Old 01-31-2022, 03:47 AM #1
NotALakerFan NotALakerFan is offline
NotALakerFan is on a distinguished road
light grinding sound when accelerating up to 35mph?
It goes away in idle, or coasting above 35 mph, but it sounds like it's coming from the front. I recorded the sound and it's posted here (not sure if linking to reddit is allowed):
Can anyone help me identify this sound? Very light grinding almost sound.. : 3rdGen4Runner
Does anyone know what it could be?
NotALakerFan is offline   Reply With QuoteReply With Quote
Old 01-31-2022, 10:21 AM #2
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
I can't hear much on vid but you say no 'noise' at idle.
Is that sitting still idle or rolling idle?
Guess you've checked the obvious like front brake shields?
If 4WD, sometimes the TC's rubber noise damper is loose.
All fluids up to spec?
2001 Limited 4WD - 349+K - SunfireRed\Thunder Cloud; - 265/75/16 Michelin A/T2s - Fat Pat's 1.5" BL - StopTech ANGLED rotors - In series 699 trans cooler, New Yota1 transmission, All new OEM suspension front to rear.
Old 01-31-2022, 01:06 PM #3
At both rolling and sitting idle, anything over 35 also makes the sound go away.
And I haven’t really checked anything, just haven’t driven it much. I’m mechanically super limited so it’s frustrating trying to figure out what might be basic checks for others. I have little to no clue
Old 01-31-2022, 01:21 PM #4
jgue467's Avatar
jgue467's Avatar
Well that narrows it down some. It could be many things like a heat shield a little loose or some worn suspension item.
If you are very limited perhaps you should take it to a trusted mechanic?
Old 01-31-2022, 04:38 PM #5
Yes I need to find someone to take a look. Wanting to learn since so many here are so able to work on their cars themselves and diagnose things but I guess that’s my expense for not knowing haha
Old 01-31-2022, 04:47 PM #6
Endlessblockades's Avatar
Endlessblockades Endlessblockades is online now
Real Name: Blair
Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold
Real Name: Blair
As an aside - I removed my TC harmonic damper when I noticed the rubber section that connected the weight to the mounting bracket was torn anyway. I also suspected it rubbed on my TC skid. I don't often hear much about the device on the forum other than the 'what is this thing?' threads. Other than the fact that they are there for a reason, do you have an opinion on their need?
Endlessblockades is online now   Reply With QuoteReply With Quote
Old 12-08-2023, 07:00 PM #7
Ritchierunner's Avatar
Ritchierunner Ritchierunner is offline
Ritchierunner is on a distinguished road
Grinding when accelerating
Hey, I’m getting this grinding/buzzing sound when I accelerate in my 98 limited. It sounds like it’s coming from the passenger side engine bay and I can feel it in the gas pedal when letting on and off the gas. This all happens after around 30mph. I tried the gas when in park and I didn’t get the sound. I also tried putting on the gas in drive while on the brake at the same time and didn’t get it, and did the same in reverse. I watched the engine when I did it to see if it was jumping around, and it wasn’t. I’m wondering if my sound is similar to anything y’all have come across and maybe have some ideas of what it could be. I posted a video to YouTube of the sound. I’ll include the link
1998 4Runner limited making loud grinding/buzzing sound when accelerating - YouTube
Ritchierunner is offline   Reply With QuoteReply With Quote
Old 12-10-2023, 10:31 AM #8
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Sounds like a loose exhaust or heat shield to me
light , linking , recorded , reddit , sound
Rattle sound when accelerating 4RunnerMD 3rd gen T4Rs 22 02-20-2023 01:04 PM
Rattling sound only when accelerating T4RunnerSteve 3rd gen T4Rs 64 08-16-2021 12:28 PM
Grinding while accelerating rfuree11 4th Gen T4Rs 3 02-19-2017 02:44 AM
Grinding Sound When Accelerating JerkyDrewster 3rd gen T4Rs 4 09-11-2015 11:41 PM
out of nowhere, awful clicking sound when accelerating. roguestriker Classic T4Rs 6 10-31-2012 03:53 PM
