Old 02-19-2024, 11:32 AM #1
danthemanx07 danthemanx07 is offline
danthemanx07 is on a distinguished road
Engine Swap - 1998 3.4l into 1997 with 3.4l
I am a sucker for a 3rd gen. I just sold one and am now looking at another. It is a 1997 with 340k miles - but it is a 5 speed.
I am not terribly concerned about the miles (if I can get it for the right price) in part because I have a 1998 3.4l with 150k ish miles on it in my garage.
I assume that the 1998 would swap right into the 1997, but I wanted to check the hive mind before making a you-know-what of my self. The 1998 came from a 4runner equipped with an auto, but I really don't see why that would matter unless y'all have something different to say.
I searched through various threads on this, but many of the comments seem to be made under the same assumption that I have - that it should work. I did find at least one thread though where a fella got a 1998 engine into his 1997 but was unable to get it started. The thread died without a resolution.
2005 GX470
3.4l A340 Automatic to R150F Manual Transmission Swap
http://ttora.com/forum/showthread.php?t=159482
danthemanx07 is offline   Reply With QuoteReply With Quote
Old 02-19-2024, 04:56 PM #2
That should swap with no issue. There are very minor wiring differences through the years, but the long block is the same, mechanically. (they updated the head gaskets through the years, but that isn't a compatibility issue)
You already have to swap harnesses (manual vs. auto), so most of the differences will already be taken care of.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 02-19-2024, 05:04 PM #3
Thanks for the input. Curious what harness I would have to swap though. The engine has its harness, that runs through the big black boot on the passenger side of the engine bay to the ECU. My assumption would be if anything would need swapped it would be all of the plugs from this harness to their respective connections on the engine going in.
The transmission harness runs up to the ECU and terminates there.
I wouldn't be swapping the transmission. Am I missing some connection between the engine and transmission that I am not aware of?
2005 GX470
Old 02-19-2024, 08:10 PM #4
The engine and transmission use the same harness. It runs from the boot on the firewall you see, over the engine to the driver's side, then down and back to the transmission, over the top to the transfer case and rear O2 sensor. To remove the engine and engine harness, you have to unplug everything on the transmission and it will come out with the engine. You also are supposed to remove the harness from inside the cab (ECU plugs and a few plugs to the dash harness) to have that side come out with the engine.
On a MT truck, it will only have the reverse light switch, transfer case switches and rear O2 sensor wires. The AT also need a few speed sensor signals, the neutral safety / range switch and the solenoid wires.
Old 02-19-2024, 08:18 PM #5
Got it now. Thanks for the break down!
2005 GX470
3.4l , engine , miles , swap , thread
Engine Swap 2000 into a 1998 azcat90 3rd gen T4Rs 22 12-04-2014 01:21 PM
1997 or 1998 Limited cjd Want to Buy/Trade 0 02-08-2014 03:14 PM
FS: Parting out THREE 4runners 1996 1997 1998 nissanh For Sale: T4R Items 89 12-04-2013 09:04 PM
Need Help on JDM 3.4 Engine Swap 1998 4runner Limited Gho5t5niper 3rd gen T4Rs 5 10-22-2013 11:40 PM
Service Manuals-1997 okay for a 1998 4Runner? 737Mech 3rd gen T4Rs 6 03-09-2011 12:56 AM
