Old 11-29-2023, 09:13 PM #1
Option01 Option01 is offline
Option01 is on a distinguished road
Projector retrofits - Are rear halos bright enough to function as turn signals?
Hello! I'm hoping some of you that have retrofit projector headlights might be able to answer a question for me. I no longer have OEM turn signals after installing an aftermarket bumper and was wondering if the rear rear switchback halos on the LED retrofits are bright enough to function as the vehicle's sole turn signals?
I'm specifically looking at the Panamera 2 shrouds from TEQ Customs as shown below and would be getting them with chrome housings if that matters. I'm assuming that going with front and rear halos would increase the light output but I don't care for how the front halos look (just my personal preference). Any input would be greatly appreciated.
Projector retrofits - Are rear halos bright enough to function as turn signals?-capture-jpg
1999 SR5 V6/Auto 4WD
4.88 Gears, Front/Rear E-Lockers
1" Body Lift, 2" Suspension Lift, 285/75 R16 Tires
Option01 is offline   Reply With QuoteReply With Quote
Old 11-29-2023, 09:45 PM #2
Ed_C's Avatar
Ed_C Ed_C is offline
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
Probably not.
You can wire the corners to do double duty as parking and signal with these modules:
LED Switchback control modules VER.1 (for 1 color LED setup) | PAIR – CorsoMotion
or
Blinker Genie 2 - for Run and Turn with LED Signals on Automobiles – Custom LED
Corsomotion will flash the corners at the same time your halos will, while the Blinker Genie will flash alternately with the halos.
Order these amber 921 LEDs for the corners https://www.ebay.com/itm/30449126430...mis&media=COPY
Old 11-29-2023, 10:11 PM #3
Ed_C's Avatar
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
You could also use this for the corner signal conversion Amazon.com
Connect one of the original parking light + to the converter brake wire and corresponding signal + to converter signals. Cut the 4-pin connector and connect the turn/stop wires to the corresponding parking light bulb +
Old 11-29-2023, 10:17 PM #4
Originally Posted by Ed_C View Post
Probably not.
or
Oh man, I had those Corsomotion modules bookmarked as a backup plan lol!
I wasn't sure if having the halo and parking light hooked up to the same turn signal wire would cause any problems. Glad to hear it's a viable option and I'll definitely be going that route. Thanks for the suggestion!
Old 11-29-2023, 11:26 PM #5
Ed_C's Avatar
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
Shouldn't be any problems as long as the halo amber is connected before the Corso modules. If you wired them to the Corso outputs they'll be constantly amber with the parking lights. Just be forewarned that Corso isn't the fastest when it comes to processing orders, even their dealers get treated this way LOL
You'll also need load resistors or a LED compatible flasher (preferably)
Old 11-30-2023, 02:44 PM #6
phattyduck phattyduck is online now
Something like this might also work for you:
96-02 3rd Gen 4runner Amber Turn Signal LED Filler Panels
– Snowbound Customs
(DIY or buy it, your choice)
Also, there are trailer/truck turn signals you can pop into a hole in the bumper - if you have a plate bumper, that is.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
phattyduck is online now   Reply With QuoteReply With Quote
Old 12-01-2023, 01:05 AM #7
toverturf toverturf is offline
toverturf will become famous soon enough toverturf will become famous soon enough
Your 4runner NEEDS this mod! - YouTube You can see how bright they are in this video with and without the headlights on. These are in a black housing but a chrome one should be pretty similar. Imo they seem bright enough.
I'm getting the same headlights but with the turbine shroud and black housing so i'll be interested to see what you think when you get them installed. For me if they aren't bright enough when I get them i'll probably get the LED filler panels linked above.
1999 Limited with rear locker.
Sherpa Matterhorn | Sonoran Steel Diff Drop | SPC UCAs | DuroBumps Front and Rear | OME 890 Springs and Black Tokico Shocks | Eimkeith Reinforcements and PCK | King Coilovers | OCD Sway Bar Links | Opt Offroad Rear Arms | Lil Skips Gas Tank Skid Plate | FGP Rock Sliders | 4x Innovations Rear Plate Bumper with tire carrier
toverturf is offline   Reply With QuoteReply With Quote
Old 12-01-2023, 05:56 PM #8
– Snowbound Customs
Good point! I actually bought some cheap Amazon amber LED's strips with adhesive backing and stuck them on the filler plates as a temporary fix. It works pretty well but I'd like something a little cleaner for a long-term solution. I did check out those filler plates from snowbound customs but the individual round LEDs wasn't really working for me aesthetically.
Old 12-01-2023, 05:58 PM #9
Thanks for the wiring tip! I do have an LED compatible flasher installs so I should be good to go in that regard.
And yeah, I've got quite a wait for the headlights to come in so hopefully Corso can get me the modules within that two month time frame so I can get both wired in at once. In the mean time, I ordered a set of these for the parking lights:
https://www.amazon.com/dp/B07TC4438Z...t_details&th=1
Old 12-01-2023, 06:06 PM #10
Thanks for the link! I agree they do seem pretty bright but I wonder how noticeable they'd be at a distance with the headlights on. Another user with a similar setup said the yellow rear halos get a bit "washed out" in that scenario so he didn't recommend relying on them as the sole turn signals.
I'll update here with my impressions once I get the projectors installed. I imagine it'll be a pretty long wait though after TEQ's big Black Friday sale. They've probably got a huge backlog of headlights to build.
Old 12-01-2023, 06:32 PM #11
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
My other concern with using the halos as the sole turn signal is visibility from 90 degrees.
Old 12-01-2023, 07:00 PM #12
Ed_C's Avatar
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
Ahhh, I thought you already have the headlights LOL
Amazon.com
Interesting design, VLEDS uses the same emitters in their high-output line but the ones you listed have 30 more of radially so they should be pretty bright
Old 12-01-2023, 10:09 PM #13
That's a great point! Are the stock turn signals visible from the side? It's been so long now that I can't remember lol.
Old 12-01-2023, 10:11 PM #14
Haha, yeah that's part of the reason I was posting the question. I wasn't sure I should shell out the extra cash for the halos if I was going to have to do something else for turn signals anyway.
Old 12-01-2023, 10:30 PM #15
Ed_C's Avatar
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
How much more do the halos add to the price?
function , projector , retrofits , signals , turn
Wiring Halos and Turn Signals separately cmriquinha 4th Gen T4Rs 1 07-03-2017 11:11 AM
FS: NEW 3rd Gen Projector Retrofits by A.Wilson013 SF Bay Area, CA TxnBluDvl For Sale: T4R Items 1 03-21-2017 04:43 PM
Gauging interest in projector retrofits A.Wilson013 For Sale: T4R Items 73 10-10-2015 05:14 PM
Gauging Interest In 3rd Gen Projector Retrofits (very small # to be made) BrianSD_42 3rd gen T4Rs 52 08-30-2015 03:02 AM
FS: 3rd gen projector retrofit with halos, $800 SLC, UT sigalution For Sale: T4R Items 3 01-19-2014 07:45 PM
