Old 12-17-2023, 06:24 PM #1
alumarine alumarine is offline
alumarine has a spectacular aura about alumarine has a spectacular aura about
Lug nuts for Steel Wheels
Just picked up a good used set of Nokian Hakkapeliitta R2 SUV winter tires on steel wheels.
Is it ok to use the wheel nuts that I use with my aluminum wheels?
Lug nuts for Steel Wheels-steel-wheels-lug-nuts-aluminum-wheels-jpg
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
alumarine is offline   Reply With QuoteReply With Quote
Old 12-17-2023, 09:54 PM #2
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Depends on what seat pattern the wheels are. There are 4 different lug nut/seat patterns if I remember - acorn/tapered, extended tapered, washer/flange nut, and ball/round.
Old 12-18-2023, 01:09 AM #3
pluton's Avatar
pluton pluton is offline
Real Name: Keith
pluton has a spectacular aura about pluton has a spectacular aura about pluton has a spectacular aura about
pluton's Avatar
Real Name: Keith
Last I checked, you can get official Toyota tapered lug nuts, which are recommended for the OEM tapered steel wheels. The owner's manual says you can use the flat washer nuts on the steel spare, but I got a set of steel nuts for use on my spare if I need it.
pluton is offline   Reply With QuoteReply With Quote
Old 12-18-2023, 03:18 PM #4
This - the OEM flat-washer lug nuts have a small taper seat for temporary spare use. Get a set of standard lug nuts for longer-term use.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 12-18-2023, 03:20 PM #5
My spare is now a 16" late first gen Tacoma/early Tundra aluminum wheel now, so no worries since the lug type matches...
Old 12-19-2023, 06:20 PM #6
Thanks for the info.
Looks like most lug nuts that are 12x1.5 - with a 60 degree conical will work.
I ended up getting them mounted on a spare set of factory aluminum wheels I had in stock.
lug , nuts , steel , tires , wheels
Winter steel rims, which lug nuts? Buba1 5th gen T4Rs 7 10-23-2021 07:35 PM
Pro comp steel wheels and lug nuts Dezerts10 Engines / Suspension / Wheels / Tires / Audio / Accessories 5 01-02-2018 01:56 PM
Lug nuts for steel spare? LargeOrangeFont 5th gen T4Rs 2 04-11-2017 06:01 PM
Tundra Steel Wheels with Hub Caps and Lug Nuts (Santa Cruz, CA) $250 SCRunner12 For Sale: Suspension/Wheels/Tires 0 01-14-2014 11:54 PM
