Old 01-16-2024, 09:55 AM #1
DWilliam DWilliam is offline
DWilliam is on a distinguished road
New Codes: P0300 and P0301
2002 SR5. Recently at the mechanic for a new fuel pump and overflow check valve to try addressing evap codes. I'm unsure how long these current codes have been there, as I let the CEL stay on for the past couple months while I waited on parts.
Codes:
P0300; Random/Multiple Cylinder Misfire Detected
P0301; Cylinder 1 Misfire Detected
Symptoms:
Nothing major. Every once in a while when I fill up the tank it will take a few extra seconds to start, however I assumed this was from an old fuel pump, which has been replaced.
Should I start with new plugs and wires? If so, is that an easy job, or should I let my mechanic take care of it? I've done pugs before, but not wires and not on a 4runner.
Anything else I should address?
DWilliam is offline   Reply With QuoteReply With Quote
Old 01-16-2024, 02:28 PM #2
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Codes:
Symptoms:
I would start with plugs and wires, and switching the coil pack for #1 with a different one to see if it follows that. Plugs and wires aren't bad with the right tools. Take your time with the plug wires and look for a plug wire routing diagram when you do it. They're quite easy to switch around and you'll end up with more misfires.
Old 01-16-2024, 10:52 PM #3
98&me 98&me is offline
98&me is on a distinguished road
I would first check the spark plug for any strangeness. Then I personally would check the compression. ( I got the 300 code and 306 code which turned out to be a stuck exhaust valve)Then I would swap coils with a known good one. Clear the codes then do the code reset procedure.
98&me is offline   Reply With QuoteReply With Quote
Old 01-17-2024, 11:00 AM #4
Thanks for the replies. I ordered plugs, wires, and MAF cleaner. Watched a couple youtube videos and it seems pretty user friendly. Anything else I should look out for when I'm doing the job?
Old 01-17-2024, 02:58 PM #5
Real Name: Patrick
Real Name: Patrick
Check the boots on the coil packs for any signs of cracking/tearing. I'd also keep track of what spark plug came from where so you can reference it later.
Old 02-18-2024, 08:55 AM #6
If the misfire is on clylinder 1 per the code, is that injector relatively easy to replace? Should I test the coil pack first? And if so, is a coil pack difficult to replace?
Old 02-18-2024, 07:46 PM #7
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
If the misfire is on clylinder 1 per the code, is that injector relatively easy to replace? Should I test the coil pack first? And if so, is a cool pack difficult to replace?
Much easier than the driver side, I think you should be able to take off the fuel rail with just the throttle body removed and don't need to take off the entire intake? I just replaced an injector today on the passenger side and it took me about 90 minutes all said and done, so for the driver side I would expect half that at the very most.
As already mentioned, your first step should be moving the coil pack to another cylinder to see if the miss follows.
You can also test the injector with a multimeter, they should read between 13-18ohms (my MotorWest injectors read 13.5 across the board, but when I tested my OEM brown ones last year they were all near 17). If the problem is a dead injector, it'd be a good idea to pick up new crush washers for the fuel rail (#90430-12026, you need two for each banjo bolt.)
Have you been driving the vehicle since making this thread? Given that it seems like you're just starting to address the issue and it's been about a month since the original post, then it would be very wise to change the oil if you find the problem is just the coil pack and not the injector itself, as it's probably very laden with gasoline. Oil can take a little bit of gas and burn it off, but a ton of it is a good way to blow a hole in the side of the block.
You also mention you didn't notice the codes were there, and had no major symptoms. Did you ever try clearing the code and seeing if it came back as 98&me suggested? You would know right away if you had a constant misfire. It would run like hell and the CEL would be flashing.
Old 02-19-2024, 08:55 AM #8
Thanks for the reply. I have been driving it, but with a solid CEL, no blinking. Seems to run fine. I’m planning on doing plugs, wires, 1 coil, and clean MAF sensor this weekend and see if that helps.
codes , cylinder , detected , misfire , start
P0300 codes errrrrrrr Ol'Blue 3rd gen T4Rs 18 10-20-2024 10:00 PM
P0300, P0304 codes Condor12 Engines / Suspension / Wheels / Tires / Audio / Accessories 0 08-19-2014 05:28 PM
Help! P0300, p0301, p0302 Chandler_Ross 3rd gen T4Rs 2 06-04-2013 11:22 PM
Multi misfire P0300, P0301, P0302, P0303 kakarot 3rd gen T4Rs 3 12-24-2012 11:36 PM
4th gen 4runner V8 rough idle Misfiring p0300, p0301-p0308 aha2988 4th Gen T4Rs 9 04-10-2012 03:28 PM
