Originally Posted by JoeT4R
That’s exactly what @said in another thread (3rd gen all questions)
So with this in mind, am I utilizing the diagnostic port that’s under the hood and NOT the OBD-II port for this? I’ve watched a few videos on that but they’ve all used the OBD port with a wire.
I also disconnected my front passenger ABS sensor yesterday and tried reading it with a voltmeter but I got zero response from it. I didn’t try the driver side though.
You have to use the underhood diagnostic port to flash abs codes. Also, if you were using a voltmeter with the wheel speed sensor side you will only be able to read ac voltage if the wheel is spinning.
2000 SR5 V6 Manual 4WD
https://www.toyota-4runner.org/3rd-g...biography.html
