Second question first: I canít say enough good about VLEDís. They are designed well and perform as expected for the price. Iím not affiliated with them, other than to say Iíve been a customer for 12 years or so, and I spend my hard earned money on the products. Itís all I use. (See my build thread for more info).
Resistors - yes, youíll need them for turn signals, but not for brake/tail or reverse. Some products require wiring in resistors for turn signals, whereas the VLEDís products have plug & play resistors available when needed.
Edit: I just realized youíve got a 3rd gen model. In my 5th gen the turn signal flasher is integrated on the body control computer module. On your 3rd gen you likely have a plug in turn signal flasher. If so, you can buy a replacement plug in flasher that is LED compatible. It will be a simply way to resolve this, but I caution against cheap stuff. Diode Dynamics appears to have one (CF15) thatís currently on sale for $16
Old 11-21-2023, 11:32 PM #10
Hmmm interesting. I just watched VLED's video about the "Hyper Flash" fix. Seems pretty easy. And their stuff is on sale for the next week so I may have to get some blinker LEDs.
How about headlights? Do those need resistors or anything other than the bulb?
Old 11-21-2023, 11:38 PM #11
The headlights do not need anything, their product is plug & play.
Some will speak ill of LEDs in reflector housings, but it comes down to two factors; proper aiming of the light and quality design of the led product. I have met the VLEDís guys (Jake & Eli) and they designed their headlights to place the chips in the same location as whet the traditional halogen filament would be, so the light is coming from the right place inside the headlight housing. Iím a big fan.
For what itís worth, Iíve been upgrading the lighting in my vehicles since 1980 and Iíve learned quite a lot. In my build thread there are several lighting upgrades, which may give you some ideas.
Hoppyís build thread - 2022 ORP
https://r.tapatalk.com/shareLink/top...ink_source=app
Old 11-22-2023, 08:25 AM #12
Ed_C's Avatar
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
No need for load resistors if you replace the flasher with a LED-compatible one (they're available for 3rd-gens). On a vehicle with a non-replaceable flasher I do prefer/use VLEDS' resistors over the usual gold ones sold everywhere.
If you do decide to order from them I highly suggest this bulb for the 3rd brake light Best, Brightest LED Brake Light Bulb, tried their 36-chip one and wasn't impressed and their most expensive Triton is too deep to clear the tailgate. Their 921 Triton switchback (converts the reverse light into dual function reverse and signal) is tempting too 16-23 TOYOTA TACOMA MESO TOTAL TAIL STAGE 1 UPGRADE V6 TRITON SWITCHBACK 921
Old 11-22-2023, 09:45 AM #13
The third brake light- how many of those bulbs does it take? I opened it and see that there is one bulb..
The rear blinkers- I have seen the video with their resistor and am leaning toward the Triton that has the resistor pre-wired. Have any of you guys used that model and if so, where did you mount the resistor? Seems like not much room behind the housing for it.
Thanks for all the replies and info!
Hoppy- I checked your build and it looks great! Sent a link to my buddy who is picking up a white 2013 with 76k miles on Friday.
Old 11-22-2023, 12:35 PM #14
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
unless things have changed over the years.....many years ago I tried an LED in my 3rd brake light, and it triggered the abs light on dash, . Similar if the 3rd brake light burns out it will trigger the ABS...so put stock back in and light went off.
other than that one light, I am running LED brake flashers back up and parking lights. Used the LED flasher relay.
Old 11-22-2023, 01:01 PM #15
Ed_C's Avatar
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
Just one
The rear blinkers- I have seen the video with their resistor and am leaning toward the Triton that has the resistor pre-wired. Have any of you guys used that model and if so, where did you mount the resistor? Seems like not much room behind the housing for it. .
Not on the 4Runner but I'm running Extreme ambers in the front signals and standard V6 (Extremes weren't available yet) switchbacks in the tails so they're also additional reverse. According to their specs the switchbacks' amber is 200lm dimmer, but they're still very bright. I have a LED flasher so no resistors, but VLEDS does sell extension wires for their resistors.
I'm running all LED brake light bulbs and no ABS or other issues. 3rd brake light has the VLEDS 921 I mentioned before and ZEVO or Philips in the tails.
back , brake , led , lights , work
Truck acting weird bay_area4runner 3rd gen T4Rs 10 02-17-2018 04:01 PM
woofer acting weird t4r4life Engines / Suspension / Wheels / Tires / Audio / Accessories 4 03-15-2011 10:09 AM
Tranny acting weird TacMedic 4th Gen T4Rs 0 03-13-2011 01:45 AM
My NAV headunit is acting weird! Duc Hunter 4th Gen T4Rs 6 01-22-2005 11:42 AM
New Runner acting weird - please help bbates 4th Gen T4Rs 4 04-28-2004 04:59 PM
