Old 01-18-2024, 10:16 AM #16
1-2 Minutes truck loses some power 3rd Gen :hunter:
Originally Posted by DirtyDoctor View Post
What does that mean? Up to temp?
At cold start the engine uses adaptive and fixed parameters to start the engine and then keep it running. (Adaptive being things like IAC position for given engine and air inlet temp for a desired rpm) (fixed being things like fuel and spark maps).
As soon as the ECU sees a valid input from the front O2 sensor (voltage creeps up to around .85vdc) it goes closed loop and starts the enrichment warmup process where you will see the O2 voltage cycling high low. Starting around 10:1af and slowly going up to 14.7:1.
Until the engine hits around 130-140 it’s running 13:1 or less and that makes more power.
1-2 , fuel , minutes , sensor , truck
4th gen loses power while driving JailbreakOverlandr 4th Gen T4Rs 2 03-30-2023 11:57 AM
While in 4WD HI, occasionally/randomly loses power when trying to accelerate sugjavier 3rd gen T4Rs 1 11-13-2017 02:36 PM
2012 4Runner: Loses all electrical power chasec11 5th gen T4Rs 4 06-18-2013 12:49 AM
Help, engine loses power intermittently neffmoore 3rd gen T4Rs 3 08-27-2010 01:03 PM
Posting Intervals is 2 minutes and Editing 15 minutes limit?? Thai General Discussions 22 04-08-2009 11:48 PM
