Old 02-06-2024, 01:43 AM #1
trashboy trashboy is offline
trashboy is on a distinguished road
aftermarket rear bumper with no lift?
i recently placed an order for a rear bumper that should be about 135 lbs added on.. problem is i'm not lifted at all. should i wait until im lifted before installing the bumper?
i've read through the lift thread but no one really talks about this, i probably modded things out of order (should have gotten a lift before the bumper).
trashboy is offline   Reply With QuoteReply With Quote
Old 02-06-2024, 05:47 AM #2
2TH4IST's Avatar
2TH4IST 2TH4IST is offline
2TH4IST has a spectacular aura about 2TH4IST has a spectacular aura about 2TH4IST has a spectacular aura about
2TH4IST's Avatar
Probably will sag quite a bit. Back when I did my rear bumper (eimkeith's) it's 115 pounds, sagged it. Then did the f150 tank mod and it was on the bump stops lol. Running ome 891's w/lc shocks now and it rides good. The springs just settled a bit to much for me.
There's danger lurking around every corner, that's why I propose we make all of our buildings round.
I don't remember the time I was human that's why I don't understand anybody.
2TH4IST is offline   Reply With QuoteReply With Quote
Old 02-06-2024, 10:55 AM #3
Zhehan Zhehan is offline
Zhehan will become famous soon enough Zhehan will become famous soon enough
Are you using the OEM coil isolators? If not, you should put those in along with some OME 10mm Trim Packers to re-gain some lost lift. Those 2 items should add about 1/2" of lift.
Or, you could also try this:
W73420 Whiteline Spring - pad bushing
– Whiteline USA
- 20mm Spring Pad This is designed for the front of the LC80 series springs and works with the rear of the 3rd Gen 4Runners.
W73404 Whiteline Spring - pad bushing
– Whiteline USA
- 30mm Spring Pad
Hope this helps.
2000 4Runner SR5 Manual Trans Federal Emissions - Eibach Pro-Truck coilovers, LC 7.5/Tokico Black, JBA UCA, SPC 25945 RLLs, Mevotech Supreme RULs, TrakMotive Xtended Travel CV Axles TO-8043ET, South Bend Rally Clutch, ES & Whiteline Bushings, MagnaFlow Cat-Back, Deck-Plate Mod, 4.56 Yukon Gears, Yukon Grizzly Rear Locker, Bushwacker Flares, 16x8 Wheels w/ 285/75 General Grabber AT2, 229K+ Miles
Zhehan is offline   Reply With QuoteReply With Quote
Old 02-06-2024, 01:57 PM #4
phattyduck phattyduck is online now
Put 135lbs in the back of the cargo area and look at it (and even drive it around). That's what it would be like with the bumper installed. If you like it, go for it.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
phattyduck is online now   Reply With QuoteReply With Quote
Old 02-07-2024, 07:11 AM #5
2TH4IST's Avatar
2TH4IST's Avatar
Yeah I'm still using the spring spacer/cone thing and I have 10mm spring pack installed. I ended up buying dobinsons C59-210V land cruiser coils instead. Just haven't installed them yet. Going to outboard the rear shocks still.
Old 02-07-2024, 07:59 AM #6
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Get a body lift before committing to bumpers. Otherwise you turn a $150 mod into a $2000+ mod.
Biggest regret I have... next to not buying something solid axle
bumper , lift , lifted , order , rear
WTB: 3rd Gen Aftermarket Rear Bumper JoeT4R Want to Buy/Trade 5 07-14-2023 03:43 PM
Body Lift if you already have an aftermarket bumper not built for it? noxor 3rd gen T4Rs 3 07-03-2023 10:20 AM
OME full lift w/ aftermarket rear bumper doctorres112 5th gen T4Rs 10 09-09-2017 11:26 PM
Anyone running aftermarket rear bumper without body lift? Sup41 3rd gen T4Rs 22 08-18-2017 10:39 PM
Aftermarket Rear Bumper rweddy1 3rd gen T4Rs 4 01-10-2007 04:10 PM
