Old 05-16-2024, 02:50 PM #16
I made my own custom bus bar off the side of the battery, like this:
It runs aftermarket lights, trailer brakes/power and the winch. If the (3x paralleled) breakers fail for the winch (trip, whatever), it is easy to bypass them.
You can probably mount something right there using a stiff bus bar...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 05-17-2024, 03:57 PM #17
GhostRing's Avatar
GhostRing GhostRing is offline
GhostRing has a spectacular aura about GhostRing has a spectacular aura about
GhostRing's Avatar
Probably get some shiz for this, but gotta ask...
I'm getting closer to installing my BS 6006 and want to simply cut/shorten the X20 Winch pos. cable
and add new lugs to the cut ends. It seems the wire may be 3AWG (25 sq mm) Since I have way more
likely access/use out of 2 AWG lugs, can I simply add some strands into a 2 lug to fill it out for the 3 wire?
The diameter difference according to AWG chart looks like this:
2......0.258"......6.54mm......33.6mm Cross Sec.
3......0.229"......5.83mm......26.7mm Cross Sec.
I'd be using a Temco hammer crimper in my 20T press, so an extra baby squeeze should be enough to set the weld, ya?
Am I over-thinking this, or do I really need to get 3G lugs to avoid a .71mm catastrophe?
Build Etc...
If it ain't broke, fix it 'til it is.
GhostRing is offline   Reply With QuoteReply With Quote
Old 05-18-2024, 12:19 PM #18
2TH4IST's Avatar
2TH4IST 2TH4IST is offline
2TH4IST is a jewel in the rough 2TH4IST is a jewel in the rough 2TH4IST is a jewel in the rough
2TH4IST's Avatar
I'd say more then likely the x2o winch cables are 2awg. 3 awg is pretty uncommon. You can use wire as a filler but you have to make sure it's a damn good crimp. Never use a connector the other way around, don't cut strands to make it fit in a connector.
Eta - somewhere on the wire there should be a marking, either stamped into the insulation or printed on it. Also the winches instructions in specs it should list the wire awg.
There's danger lurking around every corner, that's why I propose we make all of our buildings round.
I don't remember the time I was human that's why I don't understand anybody.
2TH4IST is offline   Reply With QuoteReply With Quote
Old 05-18-2024, 05:44 PM #19
GhostRing's Avatar
GhostRing's Avatar
Gotta remember where this thing was made..!
I'm just going by the lugs which have "25-8" stamped in.
Assuming that is mm area + stud/hole size (no marks on cable)
That can only help flexibility due to where I want to smush this thing,
as the cables will need a pretty precise angle to be happy.
Build Etc...
Old 05-21-2024, 02:06 PM #20
25mm2 is what they call out on their website... so that seems like a fair assumption.
Old 05-21-2024, 04:18 PM #21
GhostRing's Avatar
GhostRing's Avatar
See what happens when I actually RTFM?
I went right past the main description and went to the installation .pdf
but was too focused on amp draw I guess. I know this seems like such
a remedial situation, but thank y'all for just checking my work ;)
Build Etc...
amps , case , shorts , thinking , winch
fuse block, circuit breaker, and relay question 1996T4runner 3rd gen T4Rs 6 02-27-2021 10:57 PM
Circuit Breaker Amperage Question ToyDB Engines / Suspension / Wheels / Tires / Audio / Accessories 16 04-16-2020 10:21 PM
Need help with aux fusebox / circuit breaker / relay setup trailtruck Engines / Suspension / Wheels / Tires / Audio / Accessories 24 11-13-2019 05:48 PM
FS: Blue Sea 120A circuit breaker, $30--San Antonio, TX papabeach For Sale: Non-T4R Items 1 06-17-2017 09:19 AM
