Originally Posted by Krommeweg
Change the contacts! If it's an original Denso unit, and the hardware isn't totally corroded, you can fix it. That NAPA garbage will buy you about six months. The hardest part of this job is pulling the starter. Once you have it on the bench, contacts/plunger are real easy. If you want to replace the whole unit GO DENSO!!
The judgement about corrosion is going to be up to you... but if I can pull the starter and change the contacts literally anyone with half a brain can do it.
Check out this video which includes part numbers.
3rd Gen T4R DIY Maintenance, Repair and Modification Videos - Page 3 - Toyota 4Runner Forum - Largest 4Runner Forum
I took another look at the starter while I was spraying bolts and nuts down with PB Blast and decided I’m replacing the starter. Also I got a really good deal on a denso starter and only paid $116 through my job. If I was to get OEM plunger and contacts online at the cheapest dealer I found, it was gonna cost $60. And if I open the cover to get at the plunger & contacts and those bolts are rusted and break I’m screwed. Toyota charges re stocking fees for returns.
I’m gonna try to change it this weekend if it doesn’t rain. I also tried taking the upper tube off the transmission dipstick and it’s not budging, even after spraying it with PB blast. Looks like I’ll be dropping the sway bar and going from underneath on getting the starter out
