Old 12-27-2023, 12:36 PM #16
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
Originally Posted by 19963.4lsr5 View Post
I keep a voltmeter in the cig lighter to monitor. 11.3 is low at key on. But I’ve seen 10vdc start the engine.
It’s your call. Have the battery load tested and if it fails replace it. What is your system voltage driving? Are you driving it enough to charge the battery?
You’re in an extreme environment.
11.3 is what I see on torque pro when driving, about 11 at idle. Alternator is a denso rebuilt put in last fall.. Battery is 3 years old. i have read that torque pro reads low
this time of year car is plugged in 2 hours b4 going to work and at work 2 hours b4 i leave. not only do I have heaters but a trickle charger on battery.
Old 12-27-2023, 04:19 PM #17
starter dragging
Put a voltmeter on the battery posts and look at the voltage with engine running. Also from the output of the alt to ground. That voltage will make a starter click for sure.
I never heard torque pro reading low. Let alone 3vdc low during normal operating conditions. The volt reading is the voltage from the OBD2 port.
Hit your alt with a hammer. If your voltage goes back to normal, your brushes are worn or were stuck.
Old 12-28-2023, 12:21 PM #18
Real Name: 3 Bears
Real Name: 3 Bears
never had a chance to put meter direct, before it was towed. For sure low voltage can make a starter click, but the starter was dragging ( kept going wiht engine running) and some times not even start or click and then a few minutes later would start. Im not sure low voltage would cause that. Sadly not the other night. So towed
maybe I have both going on. Starter and alternator
Old 12-29-2023, 12:58 PM #19
Real Name: 3 Bears
Real Name: 3 Bears
new starter in and old one must have been draining the system when running, because wiht new one in ( rebuilt) im back to 12 and 13 volts on my torque app
Old 12-29-2023, 01:43 PM #20
starter dragging
In cold weather you should be 14+ volts. In my area I’m 14.1-14.3 at my cig lighter and on my ScanGauge.
Read your voltage at the battery and alt output to ground and to the negative terminal.
Old 12-29-2023, 02:08 PM #21
BuffaloBass BuffaloBass is offline
BuffaloBass is on a distinguished road
In ALL weather and all 12v systems checked at a high idle ought be pushing 14.2V -ish. Euro/US/Asian.
PS my "daily activity" on the 99 4rnr is squaring away this leaky azz mess: ( well, basically doing a full mechanical resto - why not?!)
starter dragging-toyo-head-leak-jpg
BuffaloBass is offline   Reply With QuoteReply With Quote
Old 12-30-2023, 02:43 PM #22
dragging , minutes , problem , read , starter
brakes dragging on my 99 Help Johnnie 3rd gen T4Rs 11 04-14-2023 09:22 PM
Brakes Dragging? FlyNavy 5th gen T4Rs 7 04-14-2011 03:02 PM
95 brakes dragging slipknoter106 Classic T4Rs 1 03-20-2011 11:12 AM
'97 Limited - ass-dragging mgwold Engines / Suspension / Wheels / Tires / Audio / Accessories 10 08-27-2006 06:04 AM
Dragging feeling Pepi 4th Gen T4Rs 8 06-16-2006 11:19 AM
