Old 01-11-2024, 09:07 AM #1
98Base4R 98Base4R is offline
98Base4R is on a distinguished road
Help with kid's car: No. 6 cylinder is dead, disconnect injector?
2002 3.4 started misfiring, running rough, CEL flicker 2 days ago. Compression is No. 6 cylinder is 75 PSI.
4Runner is my kid's car, he works full time and has a full class load at college. He needs to drive it until we can get it repaired. It will take a few weeks to find and install a replacement motor. I would like to disconnect the No. 6 injector, so fuel doesn't ruin the cat converter.
I have watched vids on removing the intake manifold to replace the injectors. Is there enough room under the intake to reach in and unclip the No. 6 injector? I need to take enough parts and tools to his apartment to get this done.
Any ideas and advice would be much appreciated!
02 4Runner SR5, 2WD, 250k, kid's car
98 4Runner Base, 2WD, 2.7L 4cyl, sold at 264k. Great truck, but the 4cyl just doesn't have enough power
98Base4R is offline   Reply With QuoteReply With Quote
Old 01-11-2024, 10:51 AM #2
spartacus's Avatar
spartacus's Avatar
Taking the plenum off would he the best bet. it's fairly simple and doesn't take much time. you can reuse the plenum metal gaskets.
Old 01-11-2024, 10:58 AM #3
Thanks, I appreciate the advice. If the metal gaskets can be re-used, I would only need these, right?
Help with kid's car:  No. 6 cylinder is dead, disconnect injector?-intake-gasket-jpg
Old 01-11-2024, 11:08 AM #4
spartacus's Avatar
spartacus's Avatar
Those are the metal plenum gaskets. Don't have to disconnect the throttle body from the top plenum. Disconnect the intake the vacuum hoses and the accelerator cables from the throttle body. Would be able to lift the top plenum off with the throttle body still attached to it.
Old 01-11-2024, 02:21 PM #5
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
If you mean under the plenum so you can do it without dismantling, not in your wildest dreams
It doesn't take very long to take off the plenum though. Working slow and unfamiliar it shouldn't take more than two hours to get it off, and that's being real generous. Once you're familiar with it it's non hassle at all. I just had to get to my injectors the other day and I think I had the plenum fully off in about 45 minutes tops, with most of that trying to reach those pain-in-the-ass 10mm hidden here and there.
Disconnecting the injector would be the right move, otherwise you're gonna be filling the crank case with fuel vapors - and that's when the real fun begins. If he drives it hard and for a while it might develop a knock, but if you're replacing the motor anyways that's hardly a concern.
cylinder , disconnect , full , injector , intake
MotorWest Injector Already Dead. (False Alarm) Devbot 3rd gen T4Rs 18 01-11-2024 09:57 PM
Dead miss - Fuel Injector? 86' 22re hikinout Classic T4Rs 16 07-12-2014 12:20 PM
Dead Cylinder Analysis ronbo613 Classic T4Rs 6 09-24-2008 04:12 PM
1995 V6 dead cylinder #3 ? IanBlondeau Classic T4Rs 1 04-10-2008 07:00 PM
Dead cylinder = Confused the_dingman Classic T4Rs 11 12-17-2007 09:09 PM
