Old 01-19-2024, 03:22 AM #1
trashboy trashboy is offline
trashboy is on a distinguished road
removing steering wheel play by replacing the steering rack shaft
recently picked up a 98 4runner which is in mechanically good condition, but came with some sloppy steering.
so far, i have done
- steering rack bushings
- lower ball joints
- lower control arm bushings
- upper control arm bushings
- outer tie rods
- alignment
steering feels much tighter now, but i still have an issue with the truck veering slightly or becoming a tad unstable when going over speedbumps. another symptom is when the truck is not in motion, or driving straight, i can move the steering wheel about an inch left or right without affecting the direction its traveling. its still very much driveable, but its getting tiresome having to readjust the wheel slightly during driving.
i read a couple threads and saw some videos on people tac welding the steering rack shaft to remove the play in it. i haven't actually confirmed this is the problem yet (will check tomorrow), am curious if people have had success simply replacing the main shaft to fix this issue instead of tac welding it. would the fix last a while, or would i simply run into the same issue in a couple years? i have never liked the idea of messing with safety features, and the peace of mind would make me feel better simply replacing the part rather than doing a DIY fix.
i believe the part number is 45210-35200, outlined here 45210-35200 - Main-Shaft - 1996-2004 Toyota | Nucar Toyota of North Attleboro
does anyone have any ideas on what else could be causing this play? can someone please confirm that this part# is what i would be looking to replace if i wanted to simply replace the part?
trashboy is offline   Reply With QuoteReply With Quote
Old 01-19-2024, 05:10 AM #2
heat's Avatar
heat heat is offline
heat will become famous soon enough heat will become famous soon enough
heat's Avatar
Didn't see the rag joint mentioned...
45230-35090
'02 Limited 4x4 AT - Stock ~181k miles
Thundercloud aka metallic dirt
heat is offline   Reply With QuoteReply With Quote
Old 01-19-2024, 09:42 AM #3
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
Originally Posted by trashboy View Post
...... when the truck is not in motion, or driving straight, i can move the steering wheel about an inch left or right without affecting the direction its traveling....
Just so you know, out of the box Toyota owner's manual says 1" of steering play is 'normal', so it won't get at tight at a Porsche yet yours seems a little extra sloppy at present.
2001 Limited 4WD - 349+K - SunfireRed\Thunder Cloud; - 265/75/16 Michelin A/T2s - Fat Pat's 1.5" BL - StopTech ANGLED rotors - In series 699 trans cooler, New Yota1 transmission, All new OEM suspension front to rear.
Old 01-19-2024, 10:49 AM #4
anniesball72's Avatar
anniesball72 anniesball72 is offline
anniesball72 is on a distinguished road
45230-35090
At 150k I replaced everything OEM the OP did. In addition to a rebuilt rack from Camelback, inner tie roads, replaced lower control arms with new OEM for new bushings, etc. EVERYTHING! Steering was greatly improved yet still not back to new. (I bought mine new).
Next I replaced the rag joint. For me it didn’t make a difference. Not to say it won’t for you.
Then I read the post about tac welding it.
Had that done and the steering tightness was much better. Back to new.
In my opinion, tack welding it is much cheaper, you end up with the same result. With the weld it will not degrade over time.
02 SR5, manual hubs, 3” lift, airbags, 5-speed swap with locking center diff, 1st gen supercharger, URD 7th, BAMF sliders.
anniesball72 is offline   Reply With QuoteReply With Quote
Old 01-19-2024, 12:30 PM #5
alumarine alumarine is offline
alumarine has a spectacular aura about alumarine has a spectacular aura about
Like others, I had to tack weld my steering column as well to remove play.
I figure with seatbelt and air bag, I should be ok.
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
alumarine is offline   Reply With QuoteReply With Quote
Old 01-19-2024, 02:05 PM #6
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
It sounds like you need this video.
Old 01-19-2024, 02:33 PM #7
yep, saw this video but wanna explore options that does not involve tack welding. maybe im just paranoid but i figure better to be safe than sorry.
does anyone have any input on whether that part # seems correct if i want to just replace the shaft entirely?
Old 01-19-2024, 04:42 PM #8
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Just know this, and this is coming from a firefighter (Me) who has seen MANY automobile accidents over the last 17 years. MOST people escape pretty gnarly accidents with minimal injury because of seatbelts and air bags. If there was a massive enough head on collision with major intrusion into the passenger compartment that would cause the steering shaft to collapse, usually these people don't survive regardless of the safety mechanisms in place.
What I'm trying to say is your concern shouldn't be a concern with tac welding the steering shaft. Don't overthink it. Do the tac weld and save some money.
Old 01-19-2024, 08:44 PM #9
nissanh nissanh is offline
It is really bad to the steering shaft (splines and U joints) if wheel is turned while engine off. Once I had to remove the upper and lower covers of the steering column and had something removed in the engine so I couldn't start the engine, so I basically lifted both wheels off the ground to turn the steering. Mine is at 220K miles and absolutely zero play in the steering!
1990 3L Diesel Hilux LN 106; 1973 Ford Cortina XL
1992 4AFE Toyota Sprinter AE 91 (aka Geo Prizm)
1997 5vzfe 4Runner 4x4 (aka Hilux Surf)
2000 2uzfe 100 Series Land Cruiser
2021 Tacoma TRD Off-Road 4x4 6-speed
Old 01-19-2024, 09:22 PM #10
I've turned the steering wheel lock to lock with the motor off hundreds of times with the wheels on the ground on a variety of vehicles with no ill effects.
Many others have as well.
Old 01-21-2024, 02:00 AM #11
snydmax's Avatar
snydmax snydmax is online now
Real Name: Matt
snydmax will become famous soon enough
snydmax's Avatar
Real Name: Matt
Had same… eventually replaced everything up front… some play remained. Tack welded the slip thingy and play gone, never looked back
'98 4WD Limited, Warm Grey, 172k, Factory E-Locker, Ride-Rites, 265/75-16 Wildpeak AT3s
snydmax is online now   Reply With QuoteReply With Quote
Old 01-21-2024, 06:15 PM #12
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
Needs to be worse than this to effect steering column.
Got tacked when needed, same will happen to 01.
removing steering wheel play by replacing the steering rack shaft-img_1471-jpg
96RedRunner limited 4x4 5VZ auto not stock 374k miles totaled 2018.
2001 limited 4x4 5VZ auto work in progress.
2011 Audi S5 Prestige 4.2 V8 6 spd MT.
part , rack , shaft , simply , steering
Loose steering and wobbly steering wheel even after steering rack bushing replacement psyduck 3rd gen T4Rs 18 07-17-2022 07:17 PM
Excessive play on drivers side steering - replace steering rack guide cheeser 3rd gen T4Rs 17 05-05-2022 08:15 PM
Why lock the steering wheel when replacing rack bushings? texadelphia 3rd gen T4Rs 15 05-18-2021 09:17 AM
Replacing steering wheel with another Toyota/Lexus model steering wheel LexusFTW 3rd gen T4Rs 20 03-04-2021 12:24 AM
Need help removing steering shaft off steering rack TheCremePuff 4th Gen T4Rs 4 10-07-2017 11:57 PM
