Old 12-02-2023, 04:29 PM #1
mendozer mendozer is offline
mendozer is on a distinguished road
odd noise started yesterday
I tried uploading the audio file but it won't work. but when i accelerate it causes a subtle whirring/whining noise. it's less with coasting but still there. nothing looks weird with belts, fan, etc. i wish i could upload the recording. it's almost like a higher pitched "crystal glass of water" sound if you know what i mean. when you swirl the finger on a glass and create the bowl effect
mendozer is offline   Reply With QuoteReply With Quote
Old 12-02-2023, 06:21 PM #2
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Does it exactly match the engine RPM every time or does it alter at idle and driving away from a stop?
326WHP 347TQ
Old 12-02-2023, 08:33 PM #3
spartacus's Avatar
spartacus's Avatar
First guess; Power steering pump system, pulley, belt pump it self.
Old 12-02-2023, 10:00 PM #4
upon startup there's a faint noise. then once i press the accelerator it gets noisier and i can't tell if its RPM dependent or just speed bc it does it just coasting at 60 or revving not in gear too.
Old 12-02-2023, 10:00 PM #5
Im alone so i cant rev it while being there but it DOES sound closer to the driver side so maybe power steering?
Old 12-03-2023, 01:57 AM #6
Endlessblockades's Avatar
Real Name: Blair
Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold
Real Name: Blair
This may be off the mark, but poorly lubed drive-line joints and double-cardans can make a wide variety of hard-to-diagnose squeaking, whistling, and whining noises. I was sure I had belt or internal transmissions issues until I came across a thread like this one and got things lubed up: Drive/Prop Shaft Greasing Guide
Been silent ever since. Just a thought.
Old 12-03-2023, 11:00 AM #7
alumarine alumarine is offline
alumarine has a spectacular aura about alumarine has a spectacular aura about
What does that mean?
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
alumarine is offline   Reply With QuoteReply With Quote
Old 12-03-2023, 02:56 PM #8
DK327's Avatar
DK327 DK327 is offline
DK327 is on a distinguished road
DK327's Avatar
I've had a similar noise while accelerating that would only appear in cold weather. It turned out to be my alternator pulley; I've since put in a CS144 using the same belt and it's been solid.
00 T4R LTD V6 4WD 275K e-locker
11 RAV4 LTD V6 4WD 100K
DK327 is offline   Reply With QuoteReply With Quote
Old 12-03-2023, 10:28 PM #9
whats different about that alternator?
Old 12-03-2023, 10:29 PM #10
hmm i'll take a look
Old 12-03-2023, 11:11 PM #11
just watched a video of a whining alternator and the guy removed the harness while it was running and the whine went away. Mine wasn't as loud as the one in the video but sure enough it was quieter. I still here a whirring when accelerating but i had the hood open so idk. Guess i'll put an alternator in there and see what happens.
Old 12-05-2023, 06:54 PM #12
Real Name: Jerod
Real Name: Jerod
Manually open the throttle valve with your hand with the engine running and hood open. It's the spring loaded thing here. Just rotate it and it'll be just like pressing the gas. Should help with finding the noise.
326WHP 347TQ
Old 12-06-2023, 03:08 AM #13
good point i know where that is, didn't even think about it.
Old 12-07-2023, 10:34 AM #14
DK327's Avatar
DK327's Avatar
It has more amps to drive winch, amp, comms equipment etc. There is a whole thread about CS144 swap as well as big 3 upgrade; replacing oem wiring with thicker gauge for better performance.
In addition to the noise being gone, it sure is nice seeing constant 14.6V and no more corrosion on battery's positive terminal. It was definitely time to replace mine.
Old 12-08-2023, 05:14 PM #15
Ben Dejo Ben Dejo is offline
Ben Dejo is on a distinguished road
Have you recently had the timing belt replaced? Now that its colder out, in the morning, one of the bearing for the idler, or tensioner, or water pump could be squealing like mine just started doing. I had my timing belt replaced a few months ago. The noise goes away after a few miles after things warm up on mine. These parts are very close in relation to the alternator and the power steering pump. Just one of the many possibilities.
Ben Dejo is offline   Reply With QuoteReply With Quote
glass , higher , noise , pitched , water
2020 4runner started making a squealing noise KingsCrossing 5th gen T4Rs 22 05-18-2020 04:16 PM
2020 4runner started making a squealing noise KingsCrossing 5th gen T4Rs 0 05-05-2020 03:44 PM
Getting started in AL - 5th Gen latha024 New Members 2 12-01-2013 11:34 PM
Just getting started ko31motoX 3rd gen T4Rs 18 11-06-2013 01:19 PM
