12-30-2023, 04:34 PM
Real Name: Kevin
Real Name: Kevin
"Transmission Relay" in the passenger kick panel
Short post: Looking for a wiring diagram for a 1999 SR5 Highlander V6 auto, I need to know what specifically signals that relay and where to find it.
Long post: wife's '99 is doing this thing where she hears an almost constant but random clicking from that kick panel, and an also-random violent clunk from the drivetrain while rolling. Neither happens when the truck is in 4WD, and neither happens while that relay is unplugged. I've replaced the relay and it's still doing it, so I'm guessing that something else is triggering it, but I don't know what. I could use that diagram if anyone has it, or knows what component is triggering that relay and where the wires run.
'My needle always settles between west and southwest. The future lies that way to me, and the earth seems more unexhausted and richer on that side.' - Thoreau, sort of.
The Grey Bastard, 1985 4Runner, driveway ornament.
Utah DesertRunners T4R, for all things wheeling and 4Runner in Utah.
01-01-2024, 10:20 AM
So the diagram is not in the FSM?
01-01-2024, 12:42 PM
Real Name: Kevin
Real Name: Kevin
Not the link I have. Is there a better one?
https://www.teamtoyota4x4.org/archiv...mci/0394wd.pdf is pining for the fjords.
01-01-2024, 02:09 PM
The FSM doesn’t have the wire diagrams. It’s a separate book. EWD
01-01-2024, 02:56 PM
That relay is triggered by a switch in the side of the transmission. They are a pain to get to. Possibly unplugging it would at least keep it from triggering but you would lose 4wd until fixed.
2000 Limited w/ rear locker
-Dobinsons IMS, JBA UCA, Whiteline Bushings
2000 SR5 4WD Auto w/ J Shift
-Stock Beater
01-01-2024, 03:02 PM
Real Name: Kevin
Real Name: Kevin
This is what I was looking for, thanks! Do you know the name of the switch? Is it IN the trans or on the outside somewhere?
01-01-2024, 10:47 PM
Originally Posted by KidVermicious
I know you found your answer yet I do see wiring diagrams in the version of fsm i have, shared here (way towards end):
Complete 4Runner Service Manual 1996-2002.pdf - Google Drive
01-02-2024, 02:15 PM
The relay that is clicking is called the ADD Relay. It runs the front differential disconnect (Automatically Disconnecting Differential), and that name will help with your search for answers.
On the SR5's, it is a very simple system. A switch on the transfer case drives the ADD relay coil, which powers two VSVs (Vacuum Switching Valves) in the engine bay that use vacuum to move an actuator on the front differential. When that is complete, a position switch in the front differential lights the 4WD light on the dash.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
01-02-2024, 03:40 PM
Real Name: Patrick
Real Name: Patrick
Are you talking about the range switches on the transfer case?
01-05-2024, 06:24 PM
The switches I'm referring are the following part numbers in this diagram. Not sure which one does what though.
8422235110
8422235080
8422235090
Just a moment...
-Stock Beater
01-06-2024, 09:10 AM
I looked up the first one on ickbay, its a switch transfer indicator.
https://www.ebay.com/itm/35258418747...Bk9SR-6E8O6bYw
01-08-2024, 11:19 AM
Real Name: Patrick
Real Name: Patrick
8422235110
8422235080
8422235090
Just a moment...
Those are on the transfer case not the transmission.
01-10-2024, 07:33 PM
Apologies.
-Stock Beater
