Old 12-03-2023, 10:42 AM #1
TX4Running's Avatar
TX4Running TX4Running is offline
TX4Running is on a distinguished road
TX4Running's Avatar
Brake job - no shims
Yesterday, I replaced the rotors and pads. I did the 231 mm TBU years ago. I used a screwdriver to compress the calipers as much as I could with bleeder open. After replacing rotor and caliper, I could not get the pads in with shim kits installed. It was hard enough to get the pads in without shim kits. I now have brakes installed with no shim kits.
Is there an easy way to get the calipers to compress a bit more to add shim kits? With new rotors and pads, I don't want to use the screwdriver again.
James
2001 4Runner SR5 4WD - 231 mm TBU, B&M 70264 external transmission cooler, Magnefine external transmission filter
TX4Running is offline   Reply With QuoteReply With Quote
Old 12-03-2023, 11:54 AM #2
_Ace_'s Avatar
_Ace_ _Ace_ is offline
_Ace_ will become famous soon enough
_Ace_'s Avatar
I use an old pad against the pistons and compress them (with the master cylinder cap off & some fluid removed) with a large C clamp.
Position the C clamp between the two pistons on the pad and slowly compress. The pistons should go into the caliper evenly and as they compress fluid will return to the master cylinder reservoir.
As you compress remove old fluid with a syringe.
1998 SR5 - 5 speed w/ 4.30 E-locker
My 1998 SR5 Build Thread
_Ace_ is offline   Reply With QuoteReply With Quote
Old 12-03-2023, 01:35 PM #3
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
yep...thats how I do it too
2002 tundra ac v8 4wd
1969 kharmann ghia
Old 12-03-2023, 01:50 PM #4
TX4Running's Avatar
TX4Running's Avatar
I assume you are doing this with the caliper removed? I should be able to pull the new pads out, pull the caliper off, and use the old pads to compress, correct?
The videos I watched show the compression via screwdriver (unconcerned with damage to rotor as they are being replaced) with the calipers still installed. I thought I compressed them as far as they would go. Then, out of frustration, I managed to squeeze the pads in without the shims. Thanks.
James
Old 12-03-2023, 02:03 PM #5
_Ace_'s Avatar
_Ace_'s Avatar
Yes, calipers removed.
Never tried it with them installed.
Old 12-03-2023, 03:59 PM #6
Endlessblockades's Avatar
Real Name: Blair
Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold
Real Name: Blair
Another C-clamper here. Hopefully you are using a caliper-hanging hook of some kind, too.
262K - Y2K/E - Clock still works
Old 12-03-2023, 05:01 PM #7
TX4Running's Avatar
TX4Running's Avatar
Thanks all. I went back and redid them. Used C-clamp with caliper removed. Used zip ties to hold up with brake line still attached. Still a very tight squeeze with new pads and rotors, but success.
James
Old 12-03-2023, 05:32 PM #8
Real Name: Blair
Real Name: Blair
Were you able to get the anti-squeal shims to fit?
Old 12-03-2023, 07:09 PM #9
TX4Running's Avatar
TX4Running's Avatar
Yes, shims on. It was very tight, but was able to get them on and have driven with no issues.
James
calipers , installed , kits , pads , shim
rear brake shims? shahsmerdis 4th Gen T4Rs 9 09-17-2015 10:18 AM
Front brake pads - how many shims? nysimonsez 4th Gen T4Rs 10 08-06-2014 08:58 PM
Tundra Brake Pad - Anti-squeal shims sggaz 3rd gen T4Rs 5 07-03-2014 07:45 PM
part# for Front brake pad shims for 07 4runner popalzai 4th Gen T4Rs 1 03-29-2012 02:50 PM
Do I need brake pad shims for 199mm Tundra upgrade? PA Pat 3rd gen T4Rs 1 06-29-2011 02:27 AM
