Old 12-24-2023, 05:32 PM #16
cthomsen99 cthomsen99 is offline
cthomsen99 is on a distinguished road
I had similar symptoms in a 99. New injectors solved the problem.
cthomsen99 is offline   Reply With QuoteReply With Quote
Old 12-24-2023, 10:28 PM #17
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Originally Posted by BabeGTR View Post
Update:
Still misfiring once warm
-Replaced #5 plug with identical NGK
-Disconnected each of the 3 passenger side fuel injectors and ohm tested:
-2 good cylinders were 15.6
-#5 showed 18.6
-Cleaned MAF
Thoughts?
I think you've done all the diagnosis you possibly can. It's not spark, so it's fuel. Time to replace the injector.
If you had bad compression, the problem would be there all the time and not intermittently. No need for a compression check.
326WHP 347TQ
Old 12-25-2023, 12:00 PM #18
MaineRunna's Avatar
MaineRunna MaineRunna is offline
MaineRunna will become famous soon enough MaineRunna will become famous soon enough
MaineRunna's Avatar
I doubt it is a head gasket, more likely to misfire cold and would be using coolant. Could do a leak down test or hydrocarbon test to confirm. Almost definitely not a mechanical issue like a valve spring. Not going to be the cam sensor either. You have for the most part ruled out an ignition problem so it almost has to be a bad fuel injector. Overall I don't replace a lot of fuel injectors on any model vehicles, but I have replaced quite a few injectors on the Toyota 3.4L. One thing to do is listen to the injectors with a stethoscope, they should have a nice solid metallic clicking noise when operating properly. You could possibly have a wiring or ECM problem, but highly unlikely.
98 SR5 4X4 5spd, desert dune metallic, Toytech Eibach 3" lift, 1" body lift, RAD Rubber Designs splash guards, 4XInnovations bumpers, Doug Thorely Headers, Magna-flow converter, JBA muffler & tail pipe, RCI skid plate, SPC UCA's & rear LCA's, front sway bar links on rear, gen II rear links on front, Tundra brakes, '02 headlights, tail lights & sidemarkers, BFG 255/85R16 Mud Terrain T/A's 241,000 miles.
MaineRunna is offline   Reply With QuoteReply With Quote
Old 12-26-2023, 03:19 PM #19
BabeGTR's Avatar
BabeGTR BabeGTR is offline
BabeGTR is on a distinguished road
BabeGTR's Avatar
Thanks for all the replies. I discovered an exposed wire on the #5 coil connection. Looks like a past mechanic tapped into it and soldered a lead in wire. The electrical tape degraded to the point I could see it. I removed the tapped in wire, heat shrunk then taped it up some more, cleared the CEL, it ran well when cold, slight sputter returned after restart. Waiting for the code to return, as I have borrowed an improved OBD II that can do diagnostics.
2000 V6 - Intermittent misfire cylinder #5-coil-connection-jpg
Black 2000 4x4 SR5 - 176k miles
BabeGTR is offline   Reply With QuoteReply With Quote
Old 12-28-2023, 05:03 PM #20
BabeGTR's Avatar
BabeGTR's Avatar
Update: After repairing the wiring into the #5 coil, the CEL has not returned. It does however still mis-fire, but now it takes a couple of hot starts to return.
Old 01-10-2024, 01:28 AM #21
BabeGTR's Avatar
BabeGTR's Avatar
Solved. It was the #5 injector, replaced and back in shape.
ago , cylinder , engine , plugs , wires
intermittent misfire... lord rigatoni 3rd gen T4Rs 16 09-27-2022 10:26 AM
Intermittent hot misfire help! alwaysbored786 3rd gen T4Rs 13 03-20-2019 10:43 AM
Intermittent Stumble/Misfire? LeeMajors 3rd gen T4Rs 15 08-07-2016 12:20 PM
Intermittent misfire Gen 2 V6 BlackRiverRat Classic T4Rs 3 04-19-2014 07:15 AM
Cylinder one misfire error code without the misfire MJW 3rd gen T4Rs 4 05-03-2012 09:07 AM
