Old 01-16-2024, 02:50 AM #1
sloscheider sloscheider is offline
sloscheider is on a distinguished road
How important is radiator replacement?
So my new to me 97 v6 4Runner has nearly 190k miles and I have no idea what previous maintenance has been performed. I’ve heard one report that the transmission coolers are known for developing leaks and flooding the tranny with engine coolant with catastrophic results.
Looks like about $200 in parts and supplies and a few hours of my weekend to replace it. Is this truly an issue or should I not worry about it? It’s got plenty of other issues to deal with but it runs well enough for my immediate needs and I’ll work on issues as I can.
sloscheider is offline   Reply With QuoteReply With Quote
Old 01-16-2024, 05:37 AM #2
SocalRunner15 SocalRunner15 is offline
SocalRunner15 is on a distinguished road
If your radiator fails, there is the possibility of it taking out your entire transmission. How does the radiator look? Does it look old and about to crack? There is also the option of routing the transmission to a separate radiator- this would prevent potential damage from happening as well as give the transmission superior cooling. Kits are around 100 dollars or so...
SocalRunner15 is offline   Reply With QuoteReply With Quote
Old 01-16-2024, 09:09 AM #3
OpenYota's Avatar
OpenYota OpenYota is offline
OpenYota is on a distinguished road
OpenYota's Avatar
Just replace it, it's cheap and easy to do.
The flipside is the cooler inside fails and gives you the pink milkshake which I can assure you will make all the other problems your truck has not a big deal
2001 SR5 4WD
OpenYota is offline   Reply With QuoteReply With Quote
Old 01-16-2024, 09:12 AM #4
aontkos's Avatar
aontkos aontkos is offline
aontkos will become famous soon enough
aontkos's Avatar
$200 in parts and a few hours of weekend time?
I'd say that's an easier pill to swallow than a new transmission if the integrated cooler fails.
Also, with not knowing the maintenance history of the vehicle, this allows you to catch up on a lot of unknowns. At almost 200k miles, the radiator should be replaced, along with coolant, hoses, radiator cap, etc.
aontkos is offline   Reply With QuoteReply With Quote
Old 01-16-2024, 09:32 AM #5
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
Look at radiator top cap color new is black as rad ages it turns brown, more brown more risk.
$200 buys you 200k mi Ins against strawberry milkshake cap cracks oil cooler fail.
If a 97 on original oh hell yes.
96RedRunner limited 4x4 5VZ auto not stock 374k miles totaled 2018.
2001 limited 4x4 5VZ auto work in progress.
2011 Audi S5 Prestige 4.2 V8 6 spd MT.
Old 01-16-2024, 09:40 AM #6
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
Newbie better listen to the experience here....if ya know whats good for ya. And don't forget about Toyota's achilles' heal, the LBJs (failure can easily be catastrophic). Luck.
2001 Limited 4WD - 349+K - SunfireRed\Thunder Cloud; - 265/75/16 Michelin A/T2s - Fat Pat's 1.5" BL - StopTech ANGLED rotors - In series 699 trans cooler, New Yota1 transmission, All new OEM suspension front to rear.
Old 01-16-2024, 11:18 AM #7
shadow247's Avatar
shadow247 shadow247 is offline
shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice
shadow247's Avatar
I would do it asap! I nearly blew up my other 4runner because I let the radiator go! Luckily I was able to limp it home, but it was seeping around the filler neck. Same thing happened on my 99 land cruiser. I went to check the fluid, and when I replaced the cap, it started leaking out of a pinhole that JUST opened up from the twisting.
I would top off your trans with Lucas ATF Conditioner. This is also a good opportunity to go ahead and do a Trans Flush using the cooler lines.
The 4Runner Show
shadow247 is offline   Reply With QuoteReply With Quote
Old 01-16-2024, 03:46 PM #8
Endlessblockades's Avatar
Real Name: Blair
Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold
Real Name: Blair
Swapping a radiator is easy - hell, even I did it. The alternative would be to cap and bypass the radiator's cooling tank altogether by installing a dedicated ATF cooling system but doing that took me as long as the radiator swap if memory serves (I have both). You'll probably spend the same amount, too. In any event, the radiator is right up there with the LBJs as must-do preventative maintenance. Everything else can wait.
Old 01-16-2024, 05:04 PM #9
bdjcl bdjcl is offline
bdjcl is on a distinguished road
I replaced mine around 210k as a peace of mind thing.
'98 Corolla LE 193k miles
'98 4Runner Limited 215k miles
bdjcl is offline   Reply With QuoteReply With Quote
Old 01-16-2024, 06:26 PM #10
Okay! I’ll get the stuff ordered and get er done!
Thanks for all the responses 🙂
Old 01-16-2024, 07:51 PM #11
TheShockerAL TheShockerAL is offline
TheShockerAL is on a distinguished road
On my 97 5spd it did not like to idle with the AC blasting in the Phx summer heat so I put the champion all aluminum radiator in it. Runs cool as a cucumber now, even climbing hills.
On my 01 I was worried about the dreaded pinkie, so I put in the Champion rad and bypassed the trans cooler completely with a remote trans cooler kit. (Whatever the equivalent to OEM is).
On my 02 Sport it wasn't lifted like the others so I put a new Denso in it and installed the remote trans cooler bypassing the radiators cooler.
TheShockerAL is offline   Reply With QuoteReply With Quote
Old 01-17-2024, 12:58 PM #12
MCgrease08's Avatar
MCgrease08 MCgrease08 is offline
MCgrease08 is on a distinguished road
MCgrease08's Avatar
I know I'm on borrowed time with mine. I have a '97 and just crossed over 290,000 miles with the original radiator. It's on the to do list come spring time, along with a new timing belt.
MCgrease08 is offline   Reply With QuoteReply With Quote
Old 01-17-2024, 04:51 PM #13
Real Name: Blair
Real Name: Blair
Gotta give credit to that 27 year old Japanese plastic, but it's time to stop trusting it!
hours , issue , issues , supplies , weekend
How to radiator replacement Crashnrondo 3rd gen T4Rs 57 07-05-2018 01:14 AM
Radiator replacement - when? 4by4runr 4th Gen T4Rs 21 09-07-2016 11:40 PM
03 radiator replacement kirkg 4th Gen T4Rs 17 10-20-2014 07:55 PM
Radiator replacement sonjason 3rd gen T4Rs 11 02-23-2011 01:10 PM
Radiator Replacement how-to doggernaut 3rd gen T4Rs 5 04-11-2009 06:45 PM
