Old 01-26-2024, 03:48 AM #1
trashboy trashboy is offline
trashboy is on a distinguished road
showoff your retrofitted headlights
planning to retrofit my headlights and just wanna get some ideas of what people have done with them (particularly if you didn't paint the housing black, and kept it chrome for a more oem+ look)
trashboy is offline   Reply With QuoteReply With Quote
Old 01-26-2024, 04:12 AM #2
Twisted Sid's Avatar
Twisted Sid Twisted Sid is offline
Twisted Sid has a spectacular aura about Twisted Sid has a spectacular aura about Twisted Sid has a spectacular aura about
There is an "official" retrofit thread out there but I don't feel like looking for it so...
https://www.toyota-4runner.org/3825644-post35412.html
'99 4Runner SR5: 5VZ, 2wd, AT, 400k+ club
'94 Pickup: 2wd, 22RE, 5spd, (3RZ swap in progress)
Front: Total Chaos Uniball Kit, Fox 2.5 8'' coilover
Rear: Deaver F67 Leaf Springs, Fox 2.0 14'' Reservoir Shocks, E-locker Axle 4.88 Gears 33x10.5 BFG ATs
Twisted Sid is offline   Reply With QuoteReply With Quote
Old 01-28-2024, 10:35 PM #3
Robb235's Avatar
Robb235 Robb235 is offline
Real Name: Robert
Robb235 will become famous soon enough
Robb235's Avatar
Real Name: Robert
Funny you should mention this. I posted a write up of my budget retrofit build. Personally I’m a big fan of blacking out the housings and using black shrouds, and blacking out the corner markers with Purple Power as well. Really updates the look of the truck, especially with a Satoshi grill. Retaining the chrome on these massive headlights just ages these trucks so much in my eyes.
Robb235's Cheapo DIY Projector Retrofit
1999 Toyota 4Runner Limited 4x4 - Turbocharged GTX3071 - URD AFR Sensor Calibrator - DW255 fuel pump - 2JZ Supra 315cc “teal top” fuel injectors - Rear Elocker Retrofit w/ 4.30 gears - 2wd Low (2Lo) On Demand - 231mm Tundra Brake Upgrade - Hayden 699 Transmission Cooler - Monitoring ATF Temps w/ My iPhone - DIY Projector Headlight Retrofit - Backup Camera Retrofit - Cooper Discoverer AT3 - OME 906 Coils & Rancho 9000XL Shocks (Rear)
2000 Yamaha XR1800 Jet Boat - MR1 4-Stroke Engine Swap
Robb235 is offline   Reply With QuoteReply With Quote
Old 01-29-2024, 02:16 PM #4
SearsTom SearsTom is offline
Real Name: PollTomBL
SearsTom is on a distinguished road
Have you considered checking out Robb235's budget retrofit build for ideas, especially since you're interested in a more OEM+ look without blacking out the housing?
SearsTom is offline   Reply With QuoteReply With Quote
Old 01-29-2024, 02:47 PM #5
StangRunner StangRunner is offline
StangRunner is on a distinguished road
I opted to DIY my OEM+ retrofit... it was not exactly 'budget' but considerably cheaper than other kits for sale with what I think are the highest quality components. I, like you, wanted to keep the vintage OEM look but with the benefit of the modern lighting. I really don't like the blacked out look, personally.
These are the components I used:
-TYC OE-style Housings from Amazon
-Motimoto Mini H1 projectors
https://www.theretrofitsource.com/bi...-H1?quantity=1
-Morimoto X5-R Switchback Halos (Amber wired to turn signal, white wired to parking lights)
https://www.theretrofitsource.com/mi...LED?quantity=1
-SuperNova LED's three color LED bulbs (I like them because you can run amber, cool white, and soft white)
Supernova LEDs - Supernova LEDs V4 LEDs H1 - Quality LEDs for your Car
-6 gang generic relay box from Amazon, mounted next to the battery with riv-nuts
Amazon.com
-H4 adapter harness to control the relays and high beams and to avoid cutting stock wiring
Amazon.com
-Headlight Sealer
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
-Waterproof connectors
There was also a ton of soldering and custom harness building involved so it's not for the faint of heart, especially if you make it totally plug and play like I did. It was by far the most tedious mod I've done but its so worth it.
