Old 12-04-2023, 02:23 PM #1
Previologist Previologist is offline
Previologist is on a distinguished road
low speed driveline click
97 4WD 5-speed
Started noticing a repetitive ticking/clicking at very low speeds, just before I stop. Seems to be coming from the middle or aft of the middle. Jacked up the rear end and no noise when spinning the rear wheels. But when I twist the rear driveshaft I get a sound that is very much like what I hear at slow speeds. It does not seem to be the u-joints, they seem tight. There is play at both ends of the shaft when I twist it, and the sound seems to be coming from the transfer case although there is a lesser sound at the rear diff. Is the play normal? Any idea on what it could be? Everything works as it should, including 4WD. I'm not 100 sure this is the same sound I'm hearing when its moving.
Haven't had time to check the gear oils yet.
Previologist is offline   Reply With QuoteReply With Quote
Old 12-04-2023, 03:16 PM #2
thennen's Avatar
thennen thennen is offline
thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold
thennen's Avatar
When is the last time the propeller (drive) shafts were greased?
thennen is offline   Reply With QuoteReply With Quote
Old 12-04-2023, 03:21 PM #3
Late spring/early summer. But it doesn't seem like the noise is coming from the shaft itself, though I could be wrong and often am.
Old 12-04-2023, 03:40 PM #4
thennen's Avatar
thennen's Avatar
Just thinking that since turning the shaft reproduces the sound.
Old 12-04-2023, 03:52 PM #5
Devbot's Avatar
Devbot Devbot is online now
Real Name: Devan
Devbot's Avatar
Real Name: Devan
If the needle bearings in the u-joint caps start to go they'll make a clicking sound. You could put all four wheels on jacks, put it in drive and listen underneath while it idles to get a better idea.
If you still have an OEM driveshaft and a u-joint is shot in the double cardan, you're gonna want a new driveshaft from a driveline builder like Tom Woods as they're next to impossible to service. If it's at the pinion then you lucked out.
Devbot is online now   Reply With QuoteReply With Quote
Old 12-06-2023, 02:10 PM #6
Actually the sound I reproduced seemed to be coming from the transfer case and/or rear diff just as they were engaged, and I wasn't rotating the shaft I was twisting it back and forth (it was in gear)
middle , play , rear , sound , twist
V8 starter click, click VOOORRROOOOOOMMMM!! alia176 4th Gen T4Rs 3 08-14-2018 01:42 PM
Speed over-reporting speed with stock tires? dieck 5th gen T4Rs 19 06-05-2015 04:12 PM
Click Click Click....then slowly starts?? MSBX4RUNNER 4th Gen T4Rs 8 11-10-2011 02:51 PM
Starter Click, Click, Click. Jump starts immediately??? daugherty83 3rd gen T4Rs 17 09-18-2009 03:46 AM
RPM differences between 4 speed Auto and 5 speed standard? kenlam 3rd gen T4Rs 2 10-14-2005 09:32 AM
