Old 11-28-2023, 02:53 AM #1
hawkcharmer's Avatar
hawkcharmer hawkcharmer is offline
hawkcharmer is on a distinguished road
Help wiring oem foglight switch so it lights up when the truck is running
Hello,
I recently purchased some off-road lights. They came with wiring harness and relay. Im connecting this to a oem foglight switch with the little orange led.
There are 3 prongs on back of switch.
Top=Ground
Middle= Hot
Bottom= Out to relay
How do I wire this so that the little orange LED lights up when I turn on the truck? Right now, it lights up only when I flip the switch to turn on lights.
The aftermarket off-road lights switch wiring is Black, White, Blue
Any feedback is greatly appreciated! Thanks
Help wiring oem foglight switch so it lights up when the truck is running-d4cf9a1d09e94ff4b6cd343bafe108ee_490-jpg
1999 4Runner SR5, 3.4L 5VZ-FE V6 | Tundra/890 coils | 5100 Bilsteins all around l 199mm Tundra brake upgrade | 265/75/16 Falken Wildpeak AT3 tires | ARB Bull Bar
hawkcharmer is offline   Reply With QuoteReply With Quote
Old 11-28-2023, 04:36 AM #2
Ed_C's Avatar
Ed_C Ed_C is offline
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
Edit: see my following post....
Old 11-28-2023, 12:11 PM #3
Ed_C's Avatar
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
Hmmm actually....
It might be possible if you wire the top and middle terminals the opposite way. Is that the switch Oznium sells?
From Customer Questions: Scion OEM Style LED Lighted Rocker
Q.I bought and installed this LED rocker switch. It looks great! It turns my lights on and off just fine.
But for some reason, the LED light on the switch always stays on, whether or not the switch is on or off.
What am I doing wrong?
A.Switch the two prongs that are connected to your power source and the positive wire on your lights.
Old 11-28-2023, 02:05 PM #4
This is a factory Toyota foglight switch.
Terminals
Top= Ground
Middle= Hot
Bottom= Relay/lights
So, I should move the middle white wire to top terminal (ground), and the top black wire to middle terminal hot?
Old 11-28-2023, 02:59 PM #5
Ed_C's Avatar
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
Terminals
Top= Ground
Middle= Hot
Leave ground as-is and swap around the other two (relay/lights to middle and hot to bottom)
Old 11-28-2023, 03:01 PM #6
Thanks! I'll try that this evening and let you know if it works.
Old 11-28-2023, 07:16 PM #7
as you mentioned... Switching those two wires around worked out! I can now see where the button is when it's dark. Thanks brother!
Old 11-28-2023, 09:05 PM #8
Endlessblockades's Avatar
Real Name: Blair
Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold
Real Name: Blair
Ah, the good old Camry switch 00550-35976. Not the fanciest ( or cheapest ), but they get most jobs done and are well-made. I ordered 2 this afternoon.
262K - Y2K/E - Clock still works
led , lights , off-road , switch , wiring
ditch lights switch wiring help Jayson44 4th Gen T4Rs 24 03-27-2020 12:48 PM
AOB switch and Black Oak lights wiring airbusa380 5th gen T4Rs 47 04-14-2019 02:40 PM
FJ Foglight switch wiring seanmh 4th Gen T4Rs 11 04-02-2013 02:08 PM
Wiring 3 Rigid Industries lights to 1 switch? Rudy97 3rd gen T4Rs 4 08-24-2012 02:13 PM
Need help on wiring Piaa lights to new Rocker Switch?? gkatmar 4th Gen T4Rs 4 01-22-2012 06:24 PM
