Old 01-30-2024, 07:29 PM #1
JoeT4R's Avatar
JoeT4R JoeT4R is online now
JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light
JoeT4R's Avatar
VSC TRAC light on
As mentioned above, my VSC TRAC light is on in my 2001 SR5 4WD, but not the VSC OFF or check engine light. My ScanGauge isn't revealing any codes and I'm not experiencing anything different than what I consider to be normal operations.
I've disconnected my battery for well over an hour to see if that would reset the light, but it remains on. I should also add that upon turning the truck on, the light itself isn't on until I put the truck in drive and begin driving. Within seconds is when it pops up. I cannot figure out what on earth could be causing this. I don't have the Andy Mod 2.0 or anything done to my rig, so what are your thoughts?
I've perused the forum and Google itself without much results related specifically to this so I'm just not sure. I'm not terribly worried about it because the truck is acting normal, but if I can figure out what's causing it to turn on, I'd love to know.
JoeT4R is online now   Reply With QuoteReply With Quote
Old 01-31-2024, 09:40 AM #2
St Runner's Avatar
St Runner St Runner is offline
St Runner will become famous soon enough
St Runner's Avatar
Just guessing here but since the VSC runs through the ABS brakes you might try to pull any codes off of the ABS Possibly a rear sensor that would not show up in a ECU code check
1997 SR5 4x4
R150f swap E-locked 4.30 gears
Tundra 231 brakes LC 80 rims 285/75/16
2001 SR5 4x4
St Runner is offline   Reply With QuoteReply With Quote
Old 01-31-2024, 11:20 AM #3
spartacus's Avatar
spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of
spartacus's Avatar
You'll have to pull the abs codes. Brake fluid level good. Abs sensors could have buildup. like mentioned above pulling the abs codes would help.
Old 01-31-2024, 12:20 PM #4
kellygoosecock kellygoosecock is offline
kellygoosecock is on a distinguished road
Head's up you have to pull the codes using a paper clip and the diag connector under the hood or the Toyota Techstream software, your standard OBDII scan tools can't read them. There's links to the factory shop manual around the forum here for all the code diag steps.
kellygoosecock is offline   Reply With QuoteReply With Quote
Old 01-31-2024, 01:16 PM #5
JoeT4R's Avatar
JoeT4R's Avatar
That’s exactly what @ said in another thread (3rd gen all questions)
So with this in mind, am I utilizing the diagnostic port that’s under the hood and NOT the OBD-II port for this? I’ve watched a few videos on that but they’ve all used the OBD port with a wire.
I also disconnected my front passenger ABS sensor yesterday and tried reading it with a voltmeter but I got zero response from it. I didn’t try the driver side though.
Old 01-31-2024, 04:02 PM #6
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Originally Posted by JoeT4R View Post
That’s exactly what @said in another thread (3rd gen all questions)
You have to use the underhood diagnostic port to flash abs codes. Also, if you were using a voltmeter with the wheel speed sensor side you will only be able to read ac voltage if the wheel is spinning.
Old 02-01-2024, 08:28 AM #7
JoeT4R's Avatar
JoeT4R's Avatar
So I'm going to be jumping the diagnostic port with two wires? I don't think I've ever even opened mine before.
Old 02-01-2024, 12:17 PM #8
yeah just one wire between two pins, check this video- 96-02 Toyota 4Runner ABS Complete Guide How To Read Codes & Delete Them Brake - YouTube
Old 02-02-2024, 01:25 PM #9
JoeT4R's Avatar
JoeT4R's Avatar
**Update**
Turned my truck on today and began driving, no VSC TRAC light is on anymore. Very strange but I’ll update this thread if it returns. I haven’t done anything so I wonder if it just took a few driving cycles or something to turn off. But everything is working normally.
Old 02-02-2024, 06:23 PM #10
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
My symptoms were different and consistent and pointed to the Trac module being bad.
FSM section starting at DI-221 might come in handy if your problem should return.
96RedRunner limited 4x4 5VZ auto not stock 374k miles totaled 2018.
2001 limited 4x4 5VZ auto work in progress.
2011 Audi S5 Prestige 4.2 V8 6 spd MT.
figure , light , normal , truck , vsc
Check engine light, VSC TRAC & TRAC OFF lights crainmain Maintenance/Detailing 120 11-22-2023 07:11 PM
VSC TRAC, TRAC OFF, and Check engine light all on. samdajellybeenie14 3rd gen T4Rs 13 02-19-2020 09:36 PM
Check engine light vsc trac & trac off lights come on piptraderfx New Members 5 03-14-2014 07:47 AM
VSC Trac and VSC Trac Off light observation Mike the Wino 4th Gen T4Rs 5 07-14-2013 08:19 PM
Check engine light Vsc trac Vsc trac off deadmaggot6 Problems & Warranty Issues 0 10-06-2008 09:44 PM