showoff your retrofitted headlights-img_0242-jpg  showoff your retrofitted headlights-img_8555-jpg  showoff your retrofitted headlights-img_8573-jpg
StangRunner is offline   Reply With QuoteReply With Quote
Old 01-30-2024, 04:36 AM #6
Amazon.com
Amazon.com
-Headlight Sealer
do you happen to have a guide that you followed for it? i dont really understand how all the connections are supposed to be set up.. i understand the process of installing the projectors etc, but how do you actually provide power to them? im interested in just running a projector with low/high functionality, don't really care for rgb or halos or anything like that
Old 01-30-2024, 02:23 PM #7
Ed_C's Avatar
Ed_C Ed_C is offline
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
I ran blacked-out housings/shrouds/projector cutoff shields (doesn't affect light output) and corners. Dechroming shrouds and corners are easy; soak them in Purple Power or purple Zep degreaser, it takes about 10-15 mins of soaking to strip the shrouds and a few hours to do OEM corners, but aftermarket corners took about the same time to strip as the shrouds. Zep is a stronger formulation, I've seen videos of people dechroming OEM corners/signals after minutes of soaking.
E46 style shroud, cutoff shields painted black (AKA passive demon eye) on a G5-R projector
MH1 7.0 projectors with the same shrouds and black passive demon eyes. Scuffed the housings and painted with either Krylon or Rustoleum satin black
I have another retrofit in the works but in chrome, the shrouds I've selected (haven't seen anyone use them on a 3rd-gen) won't make it look too "bug eyed"
Old 01-30-2024, 04:29 PM #8
which shrouds are you planning on using? i was also looking for something that is less bug eyed, was thinking of the panasquare shroud maybe..
Old 01-31-2024, 11:03 AM #9
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
TEQ Customs in Raleigh, NC makes nice sets of retrofit headlights. They also sell DIY kits if you want to assemble them yourself.
Old 01-31-2024, 08:41 PM #10
snydmax's Avatar
snydmax snydmax is offline
Real Name: Matt
snydmax will become famous soon enough
snydmax's Avatar
Real Name: Matt
TEQ’s “OEM+”
'98 4WD Limited, Warm Grey, 172k, Factory E-Locker, Ride-Rites, 265/75-16 Wildpeak AT3s
snydmax is offline   Reply With QuoteReply With Quote
Old 01-31-2024, 11:52 PM #11
for those that have done the retrofit, does it matter if i use a 99+ housing on a 98? i looked it up and apparently they have different mechanisms of spraying the light out (one reflects, one doesnt). would it matter in my case? also, does it matter if the lens is plastic vs glass?
Old 02-01-2024, 01:22 PM #12
All US housings are glass front. They are mechanically compatible where they bolt to the chassis and line up to the body between the clear and fluted lenses. Use the later housing if you are doing a projector retrofit.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 02-01-2024, 01:51 PM #13
shadow247's Avatar
shadow247 shadow247 is offline
shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice
shadow247's Avatar
You'll want to use 99 and up headlight housing for the clear lens. 96-98 have a grid pattern etched into the lens. I don't think it would work out too good.
The 4Runner Show
shadow247 is offline   Reply With QuoteReply With Quote
Old 02-02-2024, 01:57 AM #14
Ed_C's Avatar
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
Use the 99-02; you want clear lenses, not fluted like the older ones.
If you still have the OEM lights I suggest reusing the mounting frames. I've used a few aftermarket OEM replacements and the fitment for the corner lights and the filler panels between the headlights and bumper are never as good as OEM
Old 02-03-2024, 01:52 AM #15
thanks for the replies guys, i ordered some 99+ headlights and was about to order the rest of the supplies needed, but am a little confused on how everything gets wired up.
would something like this kit be sufficient?
https://www.morimotohid.com/morimoto...tem?quantity=1
35w ballasts
9006 4000k bulbs
9005/9006/9012/h10 wire harness
is the antiflicker capacitor nessecary?
for context, i am planning on ordering the square mini d2s projectors from morimoto with a panasquare shroud.
https://www.morimotohid.com/morimoto...ors?quantity=1
black , headlights , housing , paint , showoff
5th gen retrofitted headlights,MA $900.00 Bob43 For Sale: T4R Items 3 06-22-2017 04:10 PM
WTB: 06-09 Retrofitted HID Headlights paperchasin Want to Buy/Trade 0 04-27-2015 04:02 PM
WTB: 3rd gen retrofitted headlights. 98LtdT4R Want to Buy/Trade 1 02-26-2013 07:35 PM
WTB: Retrofitted 98-02 headlights en93nsx Want to Buy/Trade 0 05-12-2012 01:51 PM
Retrofitted headlights are done!!! Schell 3rd gen T4Rs 4 10-19-2010 04:01 PM
