Old 12-31-2023, 04:46 PM #1
str8flexed's Avatar
str8flexed str8flexed is offline
str8flexed is on a distinguished road
str8flexed's Avatar
Radiator flush quick question - drained fluid only warm not hot after 20min
Quick question. In the middle of a full radiator flush. After draining 8L, filled the radiator up with distilled water and idled with the engine on for 20-25 minI also went and feathered the accelerator a bit.
When I opened the valve on the bottom to drain, I was curious and touched the water. It was lukewarm at best.
Any ideas? I thought it was supposed to be piping hot. Makes me think something is wrong. Did the thermostat not open? Maybe I should just put the radiator cap on and go for a drive? I kept the engine on while having the fluid in a funnel, not pressurized with a cap.
2017 TRD Off-Road Premium: Dobinsons lift, Icon UCA, Gobi Stealth, Cooper AT3 XLT 295/70r17, Race Relations Wheels -12 offset 8.5”, CBI front bumper, Xenon HID headlights, RCI skids, RSG sliders, Focal 690TOY front speakers, Kicker DS rears
str8flexed is offline   Reply With QuoteReply With Quote
Old 01-01-2024, 10:16 AM #2
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
What was ambient temp? I think 20-25 idle mins should raise temps to normal, 190s allowing thermo to open, its probably lukewarm because that is the coolest part coming out first, the hotter water is entering at top.
Did you turn on the heater to allow that water to move out also?
Old 01-02-2024, 02:37 PM #3
Idling on a cool day? There's a good chance the bottom side of the rad is pretty cool. If the upper radiator hose is hot, the thermostat is opening.
Why not just go for a drive? You can run weeks with just water in there (maybe put in some watter wetter or similar if you are going to run for any reasonable time). I've done that on other projects when I'm checking for leaks and other performance issues and I don't want to waste coolant...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
engine , fluid , flush , quick , radiator
Power Steering Flush and Fluid question atalarico 4th Gen T4Rs 11 02-13-2019 07:15 PM
Quick 15-minute 5-speed W59 manual transmission fluid flush DIY verbutani 3rd gen T4Rs 9 12-12-2017 04:52 AM
Radiator & Trans fluid flush PoshSnoop 3rd gen T4Rs 6 09-18-2017 01:45 PM
New Radiator with Coolant Flush? Power Steering Fluid Flush, and Brake Fluid Flush? jdotlim 4th Gen T4Rs 4 09-17-2017 07:52 PM
quick question on refilling radiator fluid amalik 3rd gen T4Rs 8 10-28-2013 03:42 PM
