Old 02-03-2024, 12:48 PM #16
Ed_C's Avatar
Ed_C Ed_C is offline
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
Originally Posted by trashboy View Post
thanks for the replies guys, i ordered some 99+ headlights and was about to order the rest of the supplies needed, but am a little confused on how everything gets wired up.
would something like this kit be sufficient?
https://www.morimotohid.com/morimoto...tem?quantity=1
35w ballasts
9006 4000k bulbs
9005/9006/9012/h10 wire harness
is the antiflicker capacitor nessecary?
for context, i am planning on ordering the square mini d2s projectors from morimoto with a panasquare shroud.
https://www.morimotohid.com/morimoto...ors?quantity=1
Interesting, TRS is undercutting their own dealers (they've been told to do MAP pricing for a few years now) with that discounted price on the square 5.0's
Wrong bulb and wire harness selection. No antiflicker capacitor needed.
If yours is equipped with DRLs, bypass them, there are a few how-tos on this forum, and run a Motocontrol harness https://www.morimotohid.com/morimoto...ess?quantity=1 But if you're not scared of doing your own wiring a basic relay harness with 9006 connections and some diodes and H4 plugs will do the job.
Non-DRL, you can also run a basic harness minus the diodes.
It's cheaper running NHK G3 ballasts, and a much lower failure rate than those Morimoto ballasts AMP: NHK G3 38W Ballasts – Lightwerkz Global Inc I suggest getting Philips or Osram D2S bulbs and the premium AMP-to-D2S adapters from Lightwerkz also
Old 02-03-2024, 05:26 PM #17
trashboy trashboy is offline
trashboy is on a distinguished road
thanks for the reply
i dont believe mine has non-drls, for context i'm on a 98 limited.
im a little confused on why the bulb and wire harness selection is incorrect. the mini d2s says that it includes "2x 9006 Solenoid Input Pigtails". doesnt that mean that i would need a 9006 bulb for the projector?
read through alot of the official retrofit guide and watched some youtube videos, but no one ever talks about the wiring part (which i feel like is more confusing than the actual installation process)
trashboy is offline   Reply With QuoteReply With Quote
Old 02-03-2024, 10:35 PM #18
Ed_C's Avatar
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
The 9006 pigtails are for the projector's highbeam solenoids; the projectors use D2S bulbs, hence the "D2S" in the projectors' name.
Relay harnesses are triggered by the OEM headlight wiring, on a H4 system the lowbeam power is cut off when highbeams are activated. A Motocontrol harness (or standard relay harness with a diode) keeps the HID ballasts powered when highbeams are on.
Old 02-04-2024, 12:09 AM #19
so from doing some more research and based off what you said, i could go ahead and use
- 2x d2s bulbs
- 1x motocontrol (h4/9003) https://www.morimotohid.com/morimoto...ess?quantity=1
- 2x 35w ballasts AMP: NHK G3 38W Ballasts – Lightwerkz Global Inc
- 2x mini d2s projectors
from my understanding, the flow goes like this
battery -> motocontrol -> ballast (1 on each side) and original factory plug -> bulbs (1 on each side)
does that sound correct?
Old 02-04-2024, 06:56 PM #20
Ed_C's Avatar
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
- 2x d2s bulbs
You'll also need AMP-D2S adapters Premium AMP > D2S Ballast Adapters – Lightwerkz Global Inc
Pretty much. Only the original driver side bulb connector plugs into the Motocontrol, passenger side is left unplugged. The power connectors to the ballasts and bixenon solenoids are the same type but they'll be labeled, and the ballast ones will have seperate grounds.
black , headlights , housing , paint , showoff
5th gen retrofitted headlights,MA $900.00 Bob43 For Sale: T4R Items 3 06-22-2017 04:10 PM
WTB: 06-09 Retrofitted HID Headlights paperchasin Want to Buy/Trade 0 04-27-2015 04:02 PM
WTB: 3rd gen retrofitted headlights. 98LtdT4R Want to Buy/Trade 1 02-26-2013 07:35 PM
WTB: Retrofitted 98-02 headlights en93nsx Want to Buy/Trade 0 05-12-2012 01:51 PM
Retrofitted headlights are done!!! Schell 3rd gen T4Rs 4 10-19-2010 04:01 PM
