hope this helps
REMOVAL & INSTALLATION
NOTE: Replacing the starter while the engine is cold is recommended. A hot engine can result in personal injury.
Disconnect the negative battery cable.
Remove the nut and disconnect the battery cable from the magnetic switch on the starter motor.
Disconnect the remaining electrical connections at the starter.
Remove the nuts and/or bolts securing the starter to the bell housing, then pull the starter toward the front of the vehicle to remove.
To install:
Insert the starter into the bell housing being sure that the starter drive teeth are engaged with the flywheel teeth, not jammed against the flywheel.
Tighten the attaching hardware to 29 ft. lbs. (39 Nm) and replace all electrical connections.
Fig. 1: Exploded view of a common starter mounting found on Toyota trucks
[IMG]
~original[/IMG]
Connect the positive battery cable (starter wire) to the starter.
Connect the negative battery cable.
Never ask a girl if shes sick, she might not be wearing any make up. - lets just say she went storming off.
Never tell your wife she looks tired, they tend to hit and say that means she looks ugly. (weird logic i know)
