Old 12-02-2023, 10:45 PM #1
Outrider Outrider is offline
Outrider will become famous soon enough
"D" dash indicator stopped working
All other (P, R, N, etc.) indicator lights on my dash work, but the D stopped. It has been years since I had my dash apart, I don't recall the bulb layout, and I thought it seemed weird that each gear had its own bulb. I did a search here, but found nothing at all. I did a general web search and found some other T4R forum that had a thread about this problem. It seems that the Park/Neutral Position Switch sends a signal to the proper indicator bulb. I read that this switch can get flaky, and sometimes fixed by loosening it, wiggling it, then re-attaching it. Trouble is, I haven't found where this sensor is located.
Before I crawl under there and start poking around, has anyone on here had this problem and solved it, and can someone tell me where the Park/Neutral Position Switch is located on the transmission? If it seems likely that this may fix the problem, I will try it before I try to pull apart my dash in cool weather, when plastic is more likely to crack.
This is a real easy problem to ignore, but I tend to treat my vehicles like aircraft, and want every single thing functioning 100%.
'99 SR5 V6 2WD named Jolene / In the T4R 200 Club
Outrider is offline   Reply With QuoteReply With Quote
Old 12-03-2023, 02:37 AM #2
Endlessblockades's Avatar
Real Name: Blair
Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold
Real Name: Blair
Could it simply be that since the D bulb is the one that is illuminated much more than any other, it might burn out first? Mine was already done when I bought my 2000 about 4 years ago.
Edit - I was looking at a dash light thread from 2009 and came across this quote:
" Funny thread... The 'D' light is out on a majority of Land Cruisers, and most people prefer that so the light isn't shining in their eyes at night while driving. Every other light in the stack works exc. the 'D'.
Cruiser owners consider it a 'feature'...
Old 12-03-2023, 04:35 AM #3
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
Bought my 01 in 17 and that bulb was burnt out.
Worried about plastic turn the heat on high won't be long till flip flops shorts T shirt weather. Windows closed of course.
Old 12-04-2023, 03:15 PM #4
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
It's the instrument cluster bulb for "D" not the switch.
Old 12-04-2023, 05:06 PM #5
I will try a bulb, first. Does anyone have a link to a good, reliable bulb chart or search wizard for these vehicles, or already happen to know which bulb # is needed for D? I didn't find much on that, except a bunch of clickbait BS sites that told me nothing useful.
Old 12-04-2023, 05:14 PM #6
Move the "L" bulb to the "D" position... It should be a '74' sized bulb, but search the LED swap threads for more clues.
It burns out faster because it is both used the most *and* it is run at low power when the lights are on. Both will wear the bulb more.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 12-04-2023, 07:56 PM #7
Real Name: Mark
Real Name: Mark
CEC 1.2W 12V 0.10A Mini T1.75 Bulb | 2721 | Bulbs.com this is the bulb that is the exact same as what is in there now.
The #74 bulbs are larger and don't fit bulb socket as well. I purchased this 10 pack and changed all of them while in there.
Old 12-04-2023, 09:19 PM #8
Thanks for the link. I will also replace them all, while I am in there.
Old 12-04-2023, 09:51 PM #9
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Replace the bulb. Don't overthink it.
Old 12-05-2023, 08:58 AM #10
Real Name: Mark
Real Name: Mark
No problem I like passing stuff along when I can. Beats the $3-5 each at dealer.
I used a dial caliper to find the correct bulb after trying the 74 that popped out of socket requiring a redo.
bulb , dash , found , problem , switch
High Beam indicator on dash not working. Trapper-Randy74 3rd gen T4Rs 3 10-20-2020 08:23 PM
dash lights stopped dimming on headlight "on" drapaki 4th Gen T4Rs 6 02-24-2014 03:18 AM
Dash lights stopped working 02gtfromky 3rd gen T4Rs 2 11-28-2013 02:58 PM
Dash control for tailgate window stopped working delucat2 4th Gen T4Rs 7 12-05-2012 03:20 PM
I noticed today the "Slip Indicator" light didn't come on at start up... Jeff T 4th Gen T4Rs 7 12-18-2011 01:43 AM
